HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 02-01-2015, 09:10 PM
  #8581
Trader Rating: 83 (100%+)
Gonna rewire my HW sct esc and 4700 kv motor. Is 12g big enough or do I need 10g?
dpcardoza is offline
Old 02-01-2015, 09:14 PM
  #8582
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
Quick question...
...Will the Xerun version 2.1 run on 1S?
Thanks.
Rich Panganiban is offline
Old 02-01-2015, 10:21 PM
  #8583
Originally Posted by JCascia
Hey there, I've got a EZRun 60a-SL and while running around the track, it just stopped. I thought it was the motor as it is was an old one but after installing a new Tacon 3500kv motor, it sort of goes forward weakly with a lot of cogging and will not go in reverse. The lights show its getting the throttle input but nothing happens. It is about six months old. I hooked up the programming box and it all looks good. I also tried re-calibrating it. Any ideas?
anybody have any advice on this or is it just toast?
JCascia is offline
Old 02-01-2015, 10:26 PM
  #8584
tc5 man's Avatar
On 4wd SC what do you have your lipo cutoff at ? My is set at 3.2v on the cutoff on the SCT pro esc well it kicked in into 7 mins of a 8 min main at a indoor dry clay track . Both cells had 38% cap left and 3.81v on both cells it was a 6000mah 2s pack.
Running a Xerun 4000kv on a Stock SCT410 .
tc5 man is offline
Old 02-01-2015, 11:15 PM
  #8585
Trader Rating: 24 (100%+)
rcuser67898578 is offline
Old 02-02-2015, 04:17 AM
  #8586
Slotmachine's Avatar
Just to make sure, try another receiver. If the unit is near six months old they may still cover it go to FalconSEKIDO.com and get an rma# and send it in.
Paul
Slotmachine is offline
Old 02-02-2015, 07:40 AM
  #8587
Hi Guys,
I've got an v3.1 120a Esc WaterProof version, with the built in sensor.
I want to move my esc from my touring car to my formula 1 car but sensor is too short ...
On the product description, HW talk about a "Sensor Lead Extender", but never found it anywhere !?
Is this extender really exist or is the sensor cable is really non removable on this esc ? Or just a silicon join to retire ?
Thanks for help,
JÚrem'
Jerem is offline
Old 02-02-2015, 09:33 AM
  #8588
lewis110's Avatar
Originally Posted by Rich Panganiban
Quick question...
Thanks.
Yes it will. Turn the LVC off, remove the red wire from the receiver plug and run a receiver pack. This works with any HW speedo.
lewis110 is offline
Old 02-02-2015, 01:37 PM
  #8589
Trader Rating: 32 (100%+)
On the 150 amp 1/8 esc does the power wires unplug or unsolder off the esc. It came setup to run 2 2s packs. I want to change it to 1 4s.
kyok2 is offline
Old 02-02-2015, 03:43 PM
  #8590
Thanks!
  #8591
Structure26's Avatar
Trader Rating: 17 (100%+)
Can anyone confirm if the latest firmware update for the HW SCT Pro ESCs helps with the glitching/clogging? I ran two SCT pros last night, one in a SCT410 and the other in an EB48.2. The SCT and the buggy both experienced what felt like a clogging or glitching episode throughout the night. I felt it most during low speeds and when turning. Last night, however, I did not have the firmware updated on the ESCs, just learned about it today and made the updates. I'm just wanting to see if the firmware fixes this issue or if I need to take other actions.
SCT410--> HW SCT PRO-->HW 4700kv-->1256 Savox--> Racers edge glitch buster-->SR300 rx
EB48.2--> HW SCT PRO-->SMC 1900kv-->1271 Savox --> Racers edge glitch buster-->SR300 rx
**Both ESCs and Motors are both brand new
Thanks.
Structure26 is offline
Old 02-02-2015, 04:32 PM
  #8592
WonTonsChicken's Avatar
Trader Rating: 43 (100%+)
Thanks.
To piggy back off this question, are they BEC voltages able to be adjusted? (i.e. 6.0v to 7.4v)
WonTonsChicken is offline
Old 02-02-2015, 07:08 PM
  #8593
Trader Rating: 18 (100%+)
12 should be plenty but if your questionable go with 10
xxxntwv is offline
Old 02-02-2015, 07:11 PM
  #8594
Bec is not adjustable,as for the firmware check which version you haver installed.I'm not sure that the newest one in the new software is correct.
xxxntwv is offline
  #8595
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
..noticing lots of queries re the SCT Pro ESC but not many answers?
nexxus is offline
