HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 01-29-2015, 09:26 AM
  #8551
Default SCT Pro delay
I just purchased the 120amp sct Pro esc. I also have the LCD program box. The esc has a delay when you hit the throttle and then goes full power after about 1-2 secs when starting from a full stop. It doesn't do it when my truck is already moving. I have tried the latest firmware, different motors and receivers. I have also made sure that there is no expo or any settings that could affect this in the radio. Is there any thing else I need to look at?
Danny Sanchez is offline
Old 01-29-2015, 09:35 AM
  #8552
Trader Rating: 83 (100%+)
I'm sure someone else will give you a more detailed answer but I'd start with the basics. Make sure your battery is good, good connections and the caps are solid. May want to lower the lvc to 3V as well. If you ate punching it it may be hitting the lvc.
dpcardoza is offline
Old 01-29-2015, 09:41 AM
  #8553
Yeah. I've made sure the batteries are charged, different sensor wires and the connections are fine.
Does anyone know what the current version of firmware is for the SCT Pro?
  #8554
Default New SCT Pro shutting off
Suspecting Low Voltage Cutoff, but don't know why.
Brand new SCT Pro, replacing a Viper VTX10 and borrowed Tekin RS. No shutoff problems whatsoever with those two. Installed in HPI Blitz ESE, with Viper VST 8.5 (4000 kv). Initially geared at 21/88. First race with a 1 year old Protek 4300 mah 100c shorty, ESC shutoff/went into limp mode immediately after 5 minute qualifier. Motor temp was 124. ESC was like 65.
Second qualifier, running 4000 mah 75c Racers Edge Shorty, 1 year old. ESC went into limp mode again 1:00 into race. I also noticed when I put this battery back on the charger, it was already at 7.6. Started at 8.4 as always.
LVC is set to factory preset 3.2. Punch was level 6. Didnt touch timing (later noticed factory preset is +15?!?)
For the main, I turned off LVC. No limit. Also though, ran a brand new Orion 4500/100c shorty. Dialed Punch back to 5, and geared up to 24/88. (Large fast outdoor track). ESC made the full 7 minute main. And was fast and won. Nothing got hot.
So question is, why was this ESC shutting off so quickly with LVC set to 3.2? Neither the Viper or Tekin shutoff in a year of using the same batteries on the same and similar tracks. Punch on those were usually 60-70% w/8.5. I never ran timing on them though.
Would running the preset 15 Degree timing on a 8.5 cause so much current draw that the batteries would go below 3.2c per cell on a fresh charge? Again, nothing ever got hot. Not even close.
It was a large track with lots of wide open throttle, but so far I'm not impressed.
What's the lowest safe setting I can set the lvc to? I never practice. Longest runs I ever do would be a 7 minute main plus a few practice laps first. The battery should never get to any dangerously low levels running like this.
FujativeOCR is offline
Old 01-29-2015, 09:51 AM
  #8555
FastPete's Avatar
Trader Rating: 44 (100%+)
If you had a monitor hooked up to see when your driving around you would be surprised what it drops to under load.
I run all mine at 2.6-2.8 no issues.
FastPete is offline
Old 01-29-2015, 09:56 AM
  #8556
FastPete's Avatar
2013-11-30
database version:130814
And lower the LVC
FastPete is offline
Old 01-29-2015, 10:30 AM
  #8557
Originally Posted by FastPete
2013-11-30
And lower the LVC
How do I install this firmware. The Hobby Wing pc software does not list it as available.
Old 01-29-2015, 11:00 AM
  #8558
bluer322's Avatar
Need a little help. I'm new to electric off-road. I'm going to start running 4wd off-road mod. I have a hobby wing Xerun V2.1 120A with a 4.5 reedy motor. Will that work for this class.
bluer322 is offline
Old 01-29-2015, 12:11 PM
  #8559
The motor may struggle a bit. 4x4 SC Trucks are heavy, everyone I know that run them are using 550 motors rather the 540s
Riverbluff is offline
Old 01-29-2015, 12:45 PM
  #8560
bluer322's Avatar
Sorry it's a 1/10 4wd buggy
bluer322 is offline
Old 01-29-2015, 12:46 PM
  #8561
FastPete's Avatar
For a SCT Pro? Should be in the dropdown as a choice.
FastPete is offline
Old 01-29-2015, 02:35 PM
  #8562
hairymuffin's Avatar
Trader Rating: 105 (100%+)
look at the setting #4(drrs) the higher the #, the faster it will respond to throttle input..if the drrs is at 1 or 2,it will give that effect...try 4 or 5..if its still doing it,try another sensor wire,also make sure both ends are plugged all the way in
hairymuffin is offline
Old 01-29-2015, 05:20 PM
  #8563
Trader Rating: 18 (100%+)
Think there must be a new firmware because the one you listed isn't there anymore.I'd have to look at it but the one I installed is 14 something.reckon its the newest anyway.lol
xxxntwv is offline
Old 01-29-2015, 05:22 PM
  #8564
No problem at all with a buggy.
Old 01-29-2015, 05:56 PM
  #8565
idbdoug's Avatar
Trader Rating: 40 (100%+)
Yeah it will work but that's allot of motor, maybe 8.5
idbdoug
idbdoug is offline
