HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 01-24-2015, 01:42 AM
  #8536
No9
No9's Avatar
Trader Rating: 17 (100%+)
Originally Posted by JC_Kustoms_21
I have a Novak Ballistic 8.5t brushless motor and theres something wrong with it. it will start spinning for about 3 seconds and stop then my esc blinks red and I can spin the rotor while I hit the throttle and it will start spinning again im not sure wats wrong didn't know if someone on here could help me with advise please..?
It's the sensor board in the sxx it is a common problem and there is an upgrade board from lrp called the mod/stock upgrade board..Had the same thing happen to mine.
No9 is offline
Old 01-24-2015, 06:44 PM
  #8537
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
I have what I believe to be a common issue with the SCT Pro ESC, running the 4000kv Corr motor sensored, it won't run, red and green led's on ESC come up, sensorless it's fine. Have tried multiple sensor cables short and long. Should I be looking to the esc or motor as a fault? Out of warranty so RMA not an option Real pain at racing Fri night, missed both quals but managed to limp the finals in sensorless mode.
nexxus is offline
Old 01-24-2015, 09:03 PM
  #8538
hairymuffin's Avatar
Trader Rating: 105 (100%+)
my 150a esc stop responding in my 1/8 on 4s,the esc only has 6 batts through it,red light blinks and no power to my servo,rec,transponder..Imsure its the bec..I plugged in rec pack and now the esc and all electronics work..If I get a sepparate bec will this fix my problem? I really dont want to send it in for repair because the DNC IS COMING and I need it for a backup esc..Funny how everyone says the bec is fine in these esc's but yet,some have problems?
hairymuffin is offline
Old 01-24-2015, 11:35 PM
  #8539
Slotmachine's Avatar
Yes an external bec should work for you.http://www.falconsekido.com/products/ubec-10a
Slotmachine is offline
Old 01-26-2015, 10:46 PM
  #8540
I got it to work with a bec..I want to send it in for repair but Not sure on the turn around? I will buy another for a backup for the DNC
Old 01-27-2015, 06:39 PM
  #8541
Trader Rating: 83 (100%+)
I have a HW 3.1 stock spec and when I plug it in the red light flashes on the speedo but I have no throttle. The servo works fine but I can't get the speedo to power off with out un plugging it. Any ideas?
mrhenning11 is offline
Old 01-27-2015, 06:44 PM
  #8542
FastPete's Avatar
Trader Rating: 44 (100%+)
Did you calibrate the end points? Neutral, for, rev? Might want to try it again.
FastPete is offline
Old 01-27-2015, 06:47 PM
  #8543
Thats the problem, I can't do anything. It won't let me calibrate or even turn it off after I power it on. The red light just blinks. I have tried to plug it into the box and plugging it into the pc.
Old 01-27-2015, 08:11 PM
  #8544
idbdoug's Avatar
Trader Rating: 41 (100%+)
Have you tried a different receiver???
idbdoug
idbdoug is offline
Old 01-27-2015, 08:21 PM
  #8545
FastPete's Avatar
I had a customer that had a bad connection to a bullet, to much flux and was acting similar. Check all connections.
FastPete is offline
Old 01-27-2015, 08:56 PM
  #8546
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
I had the same issue with mine. I posted the question a few pages back. I ended up sending it back to HWNA..
I tried to troubleshoot the esc by changing RXs, trying a different ESC RX & Batt connectors, different motor, different Batt, etc. Next time you turn it on spin the rear wheels by hand and then hit the throttle on your radio. If you get throttle then it could be a bad esc capacitor; I didn't try replacing it.
DriveItLikeYSIT is offline
Old 01-28-2015, 02:54 PM
  #8547
Arknabbit's Avatar
I'd like to do some bearing maintenance on my 4700kv. Aside from removing the screws, do the ends pull straight off or is there any kind of twisting involved?
Arknabbit is offline
Old 01-28-2015, 03:16 PM
  #8548
Recently got a HW JustStock club spec speedo with a buggy I got off eBay. Which program box do I need in order to make program changes? Also, the website shows the lowest turn motor to run with it as 11.5. The buggy cam with a HW V10 10.5. Has anyone had experience with pushing the speedo to the lower turn motor.
My guess is the motor and speedo have not been ran together because the speedo doesn't have any battery connections on it and the wires don't look like they have been soldered to anything before. My guess is the guy just installed them to sell the buggy.
Never ran HW before so looking for some input.
Thanks.
Riverbluff is offline
Old 01-28-2015, 05:23 PM
  #8549
lewis110's Avatar
Just pulls straight out. You can also twist then out. Its a smooth bore inside.
lewis110 is offline
Old 01-28-2015, 05:24 PM
  #8550
lewis110's Avatar
Thanks.
You will be good with the 10.5 I wouldn't go any higher then that though for offroad use.
lewis110 is offline
