HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 08-17-2012, 01:18 PM
  #841
midwestcajun's Avatar
Falcon Sediko has an advertised Black XeRun 150a ESC. Is this an older/newer version or what? Haven't seen many of these around.
midwestcajun is offline
Old 08-17-2012, 01:31 PM
  #842
Originally Posted by Tyler Keel
I just got a 150Amp ESC in a trade and it has 10AWG wire on it. I assume this is from the factory, is that ok to run or would someone suggest I switch to 14AWG?
Posted this question a few weeks ago, haven't got any answers. Ran it this past weekend with no problems...just want to know if it's something worth changing.
Larger wires never hurt other than being annoying. If you are running 1/8th scale I would either leave the 10 awg wires on there or change to 12 awg if you need the wires to be more flexible.
kcobra is offline
Old 08-17-2012, 02:39 PM
  #843
SureShotImages's Avatar
Just got my 150a Xerun esc 2 weeks ago, so it's fairly new. Can I run 0 timing and/or 0 punch on it? I heard that may hve some ill effects on the esc.
SureShotImages is offline
Old 08-19-2012, 01:42 PM
  #844
Originally Posted by sffan15
Hi Everyone,
I've been back into RC for about 6 months now, and I'm starting to get competitive. I am also on a slight budget. I have read great things about Hobbywing components so I will purchase a motor soon for my 2WD SCT.
I now have two questions:
1. What is the difference between the same turn EZRUN and XERUN motor?
2. Which turn motor should I chose? (more info on this below)
The first motor I had in my truck was a Castle 1406 5700KV, and it was more power than I could ever use. Even as I get better and better, it's simply too much motor for 2WD. I do, however, enjoy having enough power for any situation. I put a 10.5T Orion motor in my truck, and it isn't enough for me, on the low end or high end (I have it geared well, but the motor is used and *could* be the problem, not sure). Anyhow, I want to have a slight amount of excess power available, for clearing jumps and such, but don't want to go overboard. I've been eyeing the 8.5T, but I don't want to spend the money and end up not having the power I crave.
Any suggestions?
Thanks,
Joey
Could someone please help me out here? Running indoor @ SDRC (medium bite, smooth clay)
sffan15 is offline
Old 08-19-2012, 01:56 PM
  #845
itchy b's Avatar
Just got a sct 120amp speedie and noticed it had a green ring that the esc wire is wound around on its way to the receiver.
Just wondering what this is and if it has to be there?
itchy b is offline
Old 08-19-2012, 02:28 PM
  #846
TCCustoms's Avatar
if you run a 2.4ghz system you can remove it as its something for interference as told by Mr. Josh Pease in an email but here is what he said...
"The green circle piece is to cut out interference. I still run mine but moved it all the way to the end closer to the receiver. "
TCCustoms is offline
Old 08-19-2012, 03:27 PM
  #847
itchy b's Avatar
Cheers
I noticed it on my 1/8th esc too and i guess with the longer length of wire compared to smaller escs maybe it needs it.
I think i shall do the same even though i run the 2.4 radio
itchy b is offline
Old 08-19-2012, 04:56 PM
  #848
TCCustoms's Avatar
right....if i can find mine i might put it back on my SCT Pro but i just thought it was a thing for packaging and took it off but im rebuilding my truck and doin a chassis swap so if im gonna do it nows the time i guess, lol!
Old 08-19-2012, 09:45 PM
  #849
if you can find a way to connect your esc to it with that still installed then keep it on,,otherwise get rid of it. it really serves no purpose...btw...CAN SOMEONE HELP ME WITH MY PREVIOUS QUESTION OR AM I GUNNA BE THE GUINEA PIG ON THE BLACK 150A ESC?
Old 08-19-2012, 10:40 PM
  #850
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Same as the blue just different color.
Blitzrockey is offline
Old 08-20-2012, 02:59 AM
  #851
DJLeonardo's Avatar
I'm sure it is already discussed somewhere in the last 57 pages but still.
I have the blue 150A Xerun and I cannot get it to calibration mode. The (Spektrum) receiver is bound, I have steering but no throttle.
My EPA is at 100%, the Throttle is in REV (why???) and I am holding the set button before switching on the power. It will flash but after the first press on the set key nothin happens anymore.
I have a Castle BEC connected to the setup.
EDIT
Oh facepalm.... I had switched the BEC and ESC wires around in the receiver. It works now.
DJLeonardo is offline
Old 08-20-2012, 03:07 AM
  #852
M7H
M7H's Avatar
And did you try it with throttle in Normal mode?
Why a BEC?
(Hollanders op een buitenlands forum, hahaha)
M7H is offline
Old 08-20-2012, 05:26 AM
  #853
Does anyone run a XERUN motor in their 2WD Short Course on indoor clay (medium-high grip), and mind telling me which turn motor you use?
Is it more than enough power, slightly less than enough power, or just the right amount of power?
I would appreciate this feedback VERY much, as I would like to make a purchase soon.
Joey
sffan15 is offline
Old 08-20-2012, 06:05 AM
  #854
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
the black ESC is just that the 150a in black so you are safe lol
BlackStarRacing is offline
Old 08-20-2012, 01:40 PM
  #855
Thanks.
