HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 01-11-2015, 07:26 AM
  #8446
gotspeed24's Avatar
Trader Rating: 45 (100%+)
Default v3 / v3.1 will not power on
hi guys,
looking for some help here as im completely stumped as to whats going on here.....every esc i have is a HW, and im super anal with my stuff. evenrything neat clean and wired correct
heres my dilemna
I took the same elecs from one buggy that ive been running for a bit and put in another buggy i just built (hw v3, airtronics Rx, Savox 1258 servo, trinity d3 6 turn motor)
I ran the buggy 3 laps the other night at the track and it just shut off, completely powered down, and will not turn back on. obviously nothing got hot, and the esc shows or does not smell burnt by any means.
bought a new v3.1, put it in car. calibrated to radio, etc....ran it on the bench for approx 5 secs.... seemed fine, then cogged a second and shut down.....same sympton as previous . will not power on
i have tried a new battery and nothing.....ive been doing this a while now and have seen sensor boards, servos, rx's go bad, wthout taking the esc with it......looking for some ideas as to what you guys might think is going on here.....sux to have to send in 2 v3 esc;s for repair
thanks in advance
gotspeed24 is offline
Old 01-11-2015, 12:26 PM
  #8447
Originally Posted by bigslashPE
maybe i shouldve asked here. can the Hobbywing 80amp esc handle a 3660 can ,2600kv brushless motor on a 2cell lipo? thanks guys.
anybody? or am i doing something here ?
bigslashPE is offline
Old 01-11-2015, 01:20 PM
  #8448
Slotmachine's Avatar
Originally Posted by gotspeed24
hi guys,
heres my dilemna
thanks in advance
Try a new receiver......
Slotmachine is offline
Old 01-11-2015, 01:32 PM
  #8449
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by ChunkySoup
Hi there,
I am very new to RC Kits and recently built a Tamiya DT-03 Neo Fighter Buggy that is currently running just stock motor and parts. I bought a HobbyWing justock combo over the holidays and it arrived this week. I was in the midst of putting it together but I haven't got a clue as to how to attach the little tiny brass basket type plugs to the wires from the ESC. I also placed a couple on the receiving strip of the motor to see how well they hold and they seem really loose to me.
I apologize if this is a repeat post but I have searched for an hour on here now and have been unable to find out what to do or how to do it.
I am assuming solder is the answer but these baskets fit loose on the wires as well and I don't think solder is going to hold very well. Do I strip back the casing of the wire? Do I solder to the motor as well?
Thanks for any help you can provide.
Chunky
Hi Chunky
Yes you are correct, tin the connector even fill it with some solder, tin the wire and they will fit together nice.
FastPete is offline
Old 01-12-2015, 12:12 AM
  #8450
I have XeRun 120A and using HobbyWing program card - I see that there are 10 pre-program settings 1*modify, 2 zero degree etc etc...
I would like to change some of those pre-program settings on any of the settings. I pick the setting I want and save it but the asterisk doesn't change after saving it.
Using Item to move around - and pressing value to change it then ok to save it.
Please help, I am sure I am doing something silly and overlooking something simple. Thank you for your time.
This is a setup for Team Associated B5M an will be doing "stock" with a 17.5 motor. Thank you thank you thank you.
I4C4LO is offline
Old 01-12-2015, 12:44 AM
  #8451
lewis110's Avatar
The value with the * is the stock setting. So it will always be at that value for reference.
lewis110 is offline
Old 01-12-2015, 04:47 AM
  #8452
Does anybody know if there is a difference between the Hobbywing WP-SC8 ESC and any of the Rebranded WP-SC8 RTR ESC?
CptKlink is offline
Old 01-12-2015, 09:48 AM
  #8453
Lewis110 - thank you.
I4C4LO is offline
Old 01-12-2015, 11:51 AM
  #8454
Potoczak's Avatar
Trader Rating: 120 (100%+)
Is there any compatability issues between the v3.1 120amp and reedy Mach 2 motors ? Just wondering before a solder them up in my buggy.
Potoczak is offline
Old 01-12-2015, 12:08 PM
  #8455
FastPete's Avatar
Not that I can think of as long is its 2 pole.
FastPete is offline
Old 01-12-2015, 05:09 PM
  #8456
Ultraspeed84's Avatar
xerun v3.1 1s can you run this with a 2s with 7.5 modified?
Ultraspeed84 is offline
Old 01-13-2015, 08:25 AM
  #8457
Hey everyone. Just wondering what the big difference is between the v3.1 and v3.1 stock spec esc. Obviously the v3.1 has more amps and bigger burst, but from the website and the spec lists, I could only really see that the v3.1 is heavier. From what I can tell they both have the same preset modes and stuff like that. Is there any benefit of having one over the other? I'm looking to drop one into a 1/10th scale buggy with a schuur speed 17.5 v3 motor.
rcdriv3r is offline
Old 01-13-2015, 09:01 AM
  #8458
FastPete's Avatar
For 17.5 the stock spec is more than enough. The differences are pretty much the motor ratings, the 120A can handle a bit more as in the specs.
FastPete is offline
Old 01-13-2015, 10:33 AM
  #8459
Excellent. Thanks for the quick reply FastPete. Stock spec it is.
rcdriv3r is offline
Old 01-13-2015, 12:04 PM
  #8460
lewis110's Avatar
No, The V3.1 1S is one cell only. DO NOT use it with a 2 cell battery.
lewis110 is offline
