HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 01-07-2015, 03:14 PM
  #8416
Originally Posted by FastPete
SCT Pro uses the fan port also.
Oh ya right, forgot about that one (and the 150A)....I've left the fan unplugged once after using programmer not good to do. Much prefer the onboard dedicated pins
brew99 is offline
Old 01-07-2015, 03:19 PM
  #8417
Exactly the instructions I am following and getting no results.....
KmanM3 is offline
Old 01-07-2015, 03:27 PM
  #8418
COBRARACING's Avatar
reload the software from the usb link cut power after that to the programmer and it will come up
COBRARACING is offline
Old 01-08-2015, 01:09 PM
  #8419
My program box does not have USB capability.
KmanM3 is offline
Old 01-08-2015, 01:21 PM
  #8420
which program box are you using the led version with the red numbers ?
Old 01-08-2015, 02:25 PM
  #8421
This one:
http://www.hobbywing.com/product_show.asp?id=214
KmanM3 is offline
Old 01-08-2015, 04:20 PM
  #8422
Trader Rating: 18 (100%+)
What's the average turnout around for RMA.they shoulve received the ESC today and I'm planning on racing next weekend.
xxxntwv is offline
Old 01-08-2015, 08:17 PM
  #8423
FastPete's Avatar
Trader Rating: 44 (100%+)
I heard as long as you make them aware they always try to accommodate.
FastPete is offline
Old 01-08-2015, 09:53 PM
  #8424
Hi everyone i have a e-revo with a Quicrun burshless esc I can run the car for ten mins after that the red light starts to blinks over and over again and the car wont move need some help
leonlovel59 is offline
Old 01-09-2015, 05:54 AM
  #8425
Slotmachine's Avatar
sounds like your battery is low, when the speedo senses a low battery it shuts down keeping the battery from harm. If you install a fresh battery the truck should run again unless it is going into thermal protection mode. Is the motor or speedo hot after a 10 min. run?
Paul
Slotmachine is offline
Old 01-09-2015, 05:57 AM
  #8426
I have an issue with a relatively new SCT Pro. I had trouble getting it to connect to the programmer. Well I finally figured out that it need to connect to the fan port, and unplug the rx wire from the receiver. I had a brain fart when i tried to check the battery voltage, I still had my rx wire plugged into the programmer, and the battery plugged into the esc. DONT DO THIS PEOPLE. I got it unplugged pretty quickly, but my rx wires from the esc look pretty bad. I cut them at the ESC and replaced them with new wire leads. The ESC seems to work fine until it hits a hard bump or sudden stop, the throttle quits working. Sometimes I can put it in reverse to keep the throttle connected, then flip the throttle a couple times to keep it engaged and not lose signal, but its tough. It doesnt seem very responsive from off throttle either, is this normal?
With all that being said, if i return it, how much would it cost to replace that rx wire? Just trying to figure out whether it needs to go in the garbage.
briarcliff is offline
Old 01-09-2015, 01:11 PM
  #8427
lewis110's Avatar
I believe that program card will only work with a justock in the Xerun series. It also works with the Quicrun and Ezrun speed controls.
When you plug it in. Make sure the metal tabs on the receiver plug are facing up.
This is the program box you will probably want to pickup. Its just all around a better box.
http://www.falconsekido.com/products/lcd-program
lewis110 is offline
Old 01-09-2015, 08:50 PM
  #8428
Vegatron75's Avatar
Will I get a email when my esc is received for RMA? I sent it in a week ago and haven't heard anything.
Vegatron75 is offline
Old 01-09-2015, 09:56 PM
  #8429
timritchieblue's Avatar
I hope you got a tracking #? I just sent mine in, received, and getting service. Did you receive a RMA#, and send in the return form?
timritchieblue is offline
Old 01-10-2015, 09:35 AM
  #8430
Vegatron75's Avatar
I have a tracking number, if i can find the receipt from the post office, and yes I sent in the all the paper work needed. THe process to return is overly complicated.
