HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 08-11-2012, 06:26 PM
  #826
Trader Rating: 88 (100%+)
Default V3 in a TLR 22
So I'm planning on putting a V3 ESC in a TLR 22 buggy, would it be okay to run with the fan off of the ESC? I don't want to burn it up.
tcdrvr2 is offline
Old 08-11-2012, 06:49 PM
  #827
Trader Rating: 41 (100%+)
I'm running a V2.1 and not had a problem with a 13.5 and 17.5 with boost. ESC gets upwards of 120 degrees but that's after a 15 min A-Main in 17.5 boosted.
jdeadman is offline
Old 08-13-2012, 06:53 AM
  #828
Kevin_M's Avatar
I live on east coast is there anyone that sells this systems close by?
Kevin_M is offline
Old 08-13-2012, 07:56 AM
  #829
lewis110's Avatar
WWW.teamcrc.com located in Rome NY
You also have www.falconsekido.com free priority shipping so you will have it in 2-3 days
lewis110 is offline
Old 08-13-2012, 08:26 AM
  #830
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
+100 on FalconSekido..... i live in Florida and couldnt be any happier with their shipping!!!! and the V3 is on sale lol
BlackStarRacing is offline
Old 08-14-2012, 06:59 AM
  #831
Suspended
Default 1/8 buggy xray 808
witch hobbywing should I get 150 amp combo with 2000kv or 150 amp with 2250kv or the sct 120 amp pro esc with witch motor?
belliso is offline
Old 08-14-2012, 10:34 AM
  #832
lewis110's Avatar
What are you putting it in?
lewis110 is offline
Old 08-14-2012, 11:03 AM
  #833
depending on what battery you plan on running and how much space you have to set your esc will make a big difference..
The SCT Pro is a smaller unit then the 150a, you can get both combos sensored as well....if you are going to run 4s i would go with the 150a and the 2000kv depending on how big your track is
Old 08-15-2012, 05:38 AM
  #834
Suspended
Default hobbywing esc/motor/combo
so you think the 150 amp will be better than the 120 amp esc I will be running 4 cells and the 2000 kv will be better than 2250 witch motor will have more speed and run cooler
belliso is offline
Old 08-15-2012, 06:06 AM
  #835
Yes the 150 is an 8th scale ESC while the 120 is a 1/10th
jdeadman is offline
Old 08-15-2012, 09:41 AM
  #836
Default Motor selection help
Hi Everyone,
I've been back into RC for about 6 months now, and I'm starting to get competitive. I am also on a slight budget. I have read great things about Hobbywing components so I will purchase a motor soon for my 2WD SCT.
I now have two questions:
1. What is the difference between the same turn EZRUN and XERUN motor?
2. Which turn motor should I chose? (more info on this below)
The first motor I had in my truck was a Castle 1406 5700KV, and it was more power than I could ever use. Even as I get better and better, it's simply too much motor for 2WD. I do, however, enjoy having enough power for any situation. I put a 10.5T Orion motor in my truck, and it isn't enough for me, on the low end or high end (I have it geared well, but the motor is used and *could* be the problem, not sure). Anyhow, I want to have a slight amount of excess power available, for clearing jumps and such, but don't want to go overboard. I've been eyeing the 8.5T, but I don't want to spend the money and end up not having the power I crave.
Any suggestions?
Thanks,
Joey
sffan15 is offline
Old 08-15-2012, 09:20 PM
  #837
LOSI123's Avatar
Trader Rating: 63 (100%+)
Anyone got any good setups or advise for a Xerun 60amp v2.1 esc with a LRP x12 17.5T 4 dot insert, in a B4.1 buggy running boosted 930 Stock software
Boost settings?
Gear Ratio?
LOSI123 is offline
Old 08-16-2012, 03:57 AM
  #838
Originally Posted by sffan15
Hi Everyone,
Any suggestions?
Thanks,
Joey
If you are running outdoors, 8.5 is plenty, but go indoors with traction, and the 8.5 suddenly feels like a 17.5.
t-man is offline
Old 08-16-2012, 08:13 AM
  #839
Tyler Keel's Avatar
I just got a 150Amp ESC in a trade and it has 10AWG wire on it. I assume this is from the factory, is that ok to run or would someone suggest I switch to 14AWG?
Posted this question a few weeks ago, haven't got any answers. Ran it this past weekend with no problems...just want to know if it's something worth changing.
Tyler Keel is offline
Old 08-16-2012, 12:12 PM
  #840
I'm running indoor on medium bite clay (maybe medium-high, not sure). It isn't super wet. SDRC if you know the track.
Joey
sffan15 is offline
