HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 12-22-2014, 11:51 AM
  #8326
onefast8's Avatar
Trader Rating: 41 (100%+)
Can the Hobbywing v2.1 be setup to run a brushed motor?
onefast8 is offline
Old 12-22-2014, 12:39 PM
  #8327
Slotmachine's Avatar
I dont think so.........
Slotmachine is offline
Old 12-22-2014, 12:52 PM
  #8328
goehm's Avatar
Trader Rating: 45 (100%+)
No, but for brushless you can get a Quicrun 10 for $20.99 from HWNA:
http://www.falconsekido.com/collecti...brushed-system
And check out this little gem under new arrivals - 10% of based on varying levels of purchase:
http://www.falconsekido.com/collections/new-arrivals
goehm is offline
Old 12-22-2014, 01:39 PM
  #8329
Trader Rating: 22 (100%+)
Originally Posted by JFuel11
You will find more smoothness with changing your punch switch. I like to run mine around 65% for the switch rate that way the lower punch rate setting like 10 is used in more of the throttle pull and the higher punch rate later in the throttle pull. Having the punch rate at 40% is most likely causing you to blow through the lower punch rate and right into the 20 setting of your second punch rate...
On a soft setup I like the following settings:
65% - 70% Switch
10 - 15 on Punch Rate 1
20 - 25 on Punch Rate 2
Let me know how this feels.
Good Luck!
Awesome, thanks. I figured it was something to do with these settings but I have had very limited track time to really get to test. I think the next time I will be on the track will actually be in OH for the Midwest Winter Champs. Not exactly low bite, but at least I should have a lot of practice time. Once we get back from Ohio I should be able to get back into a groove of Sat and Sun club races for a few months. Hopefully I'll be able to give you solid feedback.
Bob Barry is offline
Old 12-22-2014, 01:46 PM
  #8330
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default This is what I like to do...
I like to set up 3 or 4 profiles on the esc each with different punch settings from 65% 5/15 to 65% 30/30 and then I can switch between profiles trackside with the programmer very quick and easy to test which setup I like best. In doing so you are overwriting some of the default profiles but you can always restore those if you needed to.
Hope this helps and good luck.
Alan
JFuel11 is offline
Old 12-22-2014, 05:22 PM
  #8331
Trader Rating: 18 (100%+)
Anyone have experience with the extreme stock? Need a inexpensive 17.5 blinky ESC
joedeman1969 is offline
Old 12-23-2014, 12:53 AM
  #8332
Trader Rating: 83 (100%+)
I have one and like it quite a bit. I do have to say that the JustStock esc is a little lighter and comes with 14g wire so you save a little weight. Performance wise I don't notice much of a difference.
dpcardoza is offline
Old 12-23-2014, 04:06 AM
  #8333
I know you will like it, everyone I talked to that has one is very happy. Guys at my local track are running lower wind motors so you should have no issue's, it should be great with 17.5. If you need help we are always here.....
Paul
Old 12-23-2014, 06:59 AM
  #8334
Default Hobbywing/Neewer program card
I didn't get this answered in a different forum so I'll try here. I bought the Neewer ESC and 550 sensorless motor combo a month ago.*
My question is.....can the hobbywing version 2 program card be used for setting up this system? Or do I have to buy a Neewer-specific setup?
ob1n is offline
Old 12-23-2014, 07:20 AM
  #8335
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
I moved this thread into this thread with the goal of someone here being able to help this gentlemen out with his question.
Kraig is offline
Old 12-23-2014, 07:32 AM
  #8336
FastPete's Avatar
Trader Rating: 44 (100%+)
It does work great I personally used it also.
FastPete is offline
Old 12-23-2014, 08:04 AM
  #8337
JFuel11's Avatar
Default They are both great ESCs...
The Extreme stock and Justock ESCs are hands down the best you can get for the money spent in my mind.
The Extreme stock has the ability to adjust profiles with timing advance if you would want to do a non-blinky setup in addition to the blinky profile.
The Justock does not have the ability to do timing advance, but is very light weight. If you are looking for a 17.5 esc only for blinky class, the justock can not be beat!
Alan
JFuel11 is offline
Old 12-23-2014, 11:33 AM
  #8338
Tracy B's Avatar
Alan
I run 2 Justocks, one in my SK Spec (17.5 with 1S) and one in my pancar (also 17.5 with a 1S).
Tracy B is offline
Old 12-23-2014, 09:05 PM
  #8339
I believe it can be used for that.......
Old 12-24-2014, 08:36 AM
  #8340
Well I got the oportunity to help out a new Hobbywing user last night. He was quite upset and ready to give up when I arrived. I first asked him if his battery was fully charged he said yes. His truck was shutting off after the straight and would go again after sitting for a few seconds.We even switched his speed control for one of my new units and still the same thing. I finally said , are you sure your battery is charged? We checked it and it was dead. We now have another satisfied customer.
Paul
