HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 12-11-2014, 09:18 AM
  #8281
simplechamp's Avatar
Trader Rating: 73 (100%+)
Got a question about running the 120A v3.1 with 4-pole motors.
I just built a 22SCT 2.0 with Tekin Pro2 4-pole motor. I notice when I hook up the program box to read the stored temp/voltage/RPM info that the RPM is showing approximately double what it should be. I am guessing this is because the ESC is expecting a 2-pole motor, and when used with a 4-pole each revolution registers as 2 in the ESC.
My question is, will this screw up my boost and turbo? For example if the boost range is set at 6000RPM-20000RPM then when using a 4-pole motor will it actually be occurring at 3000RPM-10000RPM? Same goes for turbo, if it's set to kick in at 30000RPM then with a 4-pole will it kick in at 15000RPM?
Thank you in advance for any help.
simplechamp is offline
Old 12-11-2014, 09:44 AM
  #8282
Trader Rating: 28 (100%+)
Running a tlr22 SCT 2.0. w/ HW XERUN 3.120a Blinky
Where shoud I start the drag brake for 17.5?
Also for a mild Mod (8.5-10.5)?
impson is offline
Old 12-11-2014, 11:48 AM
  #8283
Slotmachine's Avatar
Hobbywing has mentioned several times here
On the forum that they dont condone the use of 4pole motors with that unit. Reason being is it stays on sensored mode throughout the whole throttle range and the high RPM's confuse the sensor at full throttle.
Slotmachine is offline
Old 12-11-2014, 12:13 PM
  #8284
Well that stinks. Guess that's what I get for buying first and asking questions later. I'm going to try it out at least with boost/turbo disabled and see how it runs. It's super smooth and didn't seem to have any issues at full throttle, but that was only on the bench.
Old 12-11-2014, 01:03 PM
  #8285
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Drag Brake
I find 5% to 10% is a good starting point all around. I personally don't use much more than 10% in most situation.
Good Luck
JFuel11 is offline
Old 12-11-2014, 10:29 PM
  #8286
onekiwi's Avatar
Can we get a post at the start of the thread with info like that? (like what a few buggy threads have)
With pics links sw updates hints tips gearing recommend starting points etc?
onekiwi is offline
Old 12-12-2014, 05:19 AM
  #8287
Can someone tell me what the difference is between the XERUN 3.0 and 3.1?
Can the 3.0 be upgraded to match?
impson is offline
Old 12-12-2014, 09:31 AM
  #8288
RcRacer37E is offline
Old 12-12-2014, 11:03 AM
  #8289
Cobra has to do that, he's the only one that can edit the first post.
Old 12-12-2014, 12:01 PM
  #8290
lewis110's Avatar
They both have the same internals. The only difference is the following upgrades on the V3.1... Heat sink is 1mm taller for better cooling, All aluminum case (v3 has a plastic lower half) and it not has silicone seals arounf the sensorport and programing ports for better dust proofing.
lewis110 is offline
Old 12-13-2014, 12:36 AM
  #8291
Default Pre Programmed Setting for Stock 10.5
My 7.5 has to go for service so had to install a 10.5 into my sct. Boost was set at 20 degrees with some turbo included as well. Motor behaved like my 7.5 with no heat probs whatsoever. Increased boost to 30 and eliminated turbo. Glad I picked up a stock spec now that I have discovered some of its benefits.
Micah123 is offline
Old 12-14-2014, 04:57 PM
  #8292
I recently installed the SCT-PRO-C1 81040250 (Black) in my SCTE. Running SMC 7500 mah batts, initially with my Lvc set to 3.2 it would cut after about 4 min on the track and the Batt would be at 3.8v per cell. I set the LVC to "none" after trying multiple settings with no success. Now comes off the track after a 7 min Qual and the batt is at 3.5. Life is good. However now that I am running a full race I am having trouble with the motor wires. Every other race my "A" terminal wire comes unsoldered. I have checked the motor temp and have never seen it over 130 degrees F. It's always the same wire. I have now re-soldered it 5 times. I'm running 13, 40 gears and there is no extra drag on anything. When running the truck is fast and smooth but this is annoying to the point I'm ready to drop the coin on a Tekin setup like everyone else is running.
SCTError is offline
Old 12-14-2014, 05:02 PM
  #8293
I recently installed the SCT-PRO-C1 81040250 (Black) in my SCTE. Running SC 7 500 ah batts, initially with my Lvc set to 3.2 it would cut after about 4 mind on the track and the Batt would be at 3.8various per cell. I set the LVC to "none" after trying multiple setting with no success. Now comes off the track after a 7 min Qual and the batt is at 3.5. Life is good. However now that I am running a full race I am having trouble with the motor wires. Ever yo the race my "A" terminal wire comes unsoldered. I have checked the motor temp and have never seen it over 130 degrees F. It's always the same wire. I have now re-soldered it 5 times. I'm running 13, 40 gears and there is no extra drag on anything. When running the truck is fast and smooth but this is annoying to the point I'm ready to drop the coin on a Tekin setup like everyone else is running.
SCTError is offline
Old 12-14-2014, 05:50 PM
  #8294
You never mentioned what motor you run.I run the 4000kv with a 16 pinion 100ft straight and never see heat above 130 in my 7lb. Tekno. I can hold my hand on the motor after 8 minutes. I run 8 punch and 7 timing too.
Paul
Old 12-15-2014, 12:06 PM
  #8295
Paul
I'm running the XERUN 3656SD 4700kv motor, I purchased this as a combo, running a 13 tooth pinion and a 40 tooth spur. 130 to me is not hot enough for the wire to come un-soldered. so for some reason it seems only that one terminal is getting hot. The solder does not look broken when this happens the terminal solder is smooth and clean just like I heated it up with an iron and removed the wire. Power is always good then just stops when the wire comes unsoldered. there is never any indication of a problem leading up to this. I have turned the punch down to 2 and timing is at 5.
SCTError is offline
