HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#8253
I have the EZRUN Combo B8 with the following problems the developed after a few months of use.
1. Reverse stopped working (yes, I checked the setup to ensure it was enabled).
2. When I release the throttle, the motor keeps running. The motor only stopps when I apply the brake. Works much like cruise control.
I have re-set multiple times neutral, full throttle, full brake according to the set-up instructions and the lights on the ESC blink with each setting properly.
#8255
#8256
The way power comes on is different between the 2.1 and 3.1 and so are the brakes.
Just installed my 3.1 last week and I was 1 second faster right out of the box.
The brakes on the 3.1 took some getting used to and I am still undecided if if the 2.1 was better on braking
By the end of Friday night I was plenty comfortable with the brakes on my new 3.1 and laying down faster more consistent times than I had been with my old setup.
Is it a wow type of difference? Not at All. I had to look at the score screen to see. I was able to qualify in front of a few guys I have been chasing for months.
Is it worth $100 more? That Depends I sure did feel good walking out Friday Night knowing I out qualified those guys
#8257
Ran my sct-pro/ 4700 setups in my scte 2.0 and 1/8 buggy for the first time over the weekend. WOW i was really impressed with how smooth they where. I was way out front in my first heats and had battery go dead in both races. After some program changes won both my second heats. Tq'ed sc and 4th in buggy, won sc main and 3rd in buggy main. Very happy with switching for the junk tekin stuff.
#8258
Obvious things to try are new fan, but honestly, you should not need a fan with this ESC even runing on carpet in a 2wd buggy. I think you might have a couple blown FETS which are causing this high ESC temps, or you are entirely geared wrong.
#8259
Yes, the fan shuts off at some point during the run. When we get back on the bench the fan is off. If we shut the esc off and right back on the fan will restart.
The gearing is 18/82.
#8260
#8261
Do you have the ESC overtemp set at 105 by any chance?
Have you ever reversed the battery polarity by accident, blowing the little diode that is in the capacitor pack? I did this and replaced the capacitor pack, but the ESC seemed to run a much higher temp after that, so obviously it also effected the FETS in the ESc also.
#8262
I wanted to post my current 2wd Mod Buggy ESC Settings as I have had a lot of messages on setups again lately and want to help. I will be posting more as I have time to do so. The setup sheet I am posting is actually screen shots directly from the software on the PC and offers explanation of why I make the changes that I do to help others with why they should make these changes and when they should make these changes.
I hope this helps and feel free to message me with questions.
Alan Bachman - Mod 2wd Buggy - Hobbywing V3.1 ESC Setup - 12-09-2014.pdf
Alan
Alan
#8263
Attachment 1254176
Alan
Attachment 1254176
Alan
#8264
Hey guys, i noticed with some of the big racers that use Orion sec's you know the cousin of our favorite sec's lol...... well i noticed for mod racing none of them are using turbo or boost is there anyone running mod 2wd or 4wd 10 scale not using turbo or boost as well?
#8265
