HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#8236
I have a customer's v3.1 1S in hand, hooked it up to the multi function program box, and all I get is a green flashing light with a beep - beep sound. It will not connect to the multi function program box.
What can I do to fix this for the customer??
Could I someone to PM me about this issue so we can chat and try and get the issue resolved for the customer.
#8237
I have not heard of such a thing. Usually if it won't connect you just get the connecting ESC displayed on the LCD box. Did you try with both a 1 cell and a 2 cell? Like I said before last years model needed w 2 cell to power the program box.
#8238
Paul
#8239
#8240
Will it connect to the PC program? I would assume no. But its worth a try. Get ahold of Angelo at [email protected]
Thank You for Angelo's email, I will be emailing him.
#8242
It's like running a Justock against a Tekin RS Gen2 SPEC (which is permanently set to blinky mode), it comes down to car setup.
#8243
I have a HW V3/3.1 and the fan will turn on upon start up but shut off during a run. I see no info in the manual. I am using 2s lipo in a 2w buggy. The temp is reading 105 deg C on carpet.
#8244
I have the EZRUN Combo B8 with the following problems the developed after a few months of use.
1. Reverse stopped working (yes, I checked the setup to ensure it was enabled).
2. When I release the throttle, the motor keeps running. The motor only stopps when I apply the brake. Works much like cruise control.
I have re-set multiple times neutral, full throttle, full brake according to the set-up instructions and the lights on the ESC blink with each setting properly.
#8245
#8246
I have just bought a xerun 150A 1800kv combo for my eb48.2 during Black Friday. I installed it and plugged in a new 4s battery and did the radio setup per the instructions. When done the motor just clicks and when pull the trigger I hear the fan slow way down and within 30 seconds the motor and esc are very hot! I never let it get over 150 deg though. Any ideas what is happening? Any help is appreciated. And before anybody asks, yes all the wiring was triple checked and correct
#8248
#8249
The motor spins freely and there's no binding, wires are in the correct color coded place, I'm at a loss, I'm suspecting this is a defective kit, but want to rule everything out before shipping back
#8250
