HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 08-06-2012, 06:23 AM
  #811
DJ_KILROY's Avatar
Originally Posted by Overtorqued
Thanks very much for your input. I had considered this before. The only soldering I did was putting a TRX battery connector on (I'm confident that those joints are good...years of experience with soldering). The battery and motor wires came already soldered onto the ESC with heatshrink over the joints. And, the motor wires had bullet connectors already in place.
With issues like this I will usually start pulling things apart to find the problem, but I didn't want to go and cut their heat shrink off to inspect the solder joints...I figured if I did that and that didn't turn out to be the problem, I might be without any warranty at all.
Anyway, I got an RMA from HobbyPartz where I bought it and it's going back to them today.
Thats a win, win if you get a new one under warranty. I hope it all works out.
Cheers
DJ_KILROY is offline
Old 08-06-2012, 05:40 PM
  #812
GSM Storm's Avatar
Trader Rating: 114 (100%+)
Hi all
looking for a starting setup for a V3 speedy using a 6.5 turn motor in a 4WD offroad buggy.
Regards
Gary
GSM Storm is offline
Old 08-06-2012, 05:44 PM
  #813
seth556's Avatar
Trader Rating: 43 (100%+)
Need help with a 120a V2.1 esc, after calibration it goes full throttle and doesn't respond to transmitter inputs with a DX3r radio. I saw someone else had similar problems and fixed it by increasing the dead band to 12% but that had no change for me. I started to think it was just a bad esc but I plugged it into a Futaba radio and it worked perfectly. Tried turning the EPA up and down on the throttle with no luck. I need some more ideas.
seth556 is offline
Old 08-06-2012, 09:16 PM
  #814
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Originally Posted by GSM Storm
Hi all
Regards
Gary
I'm in the middle of testing mine at the moment. But with a 6.5 I would try it on no boost and no Turbo first. Set up your neutral percent and brakes etc. Then try that. Let me know what u think and I can give some suggestions from there.
Blitzrockey is offline
Old 08-10-2012, 10:58 AM
  #815
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
hey guys need a little training on boost and timing on a Extreme Stock ESC im rinning in my losi 22 buggy.....Is there anyone using one on a 10th scale off road buggy? Oh im using a 13.5t motor....
Thanks for any input!!!
BlackStarRacing is offline
Old 08-10-2012, 11:24 AM
  #816
I use a xerun 60amp with a 8.5 in my 2wd buggy. What are you trying to do with the buggy? More speed? More accel? Lemme know and I will try to help ya the best I can.
Old 08-10-2012, 11:56 AM
  #817
i need to just figure how each setting effects the motor... how to adjust the settings to make them best for off road? i would like a bit more speed but also the ability to clear triples...lol
Old 08-10-2012, 03:32 PM
  #818
lewis110's Avatar
I highly recommend updating the hobbywing pc program to the 3.1 version. Angelo posted the link on the hobbywing thread in the on road section. It has a nice explanation what each does right on the right side of the page when updating.
I run the 930 stock filmware on a 60amp esc. 13.5 motor. Geared 22/88, 35 degree boost, if you need more top end use a few degree of turbo. Start boost at 3000 rpm
lewis110 is offline
Old 08-10-2012, 03:46 PM
  #819
lewis110's Avatar
Here is the link to the new v3.1 pc program
http://www.hobbywing.com/product_show.asp?id=218
lewis110 is offline
Old 08-10-2012, 04:24 PM
  #820
With a 13.5 I would probably start with 20degrees boost timing starting at about 8000k rpm. I ushualy dont recomend turbo for offroad as it can upset the car when it kicks in. The boost timing is dynamic so it ramps up with throttle speed so its nice and smooth but still get you your speed.
Try those settings and temp it after 5 min and see where its at.
Old 08-10-2012, 04:27 PM
  #821
i will try the download i have the LED program box so ill go to the website! Thanks!!
Ok im going to change the programing on the esc....do you think i should update the firmware to 3.1?
Old 08-10-2012, 04:31 PM
  #822
lewis110's Avatar
Have you upgraded the filmware? If your using the led (ezrun) program box the numbers don't match up with the led box. That will just confuse you. Also you need the lcd program box to hook up to the computer.
lewis110 is offline
Old 08-10-2012, 06:01 PM
  #823
No I haven't plugged it up yet I have with my sct pro...... But I will tonight
Old 08-11-2012, 12:12 PM
  #824
I have been running the SCT pro esc and a Tekin SC4x 4.5T for a few months now, racing. I experience similar issues as others with the delay of full throttle, which I have just gotten used to, as I have tried everything to eliminate it.
Is this motor compatible with my esc? It seems incredibly slow, in fact, one of the slowest trucks on the track on a straight. I have this setup installed in a SCTE, using Turnigy 5.8 2S, with a 14 pinion, temps get upwards of 170, esc will never go above 105.
From what understand, this motor should really scream.
TintJunkie is offline
Old 08-11-2012, 02:45 PM
  #825
lewis110's Avatar
Your problem is the Tekin! Lol
I don't have any delay with mine but I'm using a hobbywing 4000kv motor. I also don't use any drag brake.
lewis110 is offline
