HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 11-27-2014, 12:18 PM
  #8176
jhautz's Avatar
Trader Rating: 86 (100%+)
Is anyone using the v3.1 stock spec esc in a 4wd buggy with success? Jut wondering if this esc has the stones to be able to handle an application like this I am wanting to try it with a 7.5 motor.
Side note.... Why do they call this esc "Stock Spec" when it has all of the timing options of the regular v3.1.The only difference I can see is its rated for 100amp vs 120amp and that is probably just because it is a plastic case instead of the full heat sink aluminum case. I dont know this for a fact by Id bet it has the same guts as the v3.1, just less cooling.
Really it should just be called the v3.1 100amp esc or v3.1 "lite" esc. Stock Spec really has no more to do with this esc than it does on the regular v3.1.
jhautz is offline
Old 11-27-2014, 01:07 PM
  #8177
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
^^ I agree; the specs are almost identical..I'm using the v3.1 stock spec ESC in a MOD Sct with a 7.5t or 8.5t motor. I have not had an issue with the stock spec esc and used the money I saved to buy a shorty pack
DriveItLikeYSIT is offline
Old 11-27-2014, 01:32 PM
  #8178
Originally Posted by BlackStarRacing
quick question: i just upgraded my HW software to the 3.4 and also updated my esc when i noticed the sub settings for boost are gone... was this done on purpose? or am i doing something wrong?
That is normal on the newest beta firmware. Boost is still there, just not all the sub-settings of boost. I'm not sure why they took it out, and I'm assuming this is on a v3.1 esc you are talking about.
brew99 is offline
Old 11-27-2014, 01:35 PM
  #8179
Originally Posted by DriveItLikeYSIT
^^ I agree; the specs are almost identical..I'm using the v3.1 stock spec ESC in a MOD Sct with a 7.5t or 8.5t motors. I have not had an issue and I used the money I saved on a shorty pack
Are you using the fan when running the SCT with 7.5 or 8.5t motor? I have been running the 120A 3.1 without the fan in a similar vehicle set-up, and was wondering if the stock spec one would need it or not? I always check temps anyhow, just curious that's all
brew99 is offline
Old 11-27-2014, 01:44 PM
  #8180
I don't use a fan on with v3.1 stock spec esc and a 17.5t stock motor but I do use a fan with the stock spec and a MOD motor. A fan is recommended with MOD motors but prob doesn't need it. I also didn't wanna take a chance with the esc overheating while racing in the FL heat.
Old 11-27-2014, 02:50 PM
  #8181
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Yeah i upgraded my box as well as both my esc's i have the v3.1 sand the v3.1 stock so both have lost the sub-sections of boost... Im wondering why they did that as well...
If anyone knows why HW removed those settings please let us know?
BlackStarRacing is offline
Old 11-27-2014, 04:04 PM
  #8182
COBRARACING's Avatar
its just to make the software easier to use by not removing boost start rpm but making it automatic ramp up it also reduces some esc and motor temp.You dont have to use it just run 129 or 526 Andy moore likes running 526 its all up to you guys it was just an extra option to make it easier for the new comers.
COBRARACING is offline
Old 11-27-2014, 05:17 PM
  #8183
FastPete's Avatar
Trader Rating: 44 (100%+)
I run a 120A V3.1 in my DEX410, transferred it from another car. I would run the stock spec no problem.
FastPete is offline
Old 11-27-2014, 06:14 PM
  #8184
Got it, ill see how i like it at the track this weekend... thanks for the great answer!
Old 11-27-2014, 06:26 PM
  #8185
Slotmachine's Avatar
+1 and remember to visit FalconSEKIDO for the black Friday sale........
Slotmachine is offline
Old 11-27-2014, 08:48 PM
  #8186
Trader Rating: 83 (100%+)
What is the usable turn limit for motors with the justock esc with the fan? I think it lists greater than 11.5 but was curious if anyone has run a 10.5 or even 8.5? Running a 2wd buggy for reference
dpcardoza is offline
Old 11-27-2014, 08:55 PM
  #8187
1/4milecrazy's Avatar
Off road, 2WD the instructions say 11.5, 8.5 for on road on 2s. For 3s, 17.5 off road and 13.5 off road. I have heard about people running lower than that on 2s with no problems, and seen one guy running a 10.5 with no problems but I wouldn't suggest going below 11.5 off road if that is what the instructions say.
1/4milecrazy is offline
Old 11-28-2014, 08:22 AM
  #8188
idbdoug's Avatar
Trader Rating: 41 (100%+)
For an 1/8th Ebuggy, do I want the Xerun 4274SD sensored or 4168SD?
Both near 1800KV and sensored
idbdoug
idbdoug is offline
Old 11-28-2014, 10:16 AM
  #8189
FastPete's Avatar
idbdoug
4274 is what I run love it.
FastPete is offline
Old 11-28-2014, 11:20 AM
  #8190
idbdoug
4274SD 1800kv is my preference...
offroadlover is offline
