HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 11-18-2014, 01:20 PM
  #8101
azeroth's Avatar
Trader Rating: 21 (100%+)
hey fast Pete I am gonna bring this over to you maybe you can figure it out your only a hour away
azeroth is offline
Old 11-18-2014, 01:36 PM
  #8102
FastPete's Avatar
Trader Rating: 44 (100%+)
Sounds good will try to see whats going on.
FastPete is offline
Old 11-18-2014, 03:42 PM
  #8103
advpball's Avatar
Trader Rating: 30 (100%+)
I got used extreme stock on here and i goto plug in battery and get arching?
Should i send in or not worth sending in? Maybe deal was to good?lol
advpball is offline
Old 11-18-2014, 04:25 PM
  #8104
hesh's Avatar
Originally Posted by Jake S
i see "V3.0_110930_MOD" but thats alittle old. any help would be good, also where to download the firmware, or is it just through the software.
Best to only download firmware through the software unless you are well versed in writing it. That version sounds about right for the 1s version, not sure on the 2s one.
hesh is offline
Old 11-18-2014, 06:08 PM
  #8105
FastPete's Avatar
Does it work ok? My SCT Pro does that for 2 years now works great!
FastPete is offline
Old 11-18-2014, 06:21 PM
  #8106
Trader Rating: 18 (100%+)
What is the major differences between the 2.1 and 3.1 120a ESC.the 2.1 can be had pretty cheap.also would the stock spec 3.1 be OK to use in mod 2wd buggy.thanks
xxxntwv is offline
Old 11-18-2014, 06:24 PM
  #8107
nitro_mt_racer's Avatar
Trader Rating: 238 (100%+)
The spark comes from the caps on the esc. If you plug the battery in with the switch off you shouldn't get that.
nitro_mt_racer is offline
Old 11-19-2014, 05:03 AM
  #8108
thekisscutken1's Avatar
Trader Rating: 46 (100%+)
anyone know if a ezrun wp sc8 esc will work good with a v10 8.5t motor in a 2wd buggy? i noticed both the v3.1 and the sc8 esc's are 120 amps constant and 760 burst. also would the 4600kv motor with the wp sc8 speedo work ok in 2wd buggy. may be in a bind and need to borrow something for a race this weeekend.
thekisscutken1 is offline
Old 11-19-2014, 03:54 PM
  #8109
advpball's Avatar
thanks guys ill try that.
advpball is offline
Old 11-19-2014, 04:03 PM
  #8110
Tech Legend
Cain's Avatar
Trader Rating: 293 (100%+)
for the hobbywing 3656SD, is it classified as a "550" motor officially, or like Trinity's Zombie, a "545" motor?
Note: I know its in between the size of the 540 and 550 common lot of motors, but curious what Hobbywing is officially classifying it as.
Cain is offline
Old 11-20-2014, 04:54 AM
  #8111
lewis110's Avatar
Pretty sure its considered just a 540 motor.
lewis110 is offline
Old 11-20-2014, 06:50 AM
  #8112
Tech Legend
Cain's Avatar
had a pretty good "debate" with someone concerning its classification, so curious what hobbywing's official position on it is.
Cain is offline
Old 11-20-2014, 08:32 AM
  #8113
AlanHall's Avatar
Trader Rating: 43 (100%+)
the arc when you connect is very normal for alot of electronics. you probably dont notice it much . real car batteries do it whenyou change it . when hooking up car audio the amps do it.
theres nothing wrong with the esc/battery
AlanHall is offline
Old 11-20-2014, 08:37 AM
  #8114
FastPete's Avatar
I agree, mine spark all the time, switch off, two years going strong!
FastPete is offline
Old 11-20-2014, 09:03 AM
  #8115
AlanHall's Avatar
Yeah The caps are still in the circuit even with the switch off.
AlanHall is offline
