HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 11-17-2014, 03:25 PM
  #8086
Slotmachine's Avatar
Originally Posted by Leealan525
Can someone please help. I have the 150A Esc with the 2250 KV motor for 1/8th scale ebuggy. I am running a 4s lipo. The other day while at a race about 5 laps into my first run. the car stopped moving everything powers up fine now but when I apply throttle the motor will not move but the wires connecting the esc and motor physically move. The motor will turn freely by hand but will not move when throttle is applied.
Check your sensor wire and make sure your motor wires are plugged in correctly.
Paul
Slotmachine is offline
Old 11-17-2014, 03:42 PM
  #8087
Leealan525's Avatar
Originally Posted by FastPete
Just to follow you, it wont move even after it cools down?
That is Correct
Leealan525 is offline
Old 11-17-2014, 04:24 PM
  #8088
cttech455's Avatar
Originally Posted by Slotmachine
Yes you need to hook up to your pc and update your card........
Paul
Thanks for the help. That did it, though I'm still going to get the multi function box as it seems my 2 and 1 programmer can only save one type of software at a time and I run both the V3 and SCT Pro in my vehicles.
cttech455 is offline
Old 11-17-2014, 04:49 PM
  #8089
vivi_gao's Avatar
V10?but i know the x211 is too
vivi_gao is offline
Old 11-17-2014, 05:52 PM
  #8090
Jake S's Avatar
Trader Rating: 67 (93%+)
Originally Posted by Jake S
what is the most updated mod fireware for the v2.1 120a esc?
i see "V3.0_110930_MOD" but thats alittle old. any help would be good, also where to download the firmware, or is it just through the software.
Jake S is offline
Old 11-17-2014, 08:18 PM
  #8091
thekisscutken1's Avatar
Trader Rating: 46 (100%+)
i just got a new 3.1 120amp and v10 8.5 combo. can't get the esc to link to program card or computer. also it wont calibrate if i hold down power button at startup. never gives me a flashing light. esc only will power the steering servo and let car steer. program card version is 1.17_140315. also sensor wired is plugged in and motor wires and soldered in correct order.
Also im not sure if my m11x has an abs function
thekisscutken1 is offline
Old 11-18-2014, 05:49 AM
  #8092
Try creating a new model on your radio and re-bind your receiver before trying to calibrate the speed control.
Paul
Old 11-18-2014, 06:47 AM
  #8093
I did create a new model as well. Bound it up and steering works fine. Holding down power button and never get any flashing. Weird that it wont connect to program card or computer software either
Old 11-18-2014, 10:33 AM
  #8094
Trader Rating: 83 (100%+)
Are you by any chance running an external bec? If so make sure you hold down the power button before booking up the battery.
dpcardoza is offline
Old 11-18-2014, 11:25 AM
  #8095
cnelson3's Avatar
Trader Rating: 66 (100%+)
Can someone explain a little bit about the difference in turbo and boost. I've heard explainations before but I've conflicting different things.
cnelson3 is offline
Old 11-18-2014, 11:37 AM
  #8096
any known issues with the v3.1 unit and program card firmware 1.17_140315? seems after i updated the card, i had issues with the esc connecting and binding
Old 11-18-2014, 01:45 PM
  #8097
azeroth's Avatar
Trader Rating: 21 (100%+)
ok i have no clue what is going on here with this esc pull trigger rolls about 10 feet slow and then off like a rocker back off back in slow then off like a rocket then slow then nothing let off and she will go again. pull the trigger car in air acts just like a nitro speed changed receiver recalibrated again new model from scratch on radio i guess a send back is in order
azeroth is offline
Old 11-18-2014, 01:58 PM
  #8098
FastPete's Avatar
Trader Rating: 44 (100%+)
If you were alittle closer I would tell you to bring it over.
FastPete is offline
Old 11-18-2014, 02:00 PM
  #8099
rcboy1's Avatar
Are you plugging the esc lead into the program box, or using the extension from the esc's fan plugin to the box? that may solve the programming issue.
rcboy1 is offline
Old 11-18-2014, 02:02 PM
  #8100
rcboy1's Avatar
What are your esc settings at?
rcboy1 is offline
