HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 08-03-2012, 03:54 PM
  #796
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Originally Posted by BlackStarRacing
hey guys im going to throw a extreme stock on my losi 22 buggy do i need to run the fan?
You shouldnt have to I run a 60amp xerun in my 2wd buggy without a fan and it never gets that hot. Check it though after 4 min and see what it temps at.
Blitzrockey is offline
Old 08-03-2012, 04:07 PM
  #797
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Sweet just got it in from falcon sekido....
BlackStarRacing is offline
Old 08-03-2012, 05:59 PM
  #798
Kevin_M's Avatar
Where is best place to buy the sct pro esc?
Kevin_M is offline
Old 08-03-2012, 07:22 PM
  #799
Falcon sekido
they have some awsome deals rite now also.
Old 08-03-2012, 08:01 PM
  #800
Trader Rating: 22 (100%+)
Originally Posted by lewis110
Just to clarify you are plugging just the program box in and reflashing just the box?
Yes, just the box is hooked up to the computer. But, today I tried it on my other computer and sure enough it took the firmware the first time and the blocks on the lcd are gone. I have not tried it on an esc yet but it appears to be fine again. Really frustrating. I actually took that esc out of the car and put a different brand in just so that I could test the car out today.
Troy Carter is offline
  #801
With the SCTE I'm selling....
Old 08-03-2012, 11:21 PM
  #802
What combo do you guys recommend for a Mugen MBX6 ECO?
Tigergutt is offline
Old 08-04-2012, 01:21 AM
  #803
hyper9boy's Avatar
80-150amp doesn't matter whick one
Same as the motor 2250kv or 2000kv
14th pinion happy days
14.8volts
hyper9boy is offline
Old 08-04-2012, 01:40 AM
  #804
14.8volts
Old 08-05-2012, 11:17 AM
  #805
Default 17.5 justock timing?
Does anybody know if it possible to change timing on the can of the hobbywing 17.5 justock motor.
02rdking is offline
Old 08-05-2012, 12:24 PM
  #806
Nope its locked
Old 08-05-2012, 06:45 PM
  #807
Nope its locked
Thanks, that's what I was afraid of.
02rdking is offline
Old 08-06-2012, 02:09 AM
  #808
Big Lee's Avatar
Default v2.1 vs v3
The extra price of the V3 120 AMP is the price of another motor ($70) compared to a V2.1. But I think the extra telemetry and data recording is worth it. Some opinions on this!! (already got a speed passion 6.5T, don't need an extra motor, but a 5.5T combo would be the other option to getting the V3.)
Big Lee is offline
Old 08-06-2012, 05:45 AM
  #809
DJ_KILROY's Avatar
Originally Posted by Overtorqued
I posted in a different thread but it looks like this may have been the right one...
This evening I ran my brand new HW ESC for the first time. This is an XERUN 150amp ESC on 4s. I ran for about 4 or 5 minutes on the track, then I just lost throttle completely like it hit the voltage cut. Turns out, it wasn't the low voltage cut though.
I tried two freshly charged batteries, and had no throttle. Just a blinking red LED on the ESC at first. I checked all my tx settings, checked throttle signal, checked wiring, checked ESC settings..all good. Eventually, the blinking went away and I just had a solid red LED on the ESC. After that, I found that the motor would run, seemingly fine, until I let off the throttle and let it stop. At this point, there would be no LED lit on the ESC. Then when I pulled the trigger, it would not run the motor again and the solid red LED came back on. I was able to 'push start' the car, then it would run fine again.
This was pretty repeatable. Push start, run fine, stop, no throttle response. Push start, and repeat. This was all with a Tacon 2000kv 1/8 motor by the way, in an RC8.2e with stock spur and 18t pinion. After the first run, the motor and ESC temps were reasonable...I forgot my temp gun at home but I could easily hold my fingers on either indefinitely. When I got home, I tried a Castle motor to see if the problem would persist, and it did. So the problem is definitely with the ESC I think.
Any ideas? If it's bad, what's the best way to get it replaced?
I had exactly the same problem on a sensored speed passion speed control. At first I though it was the sensor wire, but it turned out one of the motor wires was loose at the speed control end.. During the trouble shooting process, I pulled my motor apart and after all the movement of the wires, the bad one fell off..
Long story short, check all of your soldering and you will fix the problem.
Cheers
Kilroy
DJ_KILROY is offline
Old 08-06-2012, 06:05 AM
  #810
Cheers
Kilroy
Thanks very much for your input. I had considered this before. The only soldering I did was putting a TRX battery connector on (I'm confident that those joints are good...years of experience with soldering). The battery and motor wires came already soldered onto the ESC with heatshrink over the joints. And, the motor wires had bullet connectors already in place.
With issues like this I will usually start pulling things apart to find the problem, but I didn't want to go and cut their heat shrink off to inspect the solder joints...I figured if I did that and that didn't turn out to be the problem, I might be without any warranty at all.
Anyway, I got an RMA from HobbyPartz where I bought it and it's going back to them today.
Overtorqued is offline
