HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 10-15-2014, 07:03 AM
  #7921
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Jeepy2013
Thanks go out to HW NA, rec'd a brand new Stock Spec V3.1 yesterday. It started out a little on the rough and frustrating side sending in my brand new ESC for warranty, but once they got on it and got the ball rolling, they sent me a new unit pretty quick.
Great to hear now enjoy it.
FastPete is offline
Old 10-15-2014, 08:28 AM
  #7922
rcus3r's Avatar
Question about the 'Start Mode (Punch)' setting on the SCT Pro.
As I understand it, this setting limits the current. Is this current limiting through the entire throttle range, or just the beginning of the throttle range?
Curious if a lower punch setting limits the top speed of the motor. Would like to know what the technical explanation is.
Thanks.
rcus3r is offline
Old 10-15-2014, 09:42 AM
  #7923
Trader Rating: 83 (100%+)
Having trouble with my extreme stock esc and my airtronics 451 and 471 receivers. They don't want to power the Rx on at all. When I hook up the battery and turn the esc on but leave it unplugged from the Rx the esc light is solid red. When I plug in the Rx the light goes dead and no power. I tried both the extreme stock esc's with both rx's and both do the same. Help!
dpcardoza is offline
Old 10-15-2014, 09:47 AM
  #7924
FastPete's Avatar
Thanks.
Wont affect top speed. Just the startup transition area from a stop or roll.
Start Mode (Also called “Punch”): Select from “Level1” to “Level9” as your like, Level1 has a very soft start
effect, while level9 has a very aggressive start effect. From Level1 to Level9, the start force is increasing. Please note
that if you choose “Level7” to “Level9” mode, you must use good quality battery pack with powerful discharge ability,
otherwise these modes cannot get the burst start effect as you want. If the motor cannot run smoothly (the motor is
trembling), it may caused by the weak discharge ability of the battery pack, please choose a better battery or a softer
gear ratio
FastPete is offline
Old 10-15-2014, 10:43 AM
  #7925
rcus3r's Avatar
I read the the manual, but it does not give the full explanation. At what point does it stop limiting and allow the full current to flow through?
On the v3.1 (and perhaps others) you have two stages at which you can specify Punch Rate. So technically, you have control over this setting through the entire throttle range. On the SCT Pro, there is just one setting.
I guess I just wanted to know how it works.
On Castle ESCs, the torque limiting, if too low or high (it has been a while, so don't remember), will actually prevent your motor going the full speed, so that's why I am wondering.
Thanks.
rcus3r is offline
Old 10-15-2014, 11:00 AM
  #7926
Dr_T's Avatar
As explained on the previous page, as far as I know, limiting "punch" means smoothening the throttle control input. Say your finger moves the trigger from neutral to full throttle in 0.1 second, then at maximum punch setting, the ESC will give this throttle input 1:1 to the motor. At a lower punch setting, the ESC will increase the throttle input more gradually, say from neutral to full in 0.5 seconds, instead of the 0.1 you commanded (these numbers are just as an example, I don't know how HW actually implemented this). This will indeed result in lower Current spikes (as it allows for a more gradual acceleration), but it is a misconception it is the same as a Current limiter: stall the motor and there will be no difference between peak Current at high or low punch setting.
I am not a racer, but if you are, try and see how well you are able to time throttling-up for jumps with the lowest punch setting. I might be wrong, but my guess is you wont't do as well as with the highest punch setting, because with low punch, your throttle command will be "spread out" in time more.
Thanks.
Me too, so if anyone from HW that actually knows, could confirm whether the above is correct, that would be great.
EDIT.
On Castle ESCs, the torque limiting, if too high, will actually prevent your motor going the full speed, so that's why I am wondering.
Thanks.
Current / Torque limiting (technically the same) and punch settings are two different functions, each with their own use and purpose. HW does not have Current / Torque limiting in addition to punch settings, like Castle.
Dr_T is offline
Old 10-15-2014, 11:25 AM
  #7927
rcus3r's Avatar
Originally Posted by Dr_T
As explained on the previous page ...
Miss a day and miss out on all kinds of info. How interesting that a similar topic gets discussed back to back.
I too have the 150A in my buggy, and even at the lowest setting, and wish I could tame it down some more.
rcus3r is offline
Old 10-15-2014, 11:59 AM
  #7928
Dr_T's Avatar
Yeah, that's the problem. If the punch is really the throttle input smoothener that I think it is, it doesn't really do much taming (unless used with small motors or low gearing). On the lowest punch setting my car will still launch itself and make the batteries cry for mommy, just with a sluggish throttle feeling, making it even harder to stay in control, as somehow throttle response feels less predictable.
In contrast, a real Current limiter can be used to take the edges off, without creating sluggish response.
Dr_T is offline
Old 10-15-2014, 06:59 PM
  #7929
Tanis103's Avatar
My offroad cars with my Hobbwings. Just wanted to share my wiring with you guys. I love this ESC's.
HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-image.jpg
Tanis103 is offline
Old 10-15-2014, 07:00 PM
  #7930
Tanis103's Avatar
Attachment 1240173
Tanis103 is offline
Old 10-15-2014, 07:28 PM
  #7931
FastPete's Avatar
Attachment 1240172
Looks great!
FastPete is offline
Old 10-16-2014, 01:00 AM
  #7932
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
Originally Posted by JFuel11
Few more and a blank...
Please Check Previous Post at bottom of Page 524 for several more setup-sheets!
Please make sure you watch the gearing and temps of your motor with these settings! If not properly geared you can generate very high motor temps quickly, but this will make a 17.5 run like a 10.5!
Attachment 1237756
Blank Setup Sheet to track and share you own settings!
Attachment 1237757
Good Luck To All!
Alan (AKA JRF)
i'm looking at running a 13.5 in mod 2wd class in a B5M. i'm looking for a starting point with my 2.1 as far as gearing/boost/turbo. i'm using a 72 tooth spur. does this sound close?
24/72 gearing
20 degrees of boost coming on at 3000rpm to 19000rpm
10 degrees of turbo coming on at 18000rpm
i know i don't have it coming on as soon as your 17.5 setup, but i'm trying to keep it tame on the infield.
RC*PHREAK is offline
Old 10-16-2014, 03:12 AM
  #7933
Where is the cheapest place to get these?
DisJuanGuy is offline
Old 10-16-2014, 06:15 AM
  #7934
Suspended
Trader Rating: 115 (100%+)
I buy mine direct from Hobbywing North America, usually free shipping and they ship very quickly.
http://www.falconsekido.com/
Jeepy2013 is offline
Old 10-16-2014, 06:22 AM
  #7935
Suspended
I actually did, ran it in my Stadium truck in the mod class last night with a Speed Passion MMM 10.5t. Truck ran flawless, more than enough power for mod class. Qualified 2nd in both qualifiers and finished 2nd in the main. First time I raced the truck too.
I also run the same ESC in my B5M in stock 17.5 buggy class, that one powers a Trinity D4 17.5 Maxzilla and has been great, just need to work on my driving...lol
