HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 09-20-2014, 08:56 AM
  #7756
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by 7ac0ma
So I just wired up my V3.1 and I ran it for a 1/2 a pack. It ran very well without any issues. I went to set everything up with the USB link V3.43 on my computer and it said I had a Beta software update. So after updating the firmware on my Multifunction LCD Program Box I proceeded to update the software on the ESC. The update failed and now the V3.1 powers on, but will not respond to anything. No throttle, no Program Box Connection, No PC Connection, NO POWER OFF.... Nothing. I disconnect the battery to the ESC and then it'll obviously power down. Without anything connected but the battery, I still get the same results... PLEASE HELP!!!!????????
There were some isolated instances where when the firmware was updated, this happened. HWNA will take good care of you but you have to send the ESC back for repair. They will handle this promptly. Sorry it happened. Follow the link.
http://www.falconsekido.com/pages/rma
FastPete is offline
Old 09-22-2014, 12:07 PM
  #7757
sac
I have a HW Extreme stock esc and i am trying to change some settings in the esc manually thru the set button on the switch.It won't allow me to get in the programming mode,it goes into the calibration setting only.Tried the LED HW programming card and that doesn't work either .It just displays dashes in the display box.In the instruction it does say some thing about if the esc has the 15 programmable setting software that they LED box won't work .But it should still allow manual programming,and it doesn't.
On HW website it shows the LCD programmer with all their combo sets for the extreme stock esc.So does that mean that only the LCD programmer will work? I have programmed many esc and this one has just got me stumped.
The esc works fine ,just doesn't won't allow me to change settings.
And as most of you know getting tech help from HobbyWing/Falconseikido USA is email only if your lucky,no direct phone support .
Sac
sac is offline
Old 09-22-2014, 01:36 PM
  #7758
FastPete's Avatar
Sac
Sac
So for the manual way your following this?
http://cdn.shopify.com/s/files/1/010...e_ESC.pdf?1727
Now the Product description lists the LCD only. But the instructions say both. I will find out or can someone clarify.
FastPete is offline
Old 09-22-2014, 06:02 PM
  #7759
FastPete's Avatar
LCD only works with xtreme stock esc. I asked for the instructions to be corrected.
FastPete is offline
Old 09-23-2014, 12:12 AM
  #7760
rcus3r's Avatar
Tried to upgrade my Hobbywing 3.1 ESC with the latest beta firmware. The process failed, and now my ESC will turn on, but will not turn off (have to pull the battery). The LED is solid red. Steering works, but no throttle. Program box will not connect to ESC.
What are my options?
Failed firmware upgrade is never a good thing...
I have a SCT Pro I had no problems upgrading.
Thanks.
rcus3r is offline
Old 09-23-2014, 04:37 AM
  #7761
lewis110's Avatar
The LED box will only work if you are running the 508 blinky firmware. With any boosted firmware you will be the LCD box. Its the best 20 bucks you can buy..
I'm also pretty sure you can't use the program button with the boosted firmware. Also if its going into calibration mode you're not holding the set button down long enough. That's if you can use the button lol
lewis110 is offline
Old 09-23-2014, 07:59 AM
  #7762
FastPete's Avatar
Thanks.
FastPete is offline
Old 09-23-2014, 09:53 AM
  #7763
I got my justock esc working ok or so i thought. i turned the car on yesterday and it was good and punchy from the get go. after about 5 min when i hit the throttle it goes slow for about 3 or 4 seconds and then takes off. any ideas why?
djbowen1 is offline
Old 09-23-2014, 10:15 AM
  #7764
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Reduce Lipo Cutoff voltage
Try turning down your lipo cutoff voltage. I run min at 3.0v per cell on most and on heavy load applications I run it at 2.8v per cell. I have never had an issue with over discharging the lipo because when I hit cut-off at these settings the non-load voltage of the packs after a run are still in a very safe zone.
Good Luck!
JFuel11 is offline
Old 09-23-2014, 10:33 AM
  #7765
rcus3r's Avatar
Thanks. Figured there isn't much I can do.
RMA process initiated.
rcus3r is offline
Old 09-23-2014, 10:03 PM
  #7766
justpoet's Avatar
Trader Rating: 16 (100%+)
Silly question. What is a recommended heat sink for use with the sensored Xerun SC motors? With the ribbing, almost none fit. I'm currently running part of one that I dremeled short enough to go on between the motor mount and the fins, but I'd love to know of one that will also go between the fins themselves to properly cool that end of the motor too.
Alternatively, would the non-sensored version's can, which appears to be a smooth can, be something I could get as a replacement part and put on in place of the current finned can?
justpoet is offline
Old 09-23-2014, 11:17 PM
  #7767
lewis110's Avatar
http://www.tqrcracing.com/shop/produ....asp?p_id=2340
These fans blow a ton of air. And the way it mounts fits perfect on the short course motors.
lewis110 is offline
Old 09-24-2014, 12:14 AM
  #7768
justpoet's Avatar
Thanks for the link. I saw those, but I'm trying to find something that won't require a fan to do significant cooling. On all my other non-HW motors I use the AE Long Fin heat sinks and they work quite well in SCs.
justpoet is offline
Old 09-24-2014, 04:58 AM
  #7769
Slotmachine's Avatar
You should not need a heat sink on the 4 pole SC motors. If your motor is getting above 150 then you are most likely geared too high, I have been running these motors in a heavy SCT410 and never have overheating issues.
Paul
Slotmachine is offline
Old 09-24-2014, 11:21 AM
  #7770
justpoet's Avatar
Paul
EBuggy lite. Gearing is fine, matching the SC, but far less airflow so need a better heat sink than the finned can. I also like to keep motors down in the 135 range when possible, which these should be able to do with heat sinks.
justpoet is offline
