HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 09-10-2014, 09:43 AM
  #7681
i'm so confused
djbowen1 is offline
Old 09-10-2014, 09:53 AM
  #7682
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default It can be but you will get it!
Originally Posted by djbowen1
i'm so confused
I know it is frustrating when you can't seem to get it to work, but it will happen!
Like the others have stated ensure you radio is set up correct first. Trims at 0 or in the middle, endpoints at 100% both directions (My radio goes to 120 or 150% but I always start at 100% myself)
Ensure no traction control settings or ABS brake settings are turned on your radio as these will interrupt the setup process.
1. Power up Esc while holding setup button and release button once powered up.
2. Leave throttle input at neutral and hit setup button.
3. Input Full Throttle on the remote and hit setup button.
4. Input Full Brake on the remote and hit setup button.
ESC should confirm settings and then operate correctly.
If this does not work, change the channel direction (Reverse) on your throttle channel in the remote and then start the process again. Once done please confirm the results.
Good Luck!
JFuel11 is offline
Old 09-10-2014, 10:18 AM
  #7683
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
crap, i was doing:
hold button and power on, let go of button
click button once to set neutral
click one more for forward
click once more for brake - this is where the motor was going nuts
Ill try the way you said when i get home.
I forgot the neutral setting. I corrected my steps. Are you hearing the beeps?
1 Beep for neutral, 2 beeps for throttle, 3 beeps for full break?
I suspect something is off with your trims, epa or your calibration steps. Can you make a video of the your calibration and issues?
Wildcat1971 is offline
Old 09-10-2014, 12:48 PM
  #7684
not hearing any beeps at all except for when i put it into the program mode by holding the red button and powering it on
djbowen1 is offline
Old 09-10-2014, 02:05 PM
  #7685
how long should i be holding the red button once the power comes on and it beeps?
djbowen1 is offline
Old 09-10-2014, 02:10 PM
  #7686
after it it turned on release the red button. one release press it again with the trigger at neutral, release it. you should hear a beep. then full trigger pull and press and release the red button. 2 beeps. full brake press and release the button, 3 beeps.
Old 09-10-2014, 03:03 PM
  #7687
FastPete's Avatar
Trader Rating: 44 (100%+)
On my SCT Pro I had this type of issue, was my fault. I wasn't holding the button long enough when turning on. I wasn't getting it in program mode.
FastPete is offline
Old 09-10-2014, 04:48 PM
  #7688
Default hobbywing xerun sct pro 120a esc and programer trouble
My multi function lcd program box will not connect to my Xerun sct pro 120a esc. updated firmware to box and still does not connect. using fan port per directions. what do I do?
dmcadams1973 is offline
Old 09-10-2014, 05:20 PM
  #7689
nitro_mt_racer's Avatar
Trader Rating: 240 (100%+)
Does your box just say "connecting to esc" yet never connects?
nitro_mt_racer is offline
Old 09-10-2014, 05:24 PM
  #7690
thephunnel's Avatar
I've had the same trouble. After trying a bunch of times, it finally connected. I thought maybe it was because it had never been connected before, but next time I tried, I had to try a few times again before it connected. I was thinking it could have something to do with the software. Tried to update the software online, but it wouldn't update so I just gave up.
thephunnel is offline
Old 09-10-2014, 05:38 PM
  #7691
That is exactly what it is doing Nitro.
Old 09-10-2014, 05:56 PM
  #7692
I've been told that the esc is looking for a neutral signal and until it sees that it won't allow the program box to connect to the esc. Unplugging your esc from the receiver should fix the issue.
Old 09-10-2014, 06:03 PM
  #7693
I will try it but seems I already tried connecting while unpluged from reciever.
Old 09-10-2014, 06:09 PM
  #7694
thanks nitro, that worked, but how stupid, the whole purpose of connecting through the fan port is so you do not need to go into the rx box.
Old 09-10-2014, 06:12 PM
  #7695
Maybe turn your radio on so the esc would see neutral
