HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 09-09-2014, 03:34 PM
  #7666
Trader Rating: 21 (100%+)
Originally Posted by FastPete
2013-11-30
database version:130814
Thanks Fastpete ill look that up. PS i refer people to the website in your sig all the time as a USA dealer cause your the only one i know of other than order directly from Hobbywing.
NvDesertRat96 is offline
Old 09-09-2014, 06:11 PM
  #7667
FastPete's Avatar
Trader Rating: 44 (100%+)
FastPete is offline
Old 09-09-2014, 06:50 PM
  #7668
Default need advise
Hi Guys
my first post in the forum
currently I'm owning xerun 120a esc, im planing to put another hw motor on it, im using 3s lipo battery with 40c.
is it safe using this motor with those battery
hobbywing xerun 13,5t sensored motor or hobbywing V10 sensored 13,5T motor
need some advise Guys
Thanks Before
kh3ong is offline
Old 09-09-2014, 07:01 PM
  #7669
FastPete's Avatar
Originally Posted by kh3ong
Hi Guys
Thanks Before
The 2.1? And welcome!
FastPete is offline
Old 09-09-2014, 07:07 PM
  #7670
Yes Pete V2.1 for the esc,
is it safe to use 3s 40c lipo battery for those motor
Thanks before
kh3ong is offline
Old 09-09-2014, 07:12 PM
  #7671
FastPete's Avatar
Thanks before
I don't see why not as long as its a good quality battery. Should work great.
FastPete is offline
Old 09-09-2014, 07:17 PM
  #7672
Thank you very much Pete for the confirmation
just wondering which one is you sugest more for the motor
xerun 13.5 T sensored motor or the v10 sensored motor
kh3ong is offline
Old 09-09-2014, 07:23 PM
  #7673
FastPete's Avatar
Either is fine. The V10 is the hot one.
FastPete is offline
Old 09-09-2014, 07:28 PM
  #7674
Great, thanks a lot for the info
kh3ong is offline
Old 09-09-2014, 11:18 PM
  #7675
raz14's Avatar
Very pleased with the Justock ESCs. Everyone at the track has only great things to say about them so just ordered a 3rd to run them in all my cars now. Great value.
raz14 is offline
Old 09-10-2014, 07:10 AM
  #7676
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default They are amazing!
The Justock ESC is amazing for the money. I have ran them for over 2 years now and pushed them to the limits to see what they can handle. I don't suggest doing the same but I was able to run my Justock with no fan in a 2wd SCT with a 13.5 and 10.5 with no issues. I also ran it with a 10.5 and 8.5 in a 2wd buggy but did thermal a few times when I pushed the timing and gearing to the max on the 2wd buggy again with no fan in place. I suggest running a fan if it fits in your application.
It is the little esc that could!
JFuel11 is offline
Old 09-10-2014, 07:49 AM
  #7677
Default justock esc setup issues
I have no idea what i am doing wrong with the setup. I am using the ESC with a turnigy 17.5 motor.
I set it all up, hold down the little red button and then set the idle, button again and hold down the throttle, button one more and set the brake.
The motor typically goes nuts and it only has one speed, its either on or off and it sounds awfully slow.
The red light is always on no matter what when the esc is idle (hand of controller)
any ideas before i lose more of my mind?
djbowen1 is offline
Old 09-10-2014, 07:55 AM
  #7678
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
make sure your trims and sub trims are set to neutral. Make sure any ABS or traction control features on the radio are off.
Then
Turn the radio on
hold the the red button pressed and turn the esc on. you should hear some beeps
push red button while trigger at neutral.
Pull the trigger to full throttle, then press the red button. you should hear 2 beeps
Push the trigger to full break and push the red button. you should hear 3 beeps.
Turn the esc off and back on.
Should work fine now.
Make sure the blue wire is going to the A, yellow to the B and orange to the C on the motor. Make sure your throttle is not reveresed on the radio. Make sure your thottle or brake EPA are not over 100%
Wildcat1971 is offline
Old 09-10-2014, 08:17 AM
  #7679
crap, i was doing:
hold button and power on, let go of button
click button once to set neutral
click one more for forward
click once more for brake - this is where the motor was going nuts
Ill try the way you said when i get home.
djbowen1 is offline
Old 09-10-2014, 08:27 AM
  #7680
Slotmachine's Avatar
Originally Posted by djbowen1
crap, i was doing:
You are doing it correctly......just make sure anti-lock brakes are not on in your radio. And if you read the manual I think it tells you to reverse the throttle. If you have another sensor wire try that too.
Paul
Slotmachine is offline
