HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 09-07-2014, 05:53 PM
  #7651
Slotmachine's Avatar
Originally Posted by mr jim
I have recalibrated like you said but still, nothing. This car is brand new so shoudnt be anything worng with it
Could be a bad receiver
Originally Posted by FastPete
No worries, but if I understand correct this is in the right place. I don't believe the V3.1 120A works well with 4 poles. The SCT Pro is the one that works well with 4 pole motors. Am I correct Slotmachine?
Yes.....correct!
Slotmachine is offline
Old 09-07-2014, 06:50 PM
  #7652
Can the 90 amp 2.1v esc handle a 6.5t Tacon sensored ?
Eagl97 is offline
Old 09-07-2014, 06:59 PM
  #7653
FastPete's Avatar
Trader Rating: 44 (100%+)
This is what I found. Im not familiar with that brand motor.
With 2 Lipo or 4-6 NiMH
1/10 on-road: >=5.5T
1/10 off-road: >=8.5T
With 3 Lipo or 7-9 NiMH
1/10 on-road: >=10.5T
1/10 off-road: >=17.5T
FastPete is offline
Old 09-07-2014, 07:04 PM
  #7654
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
Strange could use some shoe goo (might be a mess to get out), or I think Exceed makes some real sticky gum for cleaning I heard nitro guys use to keep wires in the receiver.
But don't understand why you have to do that. Just checked mine and its snug. Maybe send a email to Falcon Sekido and see what they say.
I tried emailing cobra racing a few days ago but I'll try emailing falcon sekido. I'm using my sct pro ESC with a 4pole motor. Does anyone know if the sct pro will work with a 2 pole HW V10 motor ?
DriveItLikeYSIT is offline
Old 09-07-2014, 07:08 PM
  #7655
Ok thanks, Tacon is sold at Hobbypartz.com with Hobbywing products
Eagl97 is offline
Old 09-07-2014, 07:09 PM
  #7656
FastPete's Avatar
Yes it should.
FastPete is offline
Old 09-07-2014, 08:10 PM
  #7657
Default problem??
I am running a Losi SCTE 4x4 1.0 with a Xerun SCT Pro speed control with a Tekin Pro4 4600kv motor. It is geared with a 40T spur/13T pinion. My battery is a CRC Rocket Fuel 7100 mah/90c. As of late the speed control has been blinking green/red simultaneously even after one lap. The truck has yet to shutdown and keeps running even though the speed control is blinking the green and red the whole time. The motor has been coming off at an average 145 degrees and the speed control was 107 degrees. Can anybody diagnose this for me? This is a new problem as the truck has run just fine.
gmslash is offline
Old 09-07-2014, 08:27 PM
  #7658
Did you reverse the throttle on the radio settings?
Paul
Old 09-07-2014, 08:30 PM
  #7659
Yes it will run it.
Paul
Sounds like a sensor issue, try a new sensor wire first.
Paul
Old 09-07-2014, 08:44 PM
  #7660
jmkalt's Avatar
SCT Pro fan crapped out today. Speedo still works fine, although without the fan, I thermaled out.
Verified it is indeed the fan itself by swapping fans with another esc.
Does anyone have a source for a replacement, or a part number to search? **** Nevermind, found it, thanks anyhow. ****
jmkalt is offline
Old 09-08-2014, 06:57 AM
  #7661
Tanis103's Avatar
I had two guys at my track ask me would it be worth sending in their ESC 1S that they hooked up backwards for repair. They both popped so they need to be repaired or throw away. What do you guys think it would cost?
Thanks,
Tanis103 is offline
Old 09-08-2014, 07:30 AM
  #7662
FastPete's Avatar
Thanks,
I would email FalconSekido and ask.
FastPete is offline
Old 09-08-2014, 04:19 PM
  #7663
hesh's Avatar
What firmware are you using?
Should be current, it updated about 4 weeks ago, was no updates available 2 weeks ago when i checked.
hesh is offline
Old 09-09-2014, 03:31 PM
  #7664
Trader Rating: 21 (100%+)
quick question? I just got a nib SCT Pro ESC replacement from warranty. What is the most current firmware that should be installed. When i look at the update one is a beta and the other i cant find in the list on the download tab. My truck isnt as fast as it should be. It feels the same as it did when i was running the SC8 from my basher as a back up.
NvDesertRat96 is offline
Old 09-09-2014, 04:12 PM
  #7665
FastPete's Avatar
2013-11-30
database version:130814
FastPete is offline
