HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 07-29-2012, 02:37 PM
  #751
What C are the batteries? The only thing I can think of is that you're not supplying it with enough juice. If that's not the case, then I would suggest warrantying it.
Racer X8000 is offline
Old 07-29-2012, 02:40 PM
  #752
Devigili22's Avatar
Trader Rating: 29 (97%+)
They were a couple weeks old 40C Gens Ace. I have run those same packs through the truck many times with no issues. I really don't want to send this damn thing all the way back to China. I got it off of falconsekido.com if that makes any difference.
Devigili22 is offline
Old 07-29-2012, 07:35 PM
  #753
Trader Rating: 41 (100%+)
I'm sorry that will never be the case. I currently run a heavy buggy with 4s 5000mah 20C packs No Problem.
to me it sounds like either the BEC is having issues and browning out your Receiver
Or there is an issue with your Voltage cutoff.
First Try to Re-flash the Firmware with the current Version
If it still happens Turn Off your Lipo Cutoff and run the car for a few minutes just to see if that has any effect
Still not working could be the BEC but just to be sure swap out the receiver and see is that changes anything
jdeadman is offline
Old 07-29-2012, 07:56 PM
  #754
GiMLit's Avatar
My suggestion is contact Falcon Sekido. I have had only a few dealings with them but they have been truly spectacular to deal with.
GiMLit is offline
Old 07-29-2012, 08:11 PM
  #755
Devigili22's Avatar
I currently only have the field program card so I can't flash any new firmware at the moment but I doubt that is the issue, it worked great before with the exact same setup. Tried a brand new receiver with same results so that rules that out. Going to give the lipo cut-off change a shot tomorrow, but I doubt it again since it's just started happening.
Old 07-30-2012, 01:58 AM
  #756
dtr
dtr's Avatar
What is the difference between the Xerun 3656 and the Ezrun 3656 motors? Obviously there is the sensor, shaft diameter and different case but anything else?
dtr is offline
Old 07-30-2012, 03:06 AM
  #757
lewis110's Avatar
The biggest difference is the Xerun motors are sensored. There might be little things in the motor that are different also but I don't know for sure.
lewis110 is offline
Old 07-30-2012, 10:48 PM
  #758
hi, I posted a thread asking about running a stadium truck with the 1s esc here
Must I need to use a fan? Most likely motor to be run will be 10.5t or 13.5t. Thank you.
one-nil is offline
Old 07-30-2012, 11:17 PM
  #759
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
You won't need a fan dont worry
Blitzrockey is offline
Old 07-31-2012, 01:01 AM
  #760
thank you. so how low a motor can I go with the 1s? I have a sensorless HW 8.5t that I can try too. If I don't need a fan for that then I think I will use that. The truck will be run on a track not for bashing. Thanks again.
one-nil is offline
Old 07-31-2012, 07:02 AM
  #761
Kevin_M's Avatar
Is there a hobbywing repair place here in the USA?
Kevin_M is offline
Old 07-31-2012, 07:27 AM
  #762
Tyler Keel's Avatar
I just got a 150Amp ESC in a trade and it has 10AWG wire on it. I assume this is from the factory, is that ok to run or would someone suggest I switch to 14AWG?
Tyler Keel is offline
Old 07-31-2012, 07:46 AM
  #763
I Have ran a 550 4.5 with mine with the heatsink and fan in my 4x4 sc. Also right now I run a 4000kv 4pole in it now with the same esc. It should be good down to a 4.5 540 can, I would put the heatsink on though and check temps and possibly use the fan.
Old 07-31-2012, 09:11 AM
  #764
ach86's Avatar
Trader Rating: 45 (100%+)
So I just purchased 2 of the HW SCT Pro. Has anyone tried or running the RevTech 4Xs in a SCTE with the SCT Pro?
Any tips or pointers accepted, thank you.
ach86 is offline
Old 07-31-2012, 09:45 AM
  #765
Will do even though I won't be running such hot motors. Thanks.
one-nil is offline
