HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 08-14-2014, 10:25 AM
  #7441
rcboy1's Avatar
Originally Posted by DriveItLikeYSIT
I'm considering getting a HW Xerun v10 8.5t v10 motor for my sct. Is anyone using a V10 mod motor in a 2wd sct? How do they compare to other brands like tekin, reedy or trinity?
I have ran this motor in this class before. I did a lot of running with the original hobbywing motors, v10 motors, tekin redline gen2, and reedy mach2. I can tell you right off the bat, the original hw motors are not in the same class of smoothness and power as these other, high end competition motors .
The v10s produce much more power and run about 5-7 degrees hotter than a same turn reedy motor, similar smoothness. Compared to tekin the smoothness and high end are about the same, but the low end is a bit punchier on the hobbywing. Hobbywings actually run a tad cooler than the tekin, possibly because of the greater airflow.
Hopefully this helps.
rcboy1 is offline
Old 08-14-2014, 10:35 AM
  #7442
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
Great review..Thanks !
DriveItLikeYSIT is offline
Old 08-14-2014, 06:00 PM
  #7443
Trader Rating: 17 (100%+)
Justock ESC #4 startmode(punch) HELP. Level 1s thru 19, factory setting is at 17. Is the lower the number the more punch?
bladeys is offline
Old 08-14-2014, 06:11 PM
  #7444
Slotmachine's Avatar
The higher the punch # the more punch you get. The lower the # the less wheel spin.
Paul
Slotmachine is offline
Old 08-14-2014, 07:06 PM
  #7445
Sent in my RMA request for my bricked ESC on August 5, got the RMA number on Aug 7, ESC arrived at Hobbywing on Aug 11 (shipped over weekend), the processed the RMA today Aug 14 and are supposed to ship in the next few days. So the RMA process for bricked ESCs takes around 2 weeks.
Below is the email response from Hobbywing:
xxxxxxxxxxxxxxxxxxxxxx
Dear xxxxxxx
Our RMA department has inspected the ESC on multiple levels. We found that there was a problem with a ROM that the entire unit needed to be replaced.
The ESC was determined to be a defective that we will issue a brand-new replacement with no extra charge. We sincerely apologize for the inconvenience.
Please find the special discount code. You can apply this code at the very end of check out page at Falconsekido.com
CODE: xxxxxxxxxxxxxxx
Please find the inspection summary below:
=== Inspection Summary ===
ESC: Xerun Stock Spec v3.1 ESC Black Edition
Term: defect
Purchased from authorized Dealer - YES
Purchased from FalconSEKIDO.com - YES
Instruction: Provide a brand new ESC
Service Charge: $89 - waived
S/H: $8.99 - waived
Total: $0
=== End Message ========
The new ESC is fully checked for its performance prior to shipping.
The package will be ready to be shipped by our automated fulfillment service in 1-2 days . You will receive the tracking number accordingly. Should you have any questions please let us know.
Thank you for your patience and support in advance.
Regards,
Team HOBBYWING
HOBBYWING NA. | FalconSEKIDO
Your Premium RC device
Crashaholic is offline
Old 08-14-2014, 08:29 PM
  #7446
FastPete's Avatar
Trader Rating: 44 (100%+)
Seems like great service! Cant wait to hear you enjoying your HW product.
FastPete is offline
Old 08-17-2014, 07:31 PM
  #7447
advpball's Avatar
Trader Rating: 30 (100%+)
i have stock spec v3.1 and can't seem to get drag brake out! re set up just won't go to a coast i am running in blinky mode?
just sent one like this back...had no problems then just stopped working rite...
recalibrated to radio and went threw setup box?
advpball is offline
Old 08-17-2014, 07:58 PM
  #7448
I think there are 2 settings for drag brake, the first is the drag brake setting then there is initial brake make sure you set both to 0.
Paul
Old 08-17-2014, 09:23 PM
  #7449
cttech455's Avatar
I've been running the 8.5t v10 in my scx-60 for 4 months now. Before that I had a viper 8.5 turn vst. The viper motor died after two months of use in a truck that was properly geared (20/81) Don't be fooled by the viper one year warranty as after I sent my motor to viper they claimed it was damaged to my mis use. I run hobbywing in every thing else I own so I decided to give the new v10 motors a shot. The motor runs much cooler than the viper and is still going strong. The machining is much better. The entire motor fits together very well, no shims needed. I've been happy with it so far.
cttech455 is offline
Old 08-17-2014, 09:57 PM
  #7450
Default Stock Spec Set Up for 7.5 SCT
Looking to see if anyone has suggestions on above set up. I am currently running blinky. Fairly long straight but I have to baby all the power or get wheel spin or wheelie. Run at the front of Pro2 class so need input from you fast guys. Thanks.
Micah123 is offline
Old 08-17-2014, 10:42 PM
  #7451
Trader Rating: 21 (100%+)
Just a follow up to this. HW had 6 day turn around on my ESC from the time they received it. Being out of warranty a invoice came with the damage report. I paid the invoice and with in a couple hours i have a tracking number. So im must say im very impressed with the service turn around time. Also thier customer service was outstanding. Every email i sent was answered with in 24hrs, even if it sounded like impatient rhetorical questions or just a simple follow up question to make sure i was understanding the process. TY Hobbywing for having great products at resonable prices and having a outstanding CS team and RMA team. Thanks, Dave L.
NvDesertRat96 is offline
Old 08-17-2014, 11:12 PM
  #7452
raz14's Avatar
Great to see a support thread for Hobbywing!
Would the Hobbywing Justock Club Spec 45A ESC handle this motor for 13.5T superstock ST?:
Flash Racing Motor 1/10 sensored motor 13.5T 3200kv
http://www.hobbypartz.com/30p-110-flash-aa-3200kv.html
raz14 is offline
Old 08-17-2014, 11:19 PM
  #7453
lewis110's Avatar
Yes, the Justock will power that motor no problem. I'm currently running a SchuurSpeed 13.5 in my SCT. The Justock can handle easily down to a 10.5 in truck and even a 8.5 in a 2wd buggy. IMO its the best blinky only ESC going..
lewis110 is offline
Old 08-17-2014, 11:35 PM
  #7454
raz14's Avatar
Excellent. Thanks!
raz14 is offline
Old 08-17-2014, 11:49 PM
  #7455
Scojax's Avatar
Default Justock a great value!
I invested in my first Justock ESC this week. (I also have 2 Tekin RS). Installed it and ran a 13.5 in ST with no problems. Setup and install was super easy. The brakes are not as strong as I am used to, but i'll try a few tweaks to see if I can get a little more out of them. Otherwise, I am totally happy with the purchase.
Scojax is offline
