HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 07-14-2012, 07:45 PM
  #706
Cloaked's Avatar
Trader Rating: 15 (100%+)
So is there a way to reset the LCD Progam Box?
I think I bricked mine with a firmware update....
When I connect it to teh PC it just shows Squares....
Cloaked is offline
Old 07-14-2012, 08:01 PM
  #707
lewis110's Avatar
On the pc software just hook up the lcd box and redownload the filmware.
lewis110 is offline
Old 07-15-2012, 05:52 PM
  #708
mesa80's Avatar
was wondering if running a tekin t8 with a hobbywing 150a ezrun 1/8 esc would be ok cause tekin 1900 kv motor has a sensor plug but on the tekin site states you can run in sensorless operation schould i go with this set up and will it be ok or return esc for one that operates sensored
mesa80 is offline
Old 07-15-2012, 06:06 PM
  #709
lewis110's Avatar
Ezrun esc are sensorless, you would be better off getting the Xerun 150 if you wanna run sensored.
The ezrun lineup is one of the best sensorless esc's made. I don't believe you will have a problem if you wanna run the ezrun.
lewis110 is offline
Old 07-15-2012, 06:31 PM
  #710
Cloaked's Avatar
Nope, just shows squares on the LCD Screen and is not recognised by the PC.
Cloaked is offline
Old 07-15-2012, 08:40 PM
  #711
lewis110's Avatar
You gotta pull down the tab for the program box. Then you just redownload the filmware to the program box.
lewis110 is offline
Old 07-16-2012, 12:46 AM
  #712
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Anybody suggest a starting FDR for a 4w short course with a 4000kv four pole?
CraigMBA is offline
Old 07-16-2012, 05:44 AM
  #713
lewis110's Avatar
What truck? I run 13/46 for a fdr of 11.5 the motor comes with both 15t for mod1 and 19th for 32 pitch pinion gears. My SCRT10 came with a 13t pinion so I started with that. I tried the 15t and my feeling is it has more torque with the 13 and overall speed is more then fast enough. I also don't use any timing in the esc and run the punch around 4/5 if you have a hoobywing esc also. You will be impressed with this bad boy of a motor.
lewis110 is offline
Old 07-16-2012, 06:03 AM
  #714
Default Ezrun combo on SCTE
Hi,
I use combo on my SCTE Ezrun SC8 120A SC-C3 motor 4700KV with gear 17/40. My ESC burn after only 2 pack. I check temp after that and motor at 150F. ESC is ok. On my third pack, i run only one lap normal and after 30-35 min, because i wait after my charger. The engine stop suddenly and ESC burn and a lot of smoke. I have a spare ESC but i don't know if i use it again on it.
diltech is offline
Old 07-16-2012, 06:40 AM
  #715
CraigMBA's Avatar
Originally Posted by diltech
Hi,
Too much gear, friend.
CraigMBA is offline
Old 07-16-2012, 06:47 AM
  #716
Ok, what is the best for that ?
diltech is offline
Old 07-16-2012, 06:59 AM
  #717
CraigMBA's Avatar
What truck?
Sc10 4x4.
11.5 it is. Thanks!
CraigMBA is offline
Old 07-16-2012, 07:00 AM
  #718
Lonestar's Avatar
Trader Rating: 14 (100%+)
Just wanted to say I am upset to not get any email answer to the email I sent out (with polite reminder a few ds after) to the "support" HW email addy...
what's the point of claiming you have email tech support if no one replies to long-standing customers?
shame...
Paul
Lonestar is offline
  #719
CraigMBA's Avatar
A smaller pinion (like a 12).
CraigMBA is offline
Old 07-16-2012, 05:23 PM
  #720
TCCustoms's Avatar
i got a coupon from Falconsekido.com for 10% off if anyone is putting in a order for hobbywing stuff....PM me and i'll shoot it to ya!
TCCustoms is offline
