HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 06-10-2014, 05:01 AM
  #7066
Originally Posted by Micah123
Own 2 stock spec speed controls and considering a Just Stock for a 17.5 buggy. Any reason not to go with a Just Stock? Will be running blinky mode. Assuming I can set drag brake,etc with the HW Program Box. Thanks
Anyone?
Micah123 is offline
Old 06-10-2014, 07:39 AM
  #7067
FastPete's Avatar
Trader Rating: 44 (100%+)
Anyone?
Good choice and yes you can set the DB.
FastPete is offline
Old 06-10-2014, 09:57 AM
  #7068
Thank you sir. If one of our local racers was not a dealer, you would be getting my business.
Micah123 is offline
Old 06-10-2014, 11:08 AM
  #7069
FastPete's Avatar
Your welcome , and I understand.
FastPete is offline
Old 06-10-2014, 12:19 PM
  #7070
RCaddict0's Avatar
Trader Rating: 85 (99%+)
Thumbs up Fastpete fiercercsolutions.com #1
I wanna thank you Fastpete for the help!
I didnt even buy it from him and he got me hooked up directly w prompt help! That says alot about Pete and fiercercsoultions.com ! I know where Im buying my next ESC! Customer service is worth so much And after multipal attempts to find help this guy pms me outta no where without me contacting him and get me fixed up quick!
RCaddict0 is offline
Old 06-10-2014, 03:35 PM
  #7071
shannow's Avatar
Hello everybody,
Since a few sessions I've had a little problem with my hobbbywing xtrem stock esc (with a 13.5t combo). Completely randomly, it dies ... no floashing lights, sound , throtle and brakes are dead but the steering works fine. No drag either, totaly dead even if I push the car around . Switch off/on and it works back again.
I first though the batteries are dead but they were at 7.4v and today it did after two laps with brand new batteries and cold ! Again switch on and off and it works again.
My conclusion at the moment is software problem but i've never updated or interfered with it ...
Any idea ?
thank you
Jonathan
shannow is offline
Old 06-10-2014, 07:00 PM
  #7072
FastPete's Avatar
Originally Posted by shannow
Hello everybody,
Any idea ?
thank you
Jonathan
Hi Jonathan
I would try to lower the LVC first to 2.8 and see if it improves. And start with a fully charged battery.
FastPete is offline
Old 06-10-2014, 11:38 PM
  #7073
shannow's Avatar
Can't try this before next week but I doubt it will solve my problem because yesterday I had LVC 3.2v but the pack was fully charged when it died (litteraly 2 laps of a small inside track).
Switch off/on and then it work perfectly for the next 1/2h on the same pack and the next pack had no issue (same brand of batteries).
Thank you
Jonathan
shannow is offline
Old 06-11-2014, 12:59 AM
  #7074
rcboy1's Avatar
Thank you
Jonathan
You definitely will want to lower you lvc, even if that doesn't fix the issue. This way you will be able to use the full capacity of the pack
rcboy1 is offline
Old 06-11-2014, 06:44 AM
  #7075
Trader Rating: 31 (100%+)
Hello everybody,
Any idea ?
thank you
Jonathan
I've seen this happen due to a bad sensor wire or bad sensor board on the motor. Maybe try one of those also to see if it fixes it...?
joncmack is offline
Old 06-11-2014, 07:07 AM
  #7076
shannow's Avatar
Thanks for the ideas.
I've just charged back my batteries and the charger indicates me that I charged 3600mah for a 4000mah pack. That's 90% so I'm pretty good with the lcv . I did think of that at first but normaly it flashes red when you hit full throttle and you're under the lcv. I didn't have this symptom and the pack was fresh yesterday.
The sensor wire was one of my mates sugestions as well . While it was dead we wiggled the sensor at both ends (although they were both thoroughly in) and nothing happened.
It's very weird and more frustratingly can't be anticipated it's really randomly and occasionally. It does it every 2-3h run perhaps if I had to give a frequency.
Jonathan
shannow is offline
Old 06-11-2014, 07:12 AM
  #7077
Trader Rating: 16 (100%+)
So I have the 150a ESC and am using that in an 1/8 e-buggy. I had a problem where is was unexpectedly turning off. It looked like the on/off switch and the wire to the rx had some exposed wire so I replaced them. When I took the ESC apart to splice in some new wire, the heat sink came off.
Does anyone know if I need to use epoxy based thermal paste? or does the fan keep the heatsink in place?
thanks!
mupchu is offline
Old 06-11-2014, 07:54 AM
  #7078
FastPete's Avatar
Jonathan
Yes but under load you cant see when its getting pulled down to lower voltage numbers. You would be surprised. Its worth a try.
FastPete is offline
Old 06-11-2014, 09:47 AM
  #7079
RCaddict0's Avatar
I would like to take back some of my remarks and bitching, but I spent good money and was worried. But the retailer has responded and apoligized for their tardy response. They are replacing it with a new unit!
Also... Hobbywing China has also responded and seemed more than eager to help me out!
That eases my stomic. I was worried!
Old 06-11-2014, 12:11 PM
  #7080
Slotmachine's Avatar
Jonathan
Trust us........everyone here has quite a bit of knowledge when it comes to the problem you are having. Set the LVC to 2.8 or 3.0 and try it. HW LVC reads the cells differently and you need to set it lower.
Paul Rush
HWNA
TEAM DRIVER
Slotmachine is offline
