HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 07-06-2012, 05:37 PM
  #691
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by jdeadman
I replace mine every month and I just did it last week
Originally Posted by mulepic
Is there anyway to clean the motor out and make sure the bearings run smooth. I've had endbell bearings go out b/c I didn't know to clean them. A bearing on its way out will certainly over heat things.
I'm going to start doing mine every couple months too.. I just partially poofed my carbon pro 6500mAH lipo. A 125 lipo or a sub 10 bearing... hmm. What a waste!! Not to mention I lost the race! Fastest lap of the a-main, fastest 5 laps, fastest 10 laps and putted accross the line for the last lap for 3rd place. Hit LVC way early and started to poof the pack due to the added work from the seized up front bearing.
Any since this post started a new page, I was wondering if anyone had the bearing size for the back bearing in the xerun 540 5-pole motor. Thx
8ight-e is offline
Old 07-07-2012, 07:35 AM
  #692
8ight-e's Avatar
Bump.. nobody knows the rear bearing size in the 540 4-pole xerun class motors?
8ight-e is offline
Old 07-07-2012, 08:26 AM
  #693
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
Anyone else having an issue with changing the setting #10 on a sct pro esc? When I connect the lcd box to the esc through the fan port and go through the settings, it skips #10 (overheat protection). Thats only happening on 1 of the 2 sct pros i'm running.
KIK is offline
Old 07-07-2012, 09:51 AM
  #694
lewis110's Avatar
There is A LOT more knowledgeable people over on the hobbywing onroad thread. Someone over there will probably know.
lewis110 is offline
Old 07-08-2012, 12:27 AM
  #695
Lonestar's Avatar
Trader Rating: 14 (100%+)
hey guys i damaged the switch on my sctpro... can i replace it with the one from one of my xerun 2.1's, are they compatible? i have a race next sunday and cannot source one in that short a time... thanks!
Paul
Lonestar is offline
Old 07-08-2012, 02:37 AM
  #696
dtr
dtr's Avatar
Paul
You can cut off the switch and solder the red and black wires together, and seal the white with shrink tube or electrical tape. If you need the switch for programming then touching the white to the balck&red counts as a push of the button.
dtr is offline
Old 07-08-2012, 01:55 PM
  #697
Lonestar's Avatar
sounds like a good fix, thanks so the 8th and 10th scale switches are the same functionality, really? May I ask if you're 100% sure of that "trick"?
thank you
Paul
Lonestar is offline
Old 07-08-2012, 02:21 PM
  #698
TCCustoms's Avatar
Which thread exactly...not like it really matters to me as im sure they arent running the SCT Pro but this way others kno also...I did search and didnt see much for onroad hobbwing
TCCustoms is offline
Old 07-08-2012, 03:45 PM
  #699
lewis110's Avatar
http://www.rctech.net/forum/electric...-software.html
This is more of a all around hobbywing thread. Plus Angelo still watches this one so answers that others don't know he answers.
lewis110 is offline
Old 07-08-2012, 04:29 PM
  #700
TCCustoms's Avatar
ahh, i saw that one but didnt kno which was which and saw that Cobraracing i think started alot of them but wanted to kno! But thanks DooD!
Old 07-09-2012, 05:23 AM
  #701
Lonestar's Avatar
Visual inspection once opened and voltmeter probing tells me you're right Thansk for the valuable info!
Cheers,
Paul
Lonestar is offline
Old 07-09-2012, 11:00 AM
  #702
dtr
dtr's Avatar
Sorry, double post.
dtr is offline
Old 07-09-2012, 11:03 AM
  #703
dtr
dtr's Avatar
Cheers,
Paul
Guys are doing it all the time to 150A and 80A Xeruns here after those switches fail due to dust Not sure about 1/10 switches but those seem very similar except the case.
dtr is offline
Old 07-12-2012, 02:36 PM
  #704
does anyone have a good starting point for 13.5t boosted in 2wd buggy, will be driving on a low/med traction clay track
Bappe is offline
Old 07-14-2012, 07:39 PM
  #705
rcfiend's Avatar
Trader Rating: 42 (100%+)
Which HW Esc should I order fo 1/8 buggy?
rcfiend is offline
