HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 05-20-2014, 04:45 AM
  #6946
nanoverse's Avatar
Originally Posted by Slotmachine
No timing will not make that much difference, it sounds like something else may be wrong. Is everything on your radio set and did you calibrate things properly? Remember your radio settings for throttle should be set to reverse.
Paul
Why?
nanoverse is offline
Old 05-20-2014, 06:48 AM
  #6947
Slotmachine's Avatar
Originally Posted by nitro_mt_racer
Looking for some suggestions fellas. Running an scte with a sct pro, tekin pro4 4600, 7200 70c smc pack, esc consistently shuts off at around 4 minutes into a heat....low voltage protection is turned off!
Originally Posted by nanoverse
Why?
Sounds like it could be overheating, what is your gearing?
Slotmachine is offline
Old 05-20-2014, 06:50 AM
  #6948
Why?
With the particular problem he is describing I don't think timing is really going to make that much of a difference.
Old 05-20-2014, 06:57 AM
  #6949
Themuffinman: I would go with the 2200kv sensored motor in Truggy.
Old 05-20-2014, 08:55 AM
  #6950
triggar118's Avatar
Default hobbywing v3 problem
Hi there i have a problem with my hobbywing v3 i was trying out an extra fan which would connect where the program box would go i unfortunatly touched the 2 wires together while its was switched on i heard a little pop and now when i try to turn it back on the red light comes on for a second the drive train twitches and the green light fashes then fads and nothing but the fan is still working all be it very slow is this now dead it also has the twin resisters on can someone help cheers
triggar118 is offline
Old 05-20-2014, 10:18 AM
  #6951
You may have popped one of the capacitors, does the speed control still work?
Paul
Old 05-20-2014, 10:32 AM
  #6952
triggar118's Avatar
Paul
I'm going to desolder the capacitors but you plug the battery in and it comes on without pressing the button the red light comes on then the green light flashes before going out Speedo does not work but the fan is turning really slow
Old 05-20-2014, 12:17 PM
  #6953
Wow really? Still waiting for help with my speedo. :-/
nomaak is offline
Old 05-20-2014, 12:21 PM
  #6954
nitro_mt_racer's Avatar
Trader Rating: 241 (100%+)
13/40, same as it's been for the last year....with no issues.
nitro_mt_racer is offline
Old 05-20-2014, 12:28 PM
  #6955
FastPete's Avatar
Trader Rating: 44 (100%+)
Send it here.
http://www.falconsekido.com/pages/rma
FastPete is offline
Old 05-20-2014, 02:52 PM
  #6956
nanoverse's Avatar
I meant why put motor rotation in reverse? Does it matter.
Old 05-20-2014, 04:30 PM
  #6957
bru00z's Avatar
Default Xtreme Stock Caps Required?
I have a been running a RM 2wd in 17.5 blinky. I just bought a MM t try and another Extreme Stock ESC but didn't add the caps due to space. I didn't notice much difference in power and only slightly hotter in the MM which I expected but not sure if I should try and add the caps?
Are the caps just for lowering heat or do they help with anything else?
bru00z is offline
Old 05-21-2014, 01:00 AM
  #6958
Or get the 2250. I like my 2200, but I have a new HW 2250 just sitting here so I may swap them out and sell the 2200 to a buddy. I have a 2250 in my 8ight E 2.0 and it is silly.
Brushless Corey is offline
Old 05-21-2014, 01:23 AM
  #6959
Registered User
I was looking at the 2000kv or the 1800kv on a large out door track that's main reason to look at it for run time and all
TheMuffinman is offline
Old 05-21-2014, 04:08 AM
  #6960
You put you radio throttle setting into the reverse setting.
