HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 05-16-2014, 01:01 PM
  #6916
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by joel45acp
FastPete, I've heard some guys downloading different firmware on the SCT pro 120. What is the reason for this? Just curious.
Don't need to, but the latest is smoother than it is already, with little improvements. And works better with Tenshock motors.
FastPete is offline
Old 05-16-2014, 01:30 PM
  #6917
kcooper273's Avatar
Trader Rating: 62 (100%+)
Originally Posted by xxxntwv
it can be done with the setup button.just follow the directions to get into the setup menu and select the correct option by counting the beeps.it's a little confusing at first but once you get used to it its fine.
I tried it, it is impossible. I can only get to 4 flashes then the red and green blink at the same time, and it won't let me program anymore, the car just flies off the table.
kcooper273 is offline
Old 05-16-2014, 03:36 PM
  #6918
Trader Rating: 18 (100%+)
you must be in calibration mode,are you holding the button down long enough to get to into the setup mode.once you get into the menu long beeps is 5.
xxxntwv is offline
Old 05-16-2014, 04:21 PM
  #6919
Questions??
My new SCT Pro doesn't want to connect with the ESC and PC when the Transmitter is on. With unplugged RX-wire it works. But it should work with plugged wire and TX on too. In my TX all the Throttle Settings are at zero and the servo monitor shows also zero. I calibrated the ESC. I use the fan port. What else can I do?
yacagree is offline
Old 05-17-2014, 10:00 AM
  #6920
Trader Rating: 52 (100%+)
Radio must be off for it to connect. Tx takes priority
tonyd is offline
Old 05-17-2014, 01:26 PM
  #6921
No it has to be on or you unplug the rx wire.
http://www.falconsekido.com/blogs/ne...-xerun-sct-pro
yacagree is offline
Old 05-17-2014, 02:14 PM
  #6922
Trader Rating: 31 (100%+)
Had something interesting happen today while practicing with my 22T. I have a Hobbywing Stock Spec v3.1 and was running a Novak Ballistic 10.5 in blinky mode. Haven't had any problems as recently as yesterday, but today, randomly, it would completely cut the ESC off while I was driving. I switched to a different motor (Trinity D3.5 17.5T) and changed the profile (didn't change sensor wire or battery) on the ESC and had no problems for the entire run. Think this is something wrong with the ESC or could the Novak 10.5 have something wrong with it that is causing this (sensor board problem?)?
joncmack is offline
Old 05-17-2014, 02:35 PM
  #6923
FastPete's Avatar
Leave the radio off or un plug the rx wire. Works fine.
FastPete is offline
  #6924
Just got my sct pro esc installed in my pro8 buggy. Tried hooking program box up and it goes to connecting to esc and never goes to next window. I left it hooked up for a few minutes and nothing. Anyone have any ideas?
scoobymx79 is offline
Old 05-17-2014, 02:50 PM
  #6925
FastPete's Avatar
Try to unhook the rx wire(wires from esc to reciever)
FastPete is offline
Old 05-17-2014, 02:54 PM
  #6926
That was the wire i had plugged into program box. Is that wrong do i need to plug into the fan port?
Old 05-17-2014, 03:01 PM
  #6927
Yes plug it into the fan port
Losi57 is offline
Old 05-17-2014, 03:08 PM
  #6928
My new SCT Pro only works with unplugged rx wire. It doesn't work with radio on or off. It's my first HW ESC which doesn't want to work with plugged rx wire. It's my 6th ESC from HW.
yacagree is offline
Old 05-17-2014, 03:24 PM
  #6929
Ok thanks
Old 05-17-2014, 04:30 PM
  #6930
FastPete's Avatar
Ok thanks
+1 fan port
FastPete is offline
