HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 05-13-2014, 09:30 AM
  #6886
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Micah123
anyone?
This might help got it from the Stock Spec info on their website.
http://www.hobbywing.com/service.asp?id=3
FastPete is offline
Old 05-13-2014, 10:05 AM
  #6887
Trader Rating: 26 (100%+)
Originally Posted by COBRARACING
Everything your doing is correct the reason why the lcd box wont wont when the rx cable is still in the receiver is the radio signal takes priority over the programmer so you either remove the rx cable from receiver or you disable radio signal .there must not be any radio signal input while programming with lcd programmer and thats because the 3 pin programming port is actually designed into thr receiver rx port as the mcu has only one pin that is used to program.
Thanks. Got it to work. Just used the HW3.42 computer software and updated the programmer until one of the 3 software programs worked. I do believe the ESC is running the "beta" software. I am impressed at how crazy fast the 4000kv 4 pole is. I run it in a durango 4x4 and have to get used to keeping up with the car LOL. it's a rocket.
tfrankito is offline
Old 05-13-2014, 10:06 AM
  #6888
Thanks but I am running 7.5 short course truck on indoor clay track. Setup sheets appear to be for onroad asphalt tracks.
Micah123 is offline
Old 05-13-2014, 01:44 PM
  #6889
R40Victim's Avatar
I just got the 150 amp ESC and installed in my T8E(8th scale buggy) The Motor needs to turn the opposite way(clockwise in stead of counter clockwise) Can I do this without a program card? It is mentioned in the manual, but not how to change it. It's under "advanced items"
R40Victim is offline
Old 05-13-2014, 02:04 PM
  #6890
FastPete's Avatar
The LCD card makes life easier. But I just looked at the instructions, and don't think you have to have it. Just follow the instruction's, and see if it will let you get to that parameter.
FastPete is offline
Old 05-13-2014, 02:48 PM
  #6891
nickdawg18's Avatar
Trader Rating: 33 (100%+)
I'm switching to hobbywing this year after I fried a brand new Tekin gen 2. I was told that I should get the sct combo to run in my buggy. I assume it's this model http://www.falconsekido.com/products...sct-pro-series
Is that the go to setup that everyone is running in buggy? Does it have more setup options? What makes it better then this model? http://www.falconsekido.com/products...ox-for-1-8-car
Thanks guys.
nickdawg18 is offline
Old 05-13-2014, 03:13 PM
  #6892
rcboy1's Avatar
Thanks guys.
That will work Nick, but you must get the Pro-D combo if youre running ebuggy. The rest of the combos have too short of a motor that is also too high kv. not 1/8th e friendly. I run the 150amp Xerun Combos (your second link, M6c or M6b).
Really the sct pro is just a smaller lighter esc thats more at home in smaller spaces. Really not much is different for adjust-ability. Other than that its a bit cheaper.
rcboy1 is offline
  #6893
Thanks guys.
The SCT Pro esc is a little smaller and is widely used in 1/8th scale, but can only be used upto 4s. The 150A is physically larger, but can handle 6s. The programming functions are exactly the same from what I know.
I use the SCT pro both in my 4wd SCT and E-buggy, and have had no issues so far.
I wouldn't say it is the "go to setup that everyone is running", but it is a very popular option, and very economical compared to other choices.
brew99 is offline
Old 05-13-2014, 03:28 PM
  #6894
Trader Rating: 18 (100%+)
it can be done with the setup button.just follow the directions to get into the setup menu and select the correct option by counting the beeps.it's a little confusing at first but once you get used to it its fine.
xxxntwv is offline
Old 05-13-2014, 03:35 PM
  #6895
nickdawg18's Avatar
Cool. Thanks man. You gonna be at dirtburners this Saturday?
Old 05-13-2014, 03:38 PM
  #6896
rcboy1's Avatar
You bet I will, as long as the track is dry. Hopefully will have the nitro car out too
rcboy1 is offline
Old 05-13-2014, 04:26 PM
  #6897
R40Victim's Avatar
IT WORKED! lol Thank you so much, I just had to reread the manual a few times to "get it" Got a little weird with longer beeps representing 5, but I got it.
Old 05-13-2014, 07:15 PM
  #6898
FastPete's Avatar
+1 Same combo I run in my EBuggy.
FastPete is offline
Old 05-13-2014, 07:17 PM
  #6899
FastPete's Avatar
Lol I been through the same thing.
FastPete is offline
Old 05-13-2014, 07:26 PM
  #6900
Trader Rating: 21 (100%+)
I run the SCTpro 120amp and a Tekin 1900kv motor with a 4s 30c lipo in my Mugen MBX6Eco. so far so good but only time will tell. just curious, what is a normal temp range for this esc and motor? I have it geared 14/44 running zero timing.
joel45acp is offline
