HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 05-11-2014, 07:54 AM
  #6871
cricha's Avatar
Originally Posted by kcobra
There were some issues with HW esc's and certain Tenshock motors.
Kcobra, I am using a Tenshock X802 V2 1850kv. Is this one of the motors that HW were having issues with?
Which firmware version does Hobbywing recommend for the SCTPro 120A with a Tenshock motor?
I hope you can help me answer these questions as I dont want to kill my new ESC.
cricha is offline
Old 05-11-2014, 08:44 AM
  #6872
No clue on specifics. Just going by the following post:
http://www.falconsekido.com/blogs/ne...enshock-motors
kcobra is offline
Old 05-11-2014, 09:42 AM
  #6873
mydudrevo's Avatar
Does hw make Orion's esc's? They are identical from the esc all the way to the program box. Yet they sell theirs for $299!!! That's just plain crazy.
mydudrevo is offline
Old 05-11-2014, 10:01 AM
  #6874
cricha's Avatar
I appreciate the prompt reply kcobra
cricha is offline
Old 05-11-2014, 12:52 PM
  #6875
lewis110's Avatar
Orion is made by Hobbywing. But the software is built to Orion's specs. The Orion has more features then the V2.1 but isn't advanced as the HW v3 series
lewis110 is offline
Old 05-11-2014, 05:29 PM
  #6876
have yal seen update problems with new update will not work with box but will with pc also brakes not as strong ?
to slow for you is offline
Old 05-11-2014, 05:40 PM
  #6877
mydudrevo's Avatar
Mine has been fine with the latest software installed on the box and installed on my SCT pro
Old 05-11-2014, 05:53 PM
  #6878
Trader Rating: 18 (100%+)
you have to load the correct firmware onto the box for the ESC that your using.the latest update decreases the default value for the braking percentage.
xxxntwv is offline
Old 05-11-2014, 06:34 PM
  #6879
every thing is updated both 3.42
Old 05-11-2014, 09:32 PM
  #6880
motoj550's Avatar
Trader Rating: 26 (100%+)
Just got a SC8 esc 1 month ago and has been running awesome, but all of a sudden today it felt like it was losing a little power, then started cogging really bad and has no reverse now, if you pick it up with wheels of ground it will spin tires but still not with the oomph it should have sit it back on ground and barely moves and still no reverse. my neighbor just bought the same esc so we hooked it up to my motor and works great so i know its not the motor, but when we hook my esc up to his motor it does the same thing, i've tried recalibrating esc and checked settings, anyone know of this problem with this esc, is it a common problem? is it toasted?
motoj550 is offline
Old 05-11-2014, 09:57 PM
  #6881
Slotmachine's Avatar
Your unit should be under warranty still if you bought a USA unit. You did not get it excessivly wet or anything like that did you? I mean like submerged under water.
Paul Rush
Slotmachine is offline
Old 05-12-2014, 07:28 AM
  #6882
motoj550's Avatar
Nope, don't run it anywhere near water, bought it at valuehobby. also when u turn it on it makes all the lights like it's suppose to but the motor doesn't make it's beeps though.
motoj550 is offline
Old 05-12-2014, 09:23 AM
  #6883
Default Set Up Sheets For Stock Spec
Have a Stock Spec esc and would like to take advantage of its capabilities. Running an sc10 sct with 7.5 tekin. Run on large indoor track in San Diego with medium to high bite surface. Are there any set up sheets available that I can test?
Micah123 is offline
Old 05-12-2014, 10:02 AM
  #6884
Trader Rating: 31 (100%+)
I have 3 V3.1 Stock spec ESC's and 1 Justock ESC. When I plug the Justock into the programming box, it says I need to update the firmware. Is it as simple as just plugging the Justock ESC and box into the computer, or do I need to download some additional firmware to the box to use with this ESC? If I need to download, can someone post the link to what needs to be downloaded.
joncmack is offline
Old 05-13-2014, 07:26 AM
  #6885
anyone?
Micah123 is offline
