HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#6751
The EZRUN-150A-PRO does resemble the 120A however its quite a bit larger and if you are using in 1/8 scale you will want to make sure it will fit in your 1/8 scale vehicle. I've attached a link below and if you click on the ESC and check the specs you will see the size measurements. The EZRUN-150A-PRO is better for 1/5 scale applications.
The EZRUN-150A-PRO is actually the most inexpensive (at this time) between all the ESC's you mentioned. I've attached a link for the ESC's and their prices and specs. See below.
http://www.falconsekido.com/collections/1-8th
#6752
Thanks for your help. It looks like the Orion version has some different specs. So is it really the same as the EZRUN 150A Pro?
#6754
what is the latest no timing (aka stock, aka blinky) software?
V3_508_No Timing
or
V3.0_110930STOCK
V3_508_No Timing
or
V3.0_110930STOCK
#6755
#6756
#6759
Last evening my 1 month old Xerun 150A esc went up in smoke.
I had it installed in a TLR 8ight-E 3.0 with a HW 2200kv motor (esc/motor bought as a combo set).
Savox 1256 servo.
Sanwa MT4s and RX472 receiver.
Capacitor installed in receiver (the setup runs fine without the capacitor though).
Esc updated with latest software (as of 1 month ago). Different than default settings: FOR/BR, LVC 3.0, PUNCH 4, LIPO CELLS 4 (we run 4s setup).
Hobbyking Nano Tech 4s lipos used many times before (and after).
This happened on the second lap in 17 degrees celcius temperature, so heat could not have been an issue.
This was my sons car. I have an identical car (Futaba BLS351 and a Sanwa M11X/RX451R receiver, no capacitor as the only difference). This has been running for about 6 months with no issues.
I live in Nothern Europe and bought the HW combo set in Hong Kong, so I'm not go bother sending it back.
The car just stopped before a jump and rather thick smoke poured from the car. I first though it was a lipo fire and ran to the car, tore the body off and disconnected the lipo. Was afraid the whole car was about to go up in flames, maybe not the smartest thing to do.
But it was the esc. The positive wire had come off due to the heat, and the esc was black around the sensor socket and the whole track smelt of burned electronics.
I'm quite maticualte with my cars, keep them clean and inspect them after each pack etc. and just in general are very aware of any small details that could indicate problems. Also wiring, cuts, wear etc.
I would say that the car was in tip top condition.
As mentioned, I'm not going to make a warranty claim, I'm just curios what could have caused such a massive "melt down" on a virtually new esc?
I know it probably is almost impossible to make factual statements, but I would like to know, if just remotely possible, if there is anything I can do to prevent this from happening again.
Off course there is always the case of just a bad esc going up in smoke.
A fellow racer at the track had a new Xerun 150A esc with him, which I bought on the spot and installed it to get my son going.
The burned esc thankfully did not fry any other electronics, and the car and all electronic components worked perfectly after installing the new Xerun 150A esc.
Savox 1256 servo.
#6761
Salkin:
Just asking....you failed to mention your gearing when this happened, do you remember what it was? I don't think I have ever seen a HW go up in smoke, I'm not saying it never happens though. When you think of how many of these items are produced you are bound to have the occasional failure. I'm happy to hear you have not given up on our product's, but I'm not happy you are having difficulties.
Paul Rush
HWNA
Team Driver......
Paul Rush
HWNA
Team Driver......
#6762
Salkin:
Paul Rush
HWNA
Team Driver......
Paul Rush
HWNA
Team Driver......
Forgot to mention, that at the track at the time of the break down, there were 4 other drivers with HW Xerun 150A's looking a little anxious :-)
#6764
