HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#6736
hey guys. just finished up my dex210 2wd buggy.
im using a v2 speedo. The thing is that its a very tight fit with the fan on. it touches the body. Can i use the v2 without the fan?
im using a turnigy trackstar motor 8.5 t.
and what firmware do you recommend? i just flashed the esc to the 930-stock firmware. Is this one a good starting point for 2wd buggy?
thanks
thanks
#6737
thanks a lot guys!
#6738
I need help please, I bought a hobbywing xerun 120a v2.1 paired with a smc 7.5 motor.
I calibrated over and over, but the motor accelerates by itself. Not sure why?
Receiver was binded as well. I give it a little throttle or no throttle and it accelarates once more by itself. Running on 2s saddle packs, thanks
#6739
Can you put the extreme stock speedo in blinky mode and if so how. I have the programming box. Thanks
#6740
How to update firmware in a Hobbywing Xtreme stock: http://youtu.be/K2DyK-zTduY
Here's a link to the PC program. http://www.hobbywing.com/product_show.asp?id=218
Roger
#6741
#6743
Hi all!!!
I have a short course 1/10 truck and a 35 amp 300kv 13 turn brushless system from the ez-run series. So far so good
, but is it possible to run a 3s lipo off-road without upgrading the fan??? so far on 7.2 volt nimh's the esc has never got hot (or even warm) and the motor sometimes gets a little hot...
#6746
#6748
What are the options for changing settings on the EZRUN-150A-PRO?
What is required for this as well?
Why does it look like the 120 costs more than the 150 version?
Computer and cable or Multifunction LCD Program Box and software/cable
#6749
Just purchased this esc can anybody give me some info on it and is there anyway to know which version it is.
