HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 04-18-2014, 05:34 PM
  #6691
hlpressley's Avatar
Trader Rating: 209 (99%+)
Trying to setup my SCT Pro for the first time. When I hook it up to the Programming Box it will not go past "connecting ESC" screen. Any ideas?
Thanks in advance
hlpressley is offline
Old 04-18-2014, 05:51 PM
  #6692
Trader Rating: 52 (100%+)
Thanks in advance
What motor? Try and disconnect the sensor wire.
tonyd is offline
Old 04-18-2014, 05:53 PM
  #6693
FastPete's Avatar
Trader Rating: 44 (100%+)
Thanks in advance
Battery hooked up, esc on, plugged in fan port correctly, push the button to connect? Is it the lcd box?
FastPete is offline
Old 04-18-2014, 06:19 PM
  #6694
hlpressley's Avatar
Trackstar 1900KV
Plugged in fan port? Not sure I follow you there? ESC powers on and runs fine, just can't seem to get the program box to connect to the ESC. Program box seems to work fine on other ESC units. It is the LCD box.
Old 04-18-2014, 06:23 PM
  #6695
Have to connect through the fan port, where the fan plugs into the ESC or else it wont program.
https://www.youtube.com/watch?v=NIOHLyyyr_8#t=386
Zonk is offline
Old 04-18-2014, 06:42 PM
  #6696
hlpressley's Avatar
Ahhhh, I had no idea. I was trying to do it through the wire that connects to the Rx like I've done on my 90A and Just Stock. This worked great though! Thanks for the help guys!!
Old 04-18-2014, 07:38 PM
  #6697
FastPete's Avatar
Glad you got it.
FastPete is offline
Old 04-19-2014, 07:01 AM
  #6698
ILRacer's Avatar
Trader Rating: 32 (100%+)
Default XERUN 120a V2.1
When are these coming off B/O everywhere I check they are out of stock. I won't order from overseas ever. Can anyone help need 2 and 2 fans plus 2 LCD program cards. Would prefer black but Blue will work unless there is a difference. Also do you need an external BEC my servos run at 6.0v x 3.0 amp.
Thanks,
Mike
ILRacer is offline
Old 04-19-2014, 08:24 AM
  #6699
FastPete's Avatar
Thanks,
Mike
I will check for you Mike
FastPete is offline
Old 04-19-2014, 04:53 PM
  #6700
COBRARACING's Avatar
Happy easter to everyone from us at Hobbywing
COBRARACING is offline
Old 04-19-2014, 06:06 PM
  #6701
FastPete's Avatar
And same to you and everyone
FastPete is offline
Old 04-19-2014, 06:15 PM
  #6702
Yes, a very Happy Easter to you all
(my first post)
and I have a question
Using HW SC8WP 120a esc and HW 4700kv 4pole in Savage xs
esc is constantly cutting out or reducing power
Is the amp draw of this motor, in this heavy truck with limited gearing options, too high (in another context I would just gear down)
Using 24T pinion (the smallest I can) and smallest gearbox options
only turn and burn in the receiver, with a hitorque mg Savox or Hitec
So my real question is do I need to drop down to the 3400kv (less amp draw) and is anyone else having trouble making the most of this combo
ryomaktm200 is offline
Old 04-19-2014, 06:31 PM
  #6703
FastPete's Avatar
(my first post)
Same to you and welcome!
FastPete is offline
Old 04-20-2014, 12:28 AM
  #6704
(my first post)
Isnt that setup more for 1/10scale shortcourse and the like, where as a savage is 1/8 scale so you would need the 1/8 scale motors which are physically bigger i believe and not sur if that ESC would handle the 1/8 scale motors, this is just my guess, I am new to the electric side of this but I just bought that setup for a shortcourse 4wd 1/10 scale.
SIKE00 is offline
Old 04-20-2014, 04:13 AM
  #6705
Sike00 thanks for sharing your experience
actually there are different HPI Savage RC's,
this setup is in the Savage xs as stated in the post, (not in the much much bigger Savage 1/8 that you refer to)
the xs is a heavy machine, rather strange because it's 1/12 or so in size but handles like
a 1/8, motor space is restricted to 56 millimeters lengthwise hence the use of the HW 3656 motor
but I'm having a lot of trouble with the 4700kv hooked up with the SC8 esc,
so I'd be interested to know how it works out in your SCT, as it seems the 4700kv has a pretty hefty amp draw. So what batt are you using, what gearing and what kind of run times are you getting,
anyway a BIG thanks to the HW techs for this amazing thread...
