HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 03-17-2014, 03:12 AM
  #6256
lewis110's Avatar
Originally Posted by SouthFloridaApp
Need some advice. I have a stock Tekno SC410 with a Hobbywing SCT combo which includes the 4700KV motor. I am using a 16 tooth pinion and 7200 mah new batteries from SMC. This past Saturday at the races my car stopped after about four minutes. About thirty seconds later is went again. The same thing happened in the main, but more frequently as we race for ten minutes. My battery voltage after the ten minute main (I ran for about 7 minutes) was 7.53 volts. I did not take the voltage after the second qualifier, but it would surely be higher than 7.53 volts due less run time. I temped the motor after the qualifier and the main and it was approx. 120 degrees both times. Should I go down one tooth on the pinion gear to a 15 tooth? Should I get a higher mah amp battery? Should I get a fan for the motor? Is there anything I can do to the esc settings? FYI I have been playing with the ESC drag brake setting.... if memory serves I have it at 40 or 30 with the programming card...Everything else is pretty standard. I was thinking of taking off the rear bumper to save weight. No nose dive issues for me.... Please advise.
Post your settings, what's your LVC set at?
lewis110 is offline
Old 03-17-2014, 06:36 AM
  #6257
Trader Rating: 25 (100%+)
Originally Posted by Johnny-RC
But I could be wrong.....
1 might be 50% for all I know lol which would mean each step would be 5.55%
2 would be 55.55 ect. ect....
Yea i guess 120% would be hard to attain. Lol. Knowing that starting point for level 1 would be nice to know. Not required but, nice for reference point. Do Hobbywing folks monitor this forum?
mconway is offline
Old 03-17-2014, 07:28 AM
  #6258
CENTRAL's Avatar
Hi there!
It's really nice to have this kind of support available...
I am considering an upgrade from brushed motor & ESC to a Hobbywing X9B combo. Problem is that I seem to have a limited space for an esc on my car (a Kyosho EP Fazer Kobra). The current ESC is a Perfex KA-16H ESC which measures 30.2x33.7x16.5mm.
How do I deal with the issue?
CENTRAL is offline
Old 03-17-2014, 07:36 AM
  #6259
FastPete's Avatar
Trader Rating: 44 (100%+)
Post settings, but lower the LVC that's most likely it.
FastPete is offline
Old 03-17-2014, 08:17 AM
  #6260
5th wheel's Avatar
I have a question. to turn off turbo if you do not want turbo I don't see a disable feature so I am guessing that on turbo if you do not want it to come in you would set the setting at 0 when you get to the turbo parameters in the ESC is this correct? I would like to try using boost only just trying to figure out how to turn off the turbo thanks for the information
5th wheel is offline
Old 03-17-2014, 08:19 AM
  #6261
5th wheel's Avatar
turbo I am talking about is on the v3.1 esc
Old 03-17-2014, 09:31 AM
  #6262
Trader Rating: 18 (100%+)
For anyone running the sct pro and hw 4700 kv motor in a scte/mip. What is your gearing?
cm03 is offline
Old 03-17-2014, 09:59 AM
  #6263
Trader Rating: 90 (100%+)
13 or 14 works well although I prefer 14 to remove some of the excessive wheel spin.
Kuya_Kimo is offline
Old 03-17-2014, 10:06 AM
  #6264
Trader Rating: 111 (100%+)
Drop the LVC to 2.8v and see what happens. That's what I had to do because I was having the same issue. That fixed it for me.
eddiemoney13 is offline
Old 03-17-2014, 10:19 AM
  #6265
FastPete's Avatar
Same thing I used to use a 13-14 in mine.
FastPete is offline
Old 03-17-2014, 11:28 AM
  #6266
lewis110's Avatar
That's correct just set the turbo to zero if you don't want to use it. I personally use very little turbo and just put the boost to it. It depends on how aggressive you have the turbo set but its real easy to spin the tires. With just boost you get a very linear feeling of throttle. If you would like more help on this pm me or email me at lewisracecars @gmail.com
Roger
lewis110 is offline
Old 03-17-2014, 12:08 PM
  #6267
Did you happen to temp the ESC? Any hot/burnt smell? Did you have steering for the thirty seconds it was not running?
I've seen this in the past and it was the fan on the ESC not working or not plugged in. It will cause the ESC to overtemp and cut off.
offroadlover is offline
Old 03-17-2014, 12:13 PM
  #6268
dan_vector's Avatar
Trader Rating: 27 (100%+)
Hi guys. I have a v2.1 90A driving a Speed Passion 13.5t V3 motor in my 4wd 1/10 buggy. How far can I push this setup sensibly to get the maximum punch and straight line speed out of it?
Can anyone provide some guidance and preferably a good starting ESC setup using STOCK software on the v2.1?
dan_vector is offline
Old 03-17-2014, 12:27 PM
  #6269
Thanks for the quick responses guys. And Pete, got my motor today, great service as usual.
cm03 is offline
Old 03-17-2014, 01:39 PM
  #6270
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
will the xerun 90a run a 4 pole 550 motor 4500kv in a scte?
84 GT 5.0 is offline
