HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 03-07-2014, 02:04 PM
  #6151
I have an issue with hooking up my HW 120A ESC WP SC8 when its installed in car.
Is it true that it (receiver) has to be unplugged from esc when programming box is plugged into esc fan power port. I can't get esc to talk to prgrm box unless receiver is unplugged.
My receiver is in a waterproof box and unplugging it from esc cord is difficult and time consuming since its soldered to esc on one end and solid wire into receiver waterproof box on the other. I have to remove box lid which is restricted by roll bar etcc..
RASHER is offline
Old 03-07-2014, 03:40 PM
  #6152
Slotmachine's Avatar
Lets all welcome Bobby Stroud to the HWNA team here on the East Coast. Bobby will be racing at Bumps and Jumps this Sat. if anyone there needs help with their HW equipment look him up......
Slotmachine is offline
Old 03-07-2014, 04:05 PM
  #6153
FastPete's Avatar
Trader Rating: 44 (100%+)
Welcome to the team, congrats to both!
FastPete is offline
Old 03-07-2014, 09:00 PM
  #6154
hlpressley's Avatar
Trader Rating: 209 (99%+)
Looking for recommendations for an ESC for my T4.2. Will be running in a mod class on a medium sized outdoor track. Will most likely run a 13.5 but possibly down to an 8.5. I have ran the JustStock in my B4.2 with 13.5 and had great success. Was thinking of trying the Xtreme Stock in the truck. Thoughts?
hlpressley is offline
Old 03-07-2014, 09:12 PM
  #6155
FastPete's Avatar
Xtreme would work perfect for 13.5. For a 8.5 I would go 90A to be safe.
FastPete is offline
Old 03-08-2014, 09:27 AM
  #6156
I updated my SCT Pro and my programmer box to the latest. Now, when I try to connect to the ESC it says "Please upgrade software". What software is it referring to and how do I fix this?
Overtorqued is offline
Old 03-08-2014, 09:47 AM
  #6157
FastPete's Avatar
You have to upgrade the esc and box. Theres a drop down at the top of the screen in the software to pick the esc or card you want to upgrade.
FastPete is offline
Old 03-08-2014, 10:42 AM
  #6158
Sir, I upgraded both. What I did find was that going back to older firmware in the box allows it to connect. It just doesn't make any sense. This is an SCT Pro and I was using the newest version it said to for that (the one that doesn't end with V3).
Old 03-08-2014, 12:12 PM
  #6159
Is the Xerun stock spec v3.1 capable of timing and turbo boost? What is the difference between the stock spec version and the Xerun 120 amp v3.1?
dozer9 is offline
Old 03-08-2014, 02:15 PM
  #6160
FastPete's Avatar
What version are you using on the card and esc. I just updated my SCT Pro and works fine.
FastPete is offline
Old 03-08-2014, 02:20 PM
  #6161
FastPete's Avatar
Stock spec is 100A and alittle less burst rate. 120A you can run down to a 3.5T. 120A is a all aluminum case, and alittle finer adjustment. Their both great.
FastPete is offline
Old 03-09-2014, 01:36 PM
  #6162
I recently installed a new Xerun 120 SCT Pro in my brushless Emaxx. It ran fine for a couple weeks and the front bearing went in the motor. I replaced the bearings and now either the ESC or the motor does not work. When I turn the ESC on I get a steady Red light, then 4 green flashes but no audible tones. the steering works, but when I hit the throttle I get nothing. Only the red light on the esc lights when I hit the throttle, but no movement by the motor.
Any idea where to start to troubleshoot this? I dont have a spare motor or ESC to swap out...
I connected the programming box and reset it to default, but that didnt change anything.
where do I start?
wreckmster is offline
Old 03-09-2014, 04:16 PM
  #6163
FastPete's Avatar
where do I start?
New sensor wire, reset your end points, check all the wiring. And lets go from there.
FastPete is offline
Old 03-09-2014, 04:28 PM
  #6164
Can someone answer the question I posted below regarding connection between reciever, esc and programming box.
RASHER is offline
Old 03-09-2014, 04:32 PM
  #6165
Fegbri46's Avatar
Mine stays connected.
Fegbri46 is offline
