HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 03-01-2014, 06:54 AM
  #6121
Trader Rating: 28 (100%+)
Originally Posted by Slotmachine
Are you running Deans connectors? I saw this 2 times over the weekend, we replaced the plugs and the problem went away. I have the imitation deans and they are tighter.http://www.ebay.com/itm/20-PAIRS-DEA...item4acf8298a5
^ What he said.
I run these as well and they are are so tight that they are extremely hard to get plugged in and back out when new (good thing).
If you have loose connections with high resistance and then try to pull big current on a high traction surface it can cause the ESC to see sub LVC voltages even if you pull the battery and meter it at 3.6v
treys1 is offline
Old 03-01-2014, 08:57 AM
  #6122
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
I always recomend turning off your lvc for racing, this way you wont run into the problem of accidentaly hitting the cut off when the voltage dips under high stress loads near the end of a race.
Blitzrockey is offline
Old 03-01-2014, 01:11 PM
  #6123
FastPete's Avatar
Trader Rating: 44 (100%+)
Agree you should know how far you can go if your racing only.
FastPete is offline
Old 03-01-2014, 02:52 PM
  #6124
Trader Rating: 15 (100%+)
Originally Posted by FastPete
About a week.
Any updates?
YMMV is offline
Old 03-01-2014, 04:14 PM
  #6125
FastPete's Avatar
Originally Posted by YMMV
Any updates?
Crossing my fingers for the end of this week They go quick, got 4 coming, 3 left get your name on one.
FastPete is offline
Old 03-01-2014, 07:23 PM
  #6126
Originally Posted by AlanHall
i had the 4000 before and was just thinking of trying something else.
I just swapped out to the 3400 and like it on our indoor clay track. I gear up one from what I ran using the 4000. More controllable and runs even cooler. On a large outdoor track I'll throw the 4000 back in.
JASF4I is offline
Old 03-01-2014, 07:29 PM
  #6127
FastPete's Avatar
Think that was what Alan was looking to hear-confirm thanks!
FastPete is offline
Old 03-01-2014, 10:45 PM
  #6128
Hello, guys
I just install the 90A V2.1 into my Serpent SRX-2 with V10 8.5T. I am wondering which update program should I update for my 2WD buggy and what set up should I follow if available?
Cheers
Jason
L.DENG is offline
Old 03-02-2014, 06:28 AM
  #6129
Thanks, just placed my order.
YMMV is offline
Old 03-02-2014, 04:40 PM
  #6130
5th wheel's Avatar
Jfuel
Need a little more help or advice
running a chaos race at my local track it's a points race. I need more power out of my 17.5 Novak.
Going to try your mild boost setup 72/31 the motor I am using is a Novak with a 13mm rotor and a ultra low resistance stator. 17.5. Or I can use my other motor which is a Novak 17.5 with a 12.5mm rotor and a high rpm stator. Which one would be better? I need to keep up with a 8.5 and 13.5 motor that the other 2 guys are using. Most of us are 17.5 I don't know why they let a 8.5 and 13.5 in this class. But it's fun any way.
5th wheel is offline
Old 03-02-2014, 06:30 PM
  #6131
Running 2wd SCT with the XERUN STOCK Spec ESC V3.1, and a Speed Passion 10.5 MMM Competition Motor. I am looking for setup suggestions or help for the ESC for outdoor clay, and indoor carpet offroad small and tight. Completely new to brushless and sensored so any help is appreciated. Running these in a Kyosho Ultima SC...Looks like most of the setups with the program box are buggy or 1/8....
kevmtnbiker is offline
Old 03-03-2014, 07:19 AM
  #6132
AlanHall's Avatar
Trader Rating: 43 (100%+)
sweet, i was thinking of ordering both . if the 3400 bad on a larger track or you just prefer the 4000?
AlanHall is offline
Old 03-03-2014, 11:23 AM
  #6133
FastPete's Avatar
Think theses some setups JFuel posted back some pages. If you cant find them I will try to look later.
FastPete is offline
Old 03-03-2014, 12:01 PM
  #6134
hobdog's Avatar
Trader Rating: 19 (100%+)
Anyone running a 150a with six cell in ebuggy? I am looking a doing it and was hoping others were having success with this speedo
hobdog is offline
Old 03-03-2014, 01:39 PM
  #6135
tc5 man's Avatar
Well i ran at a indoor track was really hard packed Clay/dirt surface and the SCT Pro esc was acting like a bad cogg during practice and into my third heat. and i couldnt finish the race it was aggerating . So i turned off the lipo cutoff and turn down the punch control and reset the esc and it was fine in the main . There was no loose wires or anything i checked .
It was with the Tenshock motor a unsensored one . Im going with the Hobbywing 4000kv or 4700kv motor a sensored one. Tired of unsensored motors acting up.
My only question is should i just set the lipo cutoff at 3.0v and not 3.2V ? I mean there was no way it should of kicked in with the lipos i have.
tc5 man is offline
