HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 02-16-2014, 07:04 PM
  #6031
COBRARACING's Avatar
Originally Posted by BlackStarRacing
had a funny thing happen to me tonight hooked up my 2in1 box and it wouldn't connect to my sctpro.... yet when i connected it to my laptop it conned the esc as well as the box..... Any ideas?
Did yoy plug into the esc while the esc was powered or did you switch
Them on both at the same time?sometimes it tends to do that when you plug it in while esc is powered no often but it can happen
COBRARACING is offline
Old 02-16-2014, 07:25 PM
  #6032
patrick lsp's Avatar
Trader Rating: 191 (100%+)
Default xerun sct pro
anyone running this with 1/8 ebuggy? rx8 died at the track, and a friend had this.. it says 1/10 and 1/8 scale. set it up and ran about four or five laps and then it shut off. I am running dx3r, spec rx , savox 1256 servo, and tekin 1900. pretty new to electric. set it up with a programming box. pretty much default settings. any ideas.
also just bought a tekin 2050. will this esc push it?
installed in a losi 3.0e stock spur and 16 pinion.
will this speedo do what I need or should I try something bigger?
patrick lsp is offline
Old 02-16-2014, 07:29 PM
  #6033
nitro_mt_racer's Avatar
Trader Rating: 240 (100%+)
We're running the sct pro in our ebuggy, 8ight-e 2.0 with tekin 1900kv on 4s with no issues.
nitro_mt_racer is offline
Old 02-16-2014, 07:48 PM
  #6034
FastPete's Avatar
Trader Rating: 44 (100%+)
Same combo I run to a tee with the Tekin motor. EBuggy, for a year and a half now. Might have to lower the LVC. I have mine set to 3.0 no issues.
FastPete is offline
Old 02-16-2014, 10:33 PM
  #6035
nm
Yello is offline
Old 02-16-2014, 10:57 PM
  #6036
tc5 man's Avatar
Figured out after a 3 race event that the Tenshock non sensered at least does not work right on the SCT PRO .
It seems to struggle at a stand still on the throttle about 2 secs or so. I had the punch control on number 4 and it didnt make a diffrence . Just not that punchy really especially getting on the throttle .
And it did that shot gun powerband if you know what i mean .
The motor seemed to work much better on the BH lt4 esc.
Im going to get the Hobbywing 4700kv sensored motor anyways .
tc5 man is offline
Old 02-17-2014, 09:53 AM
  #6037
Lower your lvc to 3.0 and disable your overheat settings .
Losi57 is offline
Old 02-17-2014, 12:32 PM
  #6038
Pygmy's Avatar
Originally Posted by JFuel11
The 3656SD is a beast of a motor. I run one myself in my 4x4SCT. The Low Voltage Cuttoff is most likely kicking in because for a very brief moment you battery voltage is getting pulled down below the cutoff voltage under heavy acceleration. I run my LVC set to 2.8V per cell and even after a full practice session where I run my Lipo down to cutoff, My lipo voltage at rest is around 6.4 to 6.5 volts.
Also, what truck are you running it in and how do you have it geared?
Alan
Had a brilliant raceday yesterday where for the first time everything behaved like it should. Setting the LVC to 2.8 was definitely the solution.
Cheers !
Pygmy is offline
Old 02-17-2014, 01:24 PM
  #6039
tc5 man's Avatar
Has anybody noticed with this ESC running on the 4x4 SC the brake force feels soft ?
I put 75% brake force setting on this ESC and more brake on the radio it still felt like it was to soft .
Maybe a 100% Brake force is better im thinking .
tc5 man is offline
Old 02-17-2014, 06:39 PM
  #6040
FastPete's Avatar
Cheers !
Great to hear glad your enjoying it!
FastPete is offline
Old 02-17-2014, 06:40 PM
  #6041
FastPete's Avatar
Hmmm I run mine at 70% and the EPA at 67% what motor?
FastPete is offline
Old 02-17-2014, 06:52 PM
  #6042
I have some other issues.
I ran my buggy in the snow today. But then it stops and doesn't run.
I can turn the servo. When I throttle, I can see the ESC light red. But there's no motor response.
Also, when I turn the XERUN on, I can see the 4 green flashes of light, but it doesn't make a beep noise.
What's going on here? Has water gotten into the ESC? The XERUN is supposed to be splashproof, and it was just snow, not puddles.
Yello is offline
Old 02-17-2014, 06:56 PM
  #6043
Trader Rating: 17 (100%+)
Hey man called several times today in the morning and evening with no answer. Tryed to leave a message but your voicemail is full. Having an issue with a motor i purchased from you in sep. 2013.
JoshC90 is offline
Old 02-17-2014, 06:57 PM
  #6044
Believing it to be about water, I turned my buggy (and the ESC) upside down completely, and guess what happened?
My ESC smoked up ferocious and now my kitchen smells like an electrical fire.
Thanks, Hobbywing.
Yello is offline
Old 02-17-2014, 07:06 PM
  #6045
FastPete's Avatar
? Who
FastPete is offline
