HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 01-11-2014, 07:05 PM
  #5566
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Well Done!!!
Originally Posted by Borik
SCTE is finally finished with HW SCTPro and HW4000kv motor. Track time tomorrow but gave it a test run on the street....this thing produces loads of low and top end power. I'm very please, can't wait to get it on the track. Thx to all for the program help, much appreciated.
Will be a shame to get that thing dirty...
Looks good. I ran the SCT Pro in 1/8 buggy tonight and that esc is just rock solid!!!
Love me some SCT Pro ESC!!!
Alan
JFuel11 is offline
Old 01-11-2014, 07:50 PM
  #5567
FastPete's Avatar
Trader Rating: 44 (100%+)
Alan
Yes sir! That's what I will be running tomorrow, love my SCT Pro in 1/8. Kinda quiet there tonight, will be busy tomorrow. Hope you had fun.
FastPete is offline
Old 01-11-2014, 08:59 PM
  #5568
FantomLeopard's Avatar
I'm running a 1/10th 2wd Buggy with an old 7.5 (possibly buying a new 8.5/9.5 motor) and I gear it to run fairly cool. It's a B4.1 and I have it at 81/22. Would I be okay running the Stock Spec (100 amp I believe) esc? My other ESC recently was decommissioned (fire has a way of doing that ) so I'm in the market for a replacement..
FantomLeopard is offline
Old 01-11-2014, 09:12 PM
  #5569
FastPete's Avatar
Would work real well.
FastPete is offline
Old 01-11-2014, 09:18 PM
  #5570
sweet! I just want to make sure I don't need to spend the extra $50 and get the 120amp one Now I'll be able to afford the programming card that goes with it!
Old 01-11-2014, 09:27 PM
  #5571
JFuel11's Avatar
Default Yes... Will be a great combo!
I race a B4.2 and C4.2 in Mod Buggy every weekend and really like the V3.1 ESC Line. It comes in the 120 AMP version and the Stock Spec 100 amp version. In a 2wd buggy the 100 amp will run cool with no fan and perform great.
I really like the V10 Mod motors as well. They are super smooth but turn up the timing and they make killer power as well. I would suggest the 8.5 for most applications.
For gearing I have found that 81/23 or 24 is usually perfect for 8.5 on most tracks you would run 2wd buggy on.
Good Luck!
Alan
JFuel11 is offline
Old 01-11-2014, 09:41 PM
  #5572
Good Luck!
Alan
Sweet thanks for the help! Luckily for me the ONLY pinions I have are 22, 23, and 24 so this works out great
Old 01-12-2014, 08:02 AM
  #5573
Alan
Yea they sure are pretty when they're new. Lucky for me my local track is indoor clay...either way she's gonna get worked at the track.
Borik is offline
Old 01-12-2014, 08:56 AM
  #5574
Alan
+1. Been running the SCT-Pro in E-truggy with no issues. At least once a month I see $200+ ESC's go up at the local tracks. My HW Xerun's just keep on ticking.
kcobra is offline
Old 01-12-2014, 03:03 PM
  #5575
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Good Luck!
Alan
Hey Alan can you post your settings for your 2wd I was kicking my rear out to the left all day... I have the v3.1 stock in it...
Daryl
BlackStarRacing is offline
Old 01-12-2014, 05:04 PM
  #5576
I have a hobbywing stock spec v3.1 i would like to put the setting in blinky mode.i put the esc in profile 2 which said no timing also set the turbo to 0. And saved the setting to the esc. Wondering if these is put into,blinky mode? ALSo is there a way to tell by the lights on the esc? So you don't have to put the program box on there.?
kjsea is offline
Old 01-12-2014, 06:22 PM
  #5577
JFuel11's Avatar
Default Yes...
As long as you saved the settings to the esc and are on the no-timing profile then when you turn on the esc the red light should blink on the switch.
Good Luck
Alan
JFuel11 is offline
Old 01-13-2014, 08:39 AM
  #5578
Big thumbs up to HW. Ran the SCTE yesterday at the track, esc and motor ran flawlessly. I tinkered a little more with the esc settings and pinion gear and man this thing rips. Loads of power at all ranges. I run the 4000kv motor and there are guys with slightly bigger motors however there trucks seemed way over-powered for there skill level. 4000kv suited my driving style perfectly. Plenty of power to clear jumps and plenty of (controllable) top end speed. Love the simplicity of having the programming box...makes little esc changes much easier.
Ran 4 packs for practice and 3 races. Anyone out there on the fence on which esc/motor combo to get....Go with HW products. For the price you get top quality products.
Thats coming from a non sponsored...weekend racer. I'm guessing anyone who has had issues with HW products came from user error (improper installation, improper gearing/set up or improper platform).
Borik is offline
Old 01-13-2014, 08:56 AM
  #5579
JFuel11's Avatar
Default Great Info!
Thanks for the update. The 4000KV set continues to impress many including myself. I have now tested the 4000KV and the 4700KV and all I can say is the 4700KV is a beast! If you are looking for sick power go with the 4700KV. If you are looking for smooth consistant power that really doesn't give anything up anywhere... go with the 4000KV... Can't lose either way.
JFuel11 is offline
Old 01-13-2014, 09:01 AM
  #5580
JFuel11's Avatar
Default Will Post Tonight...
Daryl
Daryl,
I will get two setups posted tonight... Low and medium traction Mod buggy.
Alan
JFuel11 is offline
