HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 01-11-2014, 04:12 AM
  #5551
Trader Rating: 33 (100%+)
Can anyone tell me where I can find a new sensor board for my 3656sd 4700?
rccrazy19 is offline
Old 01-11-2014, 05:59 AM
  #5552
GEB
New here, I havent raced elec in about 20 years.
Glad I found this site!
I've got a V3 ESC and gonna need some advice getting it set up.
Anyway just thought I'd pop in and say hello!
Gene
GEB is offline
Old 01-11-2014, 07:11 AM
  #5553
Originally Posted by COBRARACING
As long as the radio input is at zero (no signal neutral)then you do not need to disconnect rx wire from receiver.
The rest is fine.
well, mine was different after update the esc fw.
the trick is before the esc detects lipo cell, immidiately press ok button on your program card to enter setup mode, after that save it
sometimes the TX cannot put neutral range correctly
j3fron is offline
Old 01-11-2014, 12:30 PM
  #5554
hugin_q3's Avatar
Default Hobbywing XERUN-SCT-PRO and failing to connect to USB Link software
Hello HK Support. I need some assistance to get my new ESC to connect to the USB Link PC Program. So here we go:
Hardware used:
Multifunction LCD Program Box, P/N = 30502000014
Hobbywing XERUN-SCT-PRO (Black), PN = 81020262
Software used:
Hobbywing USB Link V.3.2
Hobbywing USB Link V.3.4
I am sitting here with my 2nd SCT Pro (Black Ver.) and cant get connected to the ESC. When I started up HK PC program it recommended me to update the LCD box to: V1.14_130508, so I did. And I did check, it said in the read me file it was compatible with the ESC also:
(...) Here we release the new firmware V103_130806-Beta for XERUN-150A, XERUN-SCT-PRO, EZRUN-150A, EZRUN-WP-SC8 ESCs, and following improvements have been made on the former version (...)
Code:
readme.txt
2013-12-02
CAR_ESC_readme.txt
Firmware Revision History:
2013-11-30
database version:130814
Here we release the new firmware V103_130806-Beta for XERUN-150A, XERUN-SCT-PRO, EZRUN-150A, EZRUN-WP-SC8 ESCs, and following improvements have been made on the former version:
1 	Excellent startup performance at low RPM greatly improved the linearity.
2.	The acceleration is much quicker than before. The new firmware eliminates the discontinuous speed jump in the old firmware,
	now its control feeling in sensorless mode is very near to the control feeling of sensored brushless system.
3 	Compatibility with Tenshock sensored motor has been observably improved.
4. 	Supports motors with higher KV. The new firmware solves the trembling problem occurs to some high RPM multi-poles (>=4 poles) motors at part throttle.
5. 	The new firmware is ¡°SAFER¡± than the old one.
a) 	It doesn't allow the neutral throttle point coinciding with the full throttle point, while the old firmware allows user to set them to a same point. Therefore, the new firmware eliminates the possibility of unexpected full-speed running when the ESC is switched on. Undoubtedly, it makes the whole system safer for users and crowd nearby.
b) 	When the ESC is switched on, the motor can be started ONLY if the ESC detects the throttle signal is correctly in the neutral range. If the throttle signal is out of the neutral range, then the motor cannot be started. This also makes the entire system more secure for RC car drivers and people close by.
USB_Link_readme.txt
2013-11-30
Software version:V3.4
1 Database Version for RC Vehicles has been updated to ¡°130814¡±;
New Firmware Program for XERUN-150A, XERUN-SCT-PRO, EZRUN-150A-PRO, EZRUN-WP-SC8 ESCs has been released, that greatly optimized the performance of these products.
2 Bug Fix for USB Link Software (BUG: when updating the LCD firmware program, the progress bar often gets lost)
AIRPLANE_ESC_HV_readme.txt
2013-05-13
database version:V3.3
1. add LCD Program Box: PROGRAMECARD / HW310_V2.1 / V1.14_130508
USB_Link_readme.txt
2013-11-30
2013-05-13
Software version:V3.3
1. Database is updated to the latest Version 130511, include new firmware for XERUN-150A and XERUN-SCT-PRO ESC.
   Increases the sensor siganl tolerance for the 4 poles sensored motor, increase the reliability of the ESC,
   and the startup of motor becomes more powerful and more smooth.
2. The firmware of the Multifunction LCD Program Box is updated to improve the compatibility with 64bits Windows 7 operating system.
2012-12-4
Software version:V3.2
Improvements in the Hobbywing USB Link Software V3.2 vs. V3.1
1. Database is updated to the latest Verison 121204, includes new firmware for XERUN-120A-V3.1 and XERUN-Justock ESC.
2. Remove the software bug in V3.1: The error occurs when importing and exporting the Punch Rate data.
3. Improve the adjustment of Boost Slope to let the setting process easier.
4. Remove the software bug in V3.1: The 8 options of the Brake Force programmable item in the enhanced firmware for the XERUN-Justock ESC cannot be displayed or set by the software.
2012-4-1
Software version:V3.0
1. new software for Xerun-V3.
2. new software for all produce.
2011-1-19
Software version:1.63
1.add function: add ESC parameters with CAR ESC Xerun series for STOCK
2010-5-12
2009-10-23
1.add function: upgrading software have progress bar
2.add function: have Speed Calculator for governor mode setting
2009-01-16
1.Add new software for XERUN-120A-V2
2.Add new software for EZRUN-80A/150A
2009-01-07
1.Add data recorder function for motor checker
2.GT ESC have more top speed for 090105 software
2009-01-04
1.first release
2013-05-13
2012-12-4
database version:V3.1
1. add LCD Program Box: PROGRAMECARD / HW310_V2.1 / V1.12_120426
2012-4-1
database version:V3.0
1. new software for for all produce
2011-9-21
database version:1.19
1.Upgrade Platinum ESC software for PL120A-HV,
  The    V1.08_101106_U_a    is ok for V-bar + Hyperion emeter version2 tachometer RPM sensor
2011-8-31
database version:1.18
1.Upgrade Platinum ESC software.only for PL40A-PRO,PL60A-PRO,PL80A-PRO,PL100A-PRO,PL120A-HV
2011-1-19
database version:1.17
1.Upgrade 2In1 LCD Program Box software
2010-11-06
database version:1.15
1.Upgrade Platinum ESC software.only for PL40A-PRO,PL60A-PRO,PL80A-PRO,PL1000A-PRO.
2010-5-12
database version:1.14
1.Upgrade Platinum ESC software.only for PL40A-PRO,PL60A-PRO,PL80A-PRO,PL100A-PRO.
2.Upgrade 2In1 LCD Program Box software. add ESC parameters with CAR ESC Xerun series for STOCK,add display ESC software version,add display ESC parameters and items number.
2010-4-22
database version:1.13
1.upgrade Platinum ESC software.only for PL40A-PRO,PL60A-PRO,PL80A-PRO,PL100A-PRO.
2009-12-24
database version:1.10
1.when run to set ESC parameter state,it should must to reset ESC,then can drive motor
2009-10-23
database version:1.09
1.first release
CAR_ESC_readme.txt
2013-11-30
2. The acceleration is much quicker than before. The new firmware eliminates the discontinuous speed jump in the old firmware, now its control feeling in sensorless mode is very near to the control feeling of sensored brushless system.
a) It doesn¡¯t allow the neutral throttle point coinciding with the full throttle point, while the old firmware allows user to set them to a same point. Therefore, the new firmware eliminates the possibility of unexpected full-speed running when the ESC is switched on. Undoubtedly, it makes the whole system safer for users and crowd nearby.
2013-05-20
database version:130520
1. Database is updated to the latest Version 130520, update firmware(V1.0_130520_Beta) for EZRUN-WP-60A and EZRUN-WP-80A,fixed a bug.
2013-05-16
database version:130516
1. Database is updated to the latest Version 130516, include new firmware(V1.01_130515a_2R) for XERUN-150A and XERUN-SCT-PRO ESC.
2013-05-13
database version:130511
2012-12-4
Car ESC Database:121204
1. new database for Xerun-V3.
2012-4-1
Car ESC Database:120317
2011-10-11
Car ESC Database 111011
The Firmware database of the car ESC has been updated to the latest Version 111008.
1.  Two new firmwares named "V3.0_110930_MOD" and "V3.0_110930_STOCK: are available for the following ESC's:
    XERUN-120A (V2.0), XERUN-60A (V2.0), XERUN-120A (V2.1), XERUN-60A (V2.1), Xtreme STOCK
    a)  "V3.0_110930_MOD" is an improved firmware version based on "V3.0_110119_MOD"; the new firmware has been updated to improve the fault tolerance of the signal quality of the Hall sensors within the sensor board of brushless motors.
        The old firmware was found to be too sensitive to any small change of the sensor signal, in turn causing the ESC to frequently switch its running mode from sensored to sensorless. The new firmware is not as sensitive, so the ESC can still operate in sensored mode even if the signal has slight changes in amplitude from small error, that might eventuate this will help Mod motors which have very large current flows which cause the signal within the sensor board of the motor to change frequently causing unnecessary errors .
    b)  "V3.0_110930_STOCK" is a new version based on "V3.0_110211_STOCK", same improvements as above.
2.  New firmware named "V3_508_No Timing" is also available for the JUSTOCK ESC. The improvements are as follows:
    a)  The "Maximum Brake Force" has been increased from 4 options to 8 options for finer adjustment.
    b)  The new firmware has also been improved for fault tolerance of the signal quality of the Hall sensors within the sensor board of the brushless sensored motor¡¯s.
3. New firmware named ¡°111011_2R¡± is available for the following ESC's:
XERUN-80A, XERUN-150A, XERUN-SCT Pro
    a)	"111011_2R" firmware improves the fault tolerance of the signal quality of the Hall sensors within the sensor board of brushless motors.
    b)	The over-heat protection threshold for the ESC is increased to more than 110 Celsius degree, and the over-heat protection function for XERUN-SCT-Pro ESC can be disabled now. (In the old version firmware, the over-heat protection is permanently activated and cannot be disabled by user)
2011-3-10
Car ESC Database 1.93
New!The newest firmware 110211_stock is released.
Team Hobbywing won the Open Brushless Racing in TITC 2011 with this firmware.
2011-1-19
Car ESC Database 1.92
New! V3.0_110119STOCK and V3.0_1109119_MOD are released.
Compared with the previous versions such as 0518_STOCK, the 3rd generation STOCK firmware of "110119_STOCK" has the following improvements:
1.Stronger and quicker acceleration, but the temperature of ESC and motor is even lower than before.
2.Boost Timing and Turbo Timing can be adjusted more smoothly, with the precision of 1 degree per step.
3.Turbo Timing and Boost Timing can be composited to be functional together (Total effective timing is 60 degree).
4.Turbo Timing increasing rate (slope rate) is adjustable.
5.Brake Force is changed from 4 options to 8 options.
2010-09-17
Car ESC Database 1.79
The new firmware "100912-2R" of XERUN-80A,XERUN-150A EZRUN-SC10 ,EZRUN-SC8 has the following improvement:
1.Eliminates the bug of ESC shortly been shut off(usually several seconds) caused by mistakenly thermal protection
2.Optimize the switching of forward and backward
2010-07-20
Car ESC Database 1.76:
1.The new firmware "VER1.0_100715-2R" of XERUN-80A and XERUN-150A ESC eliminates the compatibility issue when the ESC works with Futaba 4PK system in sensored mode, and the reliability of the ESC is also improved.
2010-06-10
database version:1.75
1.The new firmware "100605" for XERUN-150A/80A significantly improves the start performance at very low PRM, and the throttle linearity is also improved.
2.The new firmware "100528_Mod" for XERUN-120A/60A V2.0 (or later version) is suitable for Modified Group racing. The turbo technology is also applied in this firmware, so the top speed is increased.
2010-05-18
database version:1.74
1.Add new STOCK firmware "100518STOCK" for XERUN-120A-V2 ,XERUN-60A-V2,Fixed some BUG .
2.Add new  firmware "100324_3R" for XERUN-80A ,XERUN-150A , support the sensored motor more smooth.
2010-04-26
database version:1.72
1. Add new STOCK firmware "100422STOCK" for XERUN-120A-V2 ,XERUN-60A-V2 ,the stock software have the dynamic timing and Turbo function.
2009-12-18
database version:1.69
1.add new software for XERUN-120A-V2,XERUN-60A-V2 ,XERUN-80A-V1,XERUN-150A-V1
2009-11-19
database version:1.65
1.have new software for CAR_ESC
2009-10-23
1.add some new items
2009-01-16
2009-01-07
2009-01-04
1.first release
Anyway, ended then up with V3.4 of the PC program and and the V1.14_130508 on the LCD Box. (I still have the V3.2 installed also)
And I can't get connected to the ESC at all.
I did keep V3.2 of the PC program and when I connect to my other SCT Pro (Blue Ver.) I do connect and can do all my settings as before.
As I recall from my head last season I did some search as I did have some issues then also, but fixed it. What I did I can't remember but i do think that was just a small issue with the LCD box having a to old version of firmware..
Anyway, any ideas?
My thought is that I have the wrong (to old or new version?) version of firmware on my new ESC and is not compatible with the LCD box.
Any help would be appreciated very much as I have been fiddling with this for two days now hehe..
hugin_q3 is offline
Old 01-11-2014, 01:43 PM
  #5555
COBRARACING's Avatar
Hardware used:
Software used:
Code:
readme.txt
2013-12-02
CAR_ESC_readme.txt
2013-11-30
USB_Link_readme.txt
2013-11-30
2013-05-13
USB_Link_readme.txt
2013-11-30
2013-05-13
2012-12-4
2012-4-1
2011-1-19
2010-5-12
2009-10-23
2009-01-16
2009-01-07
2009-01-04
1.first release
2013-05-13
2012-12-4
2012-4-1
2011-9-21
2011-8-31
2011-1-19
2010-11-06
2010-5-12
2010-4-22
2009-12-24
2009-10-23
1.first release
CAR_ESC_readme.txt
2013-11-30
2013-05-20
2013-05-16
2013-05-13
2012-12-4
2012-4-1
2011-10-11
2011-3-10
2011-1-19
2010-09-17
2010-07-20
2010-06-10
2010-05-18
2010-04-26
2009-12-18
2009-11-19
2009-10-23
2009-01-16
2009-01-07
2009-01-04
1.first release
Anyway, any ideas?
You need to remove your rx wire from receiver or have a zero input to the radio as the rx port takes precedent over the programming port .
COBRARACING is offline
Old 01-11-2014, 02:03 PM
  #5556
ESC Suggestions for the new TLR 22-4. Its the new 4wd buggy?
Thinking of a 7.5t
braderb is offline
Old 01-11-2014, 02:34 PM
  #5557
FastPete's Avatar
Trader Rating: 44 (100%+)
Thinking of a 7.5t
V3.1 120AMP would be sweet, smooth, tons of power.
FastPete is offline
Old 01-11-2014, 03:14 PM
  #5558
Kaw1000's Avatar
All is good...Thank you!
Kaw1000 is offline
Old 01-11-2014, 03:18 PM
  #5559
hugin_q3's Avatar
Hi there
Yes, I have done it that way from the start. To eliminate the errors as much as possible.
For my first SCT Pro I made this easy with a extra connection wire as I do run an external 10Amp BEC. So I always disconnect from the RX and the external BEC when connecting to the system, so the RX is not in the picture at all. And last attempt today I did have everything out of the car on the table to have a full control to everything.
So that way I should be all good when it comes to the routines connecting everything together correctly. As I did on my Blue SCT Pro, that works flawless on the V3.2 software.
However, another question, is there any way to, lets say 'flash' back older firmware to the USB card some way?
That will be from the newer V1.14_130508 to the older V1.12_120426 (?) version? (If that in any chances are the problem at all..)
hugin_q3 is offline
Old 01-11-2014, 03:33 PM
  #5560
SCTE is finally finished with HW SCTPro and HW4000kv motor. Track time tomorrow but gave it a test run on the street....this thing produces loads of low and top end power. I'm very please, can't wait to get it on the track. Thx to all for the program help, much appreciated.
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-20140111_134056_resized.jpg   HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-20140111_134128_resized.jpg   HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-20140111_134111_resized.jpg
Borik is offline
Old 01-11-2014, 04:39 PM
  #5561
5th wheel's Avatar
Looks very nice. Great job
5th wheel is offline
Old 01-11-2014, 04:52 PM
  #5562
FastPete's Avatar
Very nice. Enjoy
FastPete is offline
Old 01-11-2014, 05:13 PM
  #5563
spookie's Avatar
Trader Rating: 25 (100%+)
Hi there
Since you're running an external bec, do you have the red esc/ rx wire in or out of the rx connector? It has to be in to power the lcd box. Then after changes, slip it back out to be able to run the external bec. That's what I have to do since I also run an external bec.
spookie is offline
Old 01-11-2014, 07:02 PM
  #5564
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Good Deal!!!
Glad you got it sorted out... now have some fun!
Alan
JFuel11 is offline
Old 01-11-2014, 07:04 PM
  #5565
JFuel11's Avatar
Default PC still connected?
Hi there
Are you trying to connect to the ESC with the programming box still connected to a computer?
JFuel11 is offline
