HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree196Likes
Old 01-08-2014, 04:53 AM
  #5491
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Originally Posted by mtn bkr
Okay, I am at wits end and am ready to give up on Hobbywing equipment. Had my 90a Xerun that I bought on eBay crap out right after calibrating. Bought a Justock from Hobbywing North America and that one has also stopped responding right after calibrating. Before I even installed it into my car I plugged it into my programming card to make sure it worked, and sure enough it did. Install it in my car tonight, calibrate it, test the throttle successfully and then it stops responding just like the 90a did. No longer works on the programming card and won't calibrate either. No beeps and no lighting of the LED.
I'm honestly at a loss for words. I've been racing for 13 years and have never killed an ESC, and now I have 2 brand new Hobbywings crap out within a 2 week span. Nothing has been connected incorrectly. All I did was solder the ESC to the motor, solder the Deans plug on and calibrate. I've used this same receiver, servo, battery and motor with Turnigy, Novak and LRP ESCs without issues so I don't believe it's my equipment causing this. I just put my Turnigy ESC back in and it's working fine with the exact same motor, battery, receiver, servo and sensor wire that seem to be killing the Hobbywing ESCs.
you know thats extremely weird, i have 4 sec's from HW and i have had my sctpro for over year and a half with no issues....
BlackStarRacing is offline
Old 01-08-2014, 06:18 AM
  #5492
nanoverse's Avatar
Originally Posted by JFuel11
I am assuming you went with the 4000 or 4700KV Motors.
Basic Settings:
Running Mode: Forward/Brake
Drag Brake Force 5%
Voltage Cut-Off 3.0V/Cell
DDRS Start Mode (Punch): Level 9 (Max) Reduce if too much bottom end
Max Brake Force 100% - Reduce to 75% if brakes are way too strong
Advanced Settings:
Max Reverse - NA (If going to run reverse I only use 25 0r 50%
Initial Brake Force: =Drag Brake Force
Neutral Range Narrow
Boost Timing 0 (If running 4000KV Motor you may want to add 5 - 10 Degrees
Turbo Open Time NA (No Turbo on 4 pole Motors)
Overheat Protection Enabled
Turbo Timing NA
Boost Start RPM (4000 RPM)
Turbo Open Delay NA
Boost Timing ACC: 350
The best way to optimize your setup is as follow:
A - Gearing: Run with no timing in esc and work out best gearing for power and temp
B - Drop on tooth on pinion and start to add esc timing to increase overall power and top end if needed, watch temps.
Temps can rise very quickly when adding timing so go slow and add a little at a time and then test run and check temps 1 Min in 2 Min in and then every other min. until you reach race time!
Good Luck!
Alan
If the aim is to get smooth usable power more in line with the smoother powerband of 2-pole motors, on medium traction tracks then I would suggest these settings with the 4000kv.
Drag brake: 0 (Four poles have more than enough internal drag brake)
Punch: 3-6 (Again 4-poles are torque monsters as is, if you overgear then little more punch)
Timing: 0-3 (Start with 0)
Gear: Look what the gearing ratio is to achieve 1:1 and over gear one to three pinion sizes. This we have found to get the tire spinning into check and get that top speed.
If you have a super grippy surface than upping the punch is useful, otherwise it just adds to tire spinning.
Last edited by nanoverse; 01-08-2014 at 11:30 AM. Reason: Timing was supposed to be 10 degrees max and not setting 10.
nanoverse is offline
Old 01-08-2014, 08:20 AM
  #5493
pballer2777's Avatar
Trader Rating: 28 (100%+)
Originally Posted by pballer2777
Quick question. I have the 120amp 1/8th scale esc with the 4274 2200kv esc. I was thinking about putting this combo in a 8t 2.0 truly for motorama. Would this combo be good enough for truly and what pinion should I start with?
anyone please?
pballer2777 is offline
Old 01-08-2014, 09:33 AM
  #5494
Timing: 0-10 (Start with 0)
Hey quick question my software doesn't have these options for my sctpro.... Is there a special software to download?
Old 01-08-2014, 11:22 AM
  #5495
nanoverse's Avatar
Load latest software from HW site and update prog box or just use the box to adjust settings and later update.
These should be visible through the box.
Edit: Sorry the timing was supposed to be about 10 degrees (0-4) max and not setting 10!
Old 01-08-2014, 11:39 AM
  #5496
rcboy1's Avatar
When you calibrate, are you sure youre doing it in the correct sequence? If you do not do it correctly the esc will lock up and not respond because its trying to 'center' itself and it cant because the throttle range is incorrectly set.
rcboy1 is offline
Old 01-08-2014, 11:50 AM
  #5497
bstadtler's Avatar
Default motors
This an email I got from FalconSedko after I sent my motor back for repairs
YW13INV1223-1
Dear
Our RMA has inspected the ESC at multiple levels. The sensor board got burned out and it needs to be completely replaced. This happens from various reasons but mainly by power related source (over surged current, irregular current C). You may want to check the brand, age, and current stability level of batteries, most importantly connect wires correctly.
As you are our value customer, we will issue the brand-new replacement this time with no extra charge. Please find the inspection summary.
=== Inspection Summary ===
Motor: Xerun 4068SD Brushless Blue Edition
Term: non-defect,
Purchased from authorized Dealer - YES
Instruction: Provide a brand new motor
Service Charge: $89 - waived
S/H: $8.99 - waived
Total: $0
It refers to my escape but they replaced my motor; it would bind up on me.
Are they talking about a motor or speed controller? What board burned up?
I'm using their esc's with their motors and SMC 65C 4 cell batteries and my other car works great. Just the one bad motor so far. This also happened on a Novak escape and motor; which is why I switched to Hobby-wing.
What do you guys think?
bstadtler is offline
Old 01-08-2014, 12:03 PM
  #5498
mtn bkr's Avatar
Trader Rating: 19 (100%+)
I followed the sequence in the instructions. If it's locks up shouldn't it still respond to the program card?
mtn bkr is offline
Old 01-08-2014, 05:33 PM
  #5499
When it locks up, are you able to disconnect power and then go through the steps again for calibration, or is it completely not responding even after sitting a while?
Have you tried reversing your throttle channel prior to calibrating to see if that helps?
treys1 is offline
Old 01-08-2014, 05:44 PM
  #5500
mtn bkr's Avatar
No longer responds to attempts at calibrating. Throttle channel on my radio is currently reversed.
mtn bkr is offline
Old 01-08-2014, 05:49 PM
  #5501
Hmm....
Are you using an external BEC? If so have you pulled the red wire on the ESC?
treys1 is offline
Old 01-08-2014, 06:41 PM
  #5502
mtn bkr's Avatar
Hmm....
No external BEC. I was initially able to calibrate and have it respond to a slight pull of the throttle. After 2-3 seconds it stopped responding to any throttle input and further calibration attempts have been unsuccessful. When I plug it into my program card I only get negative symbols for all 3 displays. Still powers up the receiver and fan just fine.
mtn bkr is offline
Old 01-08-2014, 07:11 PM
  #5503
Ah, I was going to say try to re-flash the firmware but it sounds like you have the LED program card, not the LCD that hooks up to the computer.
If you just bought it follow the instructions here http://www.falconsekido.com/pages/rma to send it back and have it fixed.
I'm sure if the gear is new they will take care of it.
treys1 is offline
Old 01-08-2014, 08:23 PM
  #5504
FastPete's Avatar
Trader Rating: 44 (100%+)
Sorry was away today guys. I read all this I agree get a RMA send it back let them take a look at it. Im sure they will take good care of you.
FastPete is offline
Old 01-08-2014, 08:28 PM
  #5505
I've got your back... LOL
treys1 is offline
