HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 01-01-2014, 12:46 AM
  #5386
FastPete's Avatar
Trader Rating: 44 (100%+)
Happy New Year everyone! I been busy putting my new Tekno EB48.2 with a SCT Pro.
FastPete is offline
Old 01-01-2014, 03:14 AM
  #5387
d_scientist's Avatar
Hi there,
My 150A esc has its red led on all the time. The esc still works but can I know what is the problem? My motor is currently a sensorless while my esc is sensored.
PLS help
d_scientist is offline
Old 01-01-2014, 08:13 AM
  #5388
Trader Rating: 37 (97%+)
Originally Posted by d_scientist
Hi there,
PLS help
Sounds like you just need to set the throttle trim on your radio. If I remember correctly the light should be off at neutral but I may be wrong.
charlesandstuff is offline
Old 01-01-2014, 08:47 AM
  #5389
FastPete's Avatar
Hi there,
PLS help
I would recalibrate
After power on, red LED always lights
Throttle signal is abnormal
Plug the control wire into the throttle channel of the receiver correctly.
FastPete is offline
Old 01-01-2014, 10:02 AM
  #5390
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Use Any One You Want
Originally Posted by 5th wheel
Jful11
been using your blinky setup works good. I used it on the esc were it's at(zero timing)
if I want to try your other set ups were on the esc should I do this were it's at buggy/sct.
or mode 1.or 17.5 there are 10 things to pick from.?
Jerry,
You can really use any one you want as you can't really mess anything up. The Profiles are just pre-set to help but can be changed and configured how you like.
JFuel11 is offline
Old 01-01-2014, 12:16 PM
  #5391
Tracy B's Avatar
Here's a quick update:
Got the track owner to give me some time to run the car on the track yesterday, and after about the 3 1/2 minute mark the green and red LEDs were flashing, which indicates that the motor is a sensored motor, but the ESC detects abnormal signal from the sensor, so it switches into sensorless mode.
The manual also states to check the connection of the sensor cable, which I did, both cables I tried, fit snug into the motor and ESC. Again, stated in the manual, the sensors in the motor may be damaged, please change the motor.
I took apart my Thunder Power 17.5 sensored brushless and inspected the sensor unit, sure enough, it smelled and looked burnt. The motor was set to 30 degrees of timing during the December 15 race and got extremely hot, this is the same race my Tekin got plugged in backwards.
I'm going to order a new sensor unit for my TP and see if that's the problem.
Tracy B is offline
Old 01-01-2014, 12:51 PM
  #5392
FastPete's Avatar
Thanks for the update, glad your making progress.
FastPete is offline
Old 01-01-2014, 03:01 PM
  #5393
JFuel11's Avatar
Default I like progress...
I have found that the TP motors product decent power but I have witness many having this issue because they don't like a lot of heat and they get that burnt varnish smell over time. On the same note many have had really good luck with them, but they are not my cup of tea.
Hope you get it all worked out!
Good Luck
Alan
JFuel11 is offline
Old 01-01-2014, 03:24 PM
  #5394
Captcha's Avatar
With help from a good friend, we got my spyder all wired up. Just from doing a little epa testing and diff breaking in we are both astonished at the smoothness and overall quality of this 50$ esc!
Pre motor and receiver mock up.
Final install.
Captcha is offline
Old 01-01-2014, 04:13 PM
  #5395
5th wheel's Avatar
Buggy looks good
5th wheel is offline
  #5396
5th wheel's Avatar
Thanks jful11
Old 01-01-2014, 06:39 PM
  #5397
FastPete's Avatar
Final install.
Very nice, whos your friend?
FastPete is offline
Old 01-01-2014, 06:59 PM
  #5398
Captcha's Avatar
Jim Andersen, pete. He helped me clean everything up and keep it all tidy.
Captcha is offline
Old 01-01-2014, 07:04 PM
  #5399
FastPete's Avatar
Figured that.
FastPete is offline
Old 01-01-2014, 10:12 PM
  #5400
I would recalibrate
Thanks a lot guys... will go back and check again.. hopefully thats the problem as I have been melting the battery lead solder 3 times yesterday!!!!
