HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 12-31-2013, 07:28 AM
  #5371
Originally Posted by lee111m
Been running a 3.1 stock for a while now, but it still wont connect to my programming card. Tested the card on other cars and it worked. Is there anything I can do, except sanding it in?
You know that the programming card must be plugged in the plug near the power switch, and not with the plug that goes to the receiver like on the V2.1 ?
ridgeracer is offline
Old 12-31-2013, 07:43 AM
  #5372
yes
lee111m is offline
Old 12-31-2013, 07:49 AM
  #5373
Does the Ezrun 60A esc turn the 7.4V voltage into 6.0V for the servo and receiver?
JellyBeans999 is offline
Old 12-31-2013, 07:54 AM
  #5374
Trader Rating: 24 (100%+)
rcuser67898578 is offline
Old 12-31-2013, 07:56 AM
  #5375
thanks johhny appreciate the help
Old 12-31-2013, 07:59 AM
  #5376
wait and one more thing, what kind of connectors does the esc use?
Old 12-31-2013, 08:23 AM
  #5377
Old 12-31-2013, 08:33 AM
  #5378
with those batteries u recommended before, what kind of connectors should i use? something that can handle well over 100 amps with no problems, because isn't amperage of a battery calculated by say 5500MaH= 5.5X50 which equals to like 250 Amps +?
Old 12-31-2013, 09:14 AM
  #5379
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Bullets are Deans Plugs...
I mostly use Hard Packs that take bullet connectors, I prefer something like these myself:
http://www3.towerhobbies.com/cgi-bin...?&I=LXEAPC&P=7
If you go with Bullet connectors do NOT use bullets like these on the ESC:
http://www3.towerhobbies.com/cgi-bin...&I=LXJPY4&P=ML
They do not support the AMP draw that the solid ones are capabile of supporting...
If you want a traditional style of connector, then I would go with Dean Plugs, I have used these in pretty high amp draw setups with no issues:
http://www3.towerhobbies.com/cgi-bin...&I=LXKX39&P=ML
Good Luck!
JFuel11 is offline
Old 12-31-2013, 10:19 AM
  #5380
Old 12-31-2013, 11:11 AM
  #5381
JFuel11's Avatar
Default Hobbywing stepped up to the plate once again!
With the growing need of more power in the 2wd Mod Racing due to the larger high traction tracks and mid motor cars, Hobbywing has stepped up to the plate and added a 7.5 Turn motor to the V10 Lineup!
https://www.facebook.com/#!/Hobbywing.NA
Can't wait to get this motor in my mod buggy!!!
Alan
JFuel11 is offline
Old 12-31-2013, 11:17 AM
  #5382
Slotmachine's Avatar
yes
You also know that if you have the older card that does not have the battery checker on it, you can only use it on one set of speedos at a time without reloading the card with another program just for the 3.0 and 3.1 speed control.
Paul
Slotmachine is offline
Old 12-31-2013, 02:51 PM
  #5383
Trader Rating: 37 (97%+)
Anyone know when the Hobbywing M6C black (150a sd/1800kv) combo will be back in stock on FalconSekido?
charlesandstuff is offline
Old 12-31-2013, 05:28 PM
  #5384
5th wheel's Avatar
Jful11
been using your blinky setup works good. I used it on the esc were it's at(zero timing)
if I want to try your other set ups were on the esc should I do this were it's at buggy/sct.
or mode 1.or 17.5 there are 10 things to pick from.?
5th wheel is offline
Old 12-31-2013, 05:30 PM
  #5385
5th wheel's Avatar
Just don't want to mess up the esc. And do it in the wrong place. Don't really understand how this works.
