HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 12-28-2013, 10:05 PM
  #5296
rcboy1's Avatar
Check for a blown out bearing as well, this can happen at the weirdest time
rcboy1 is offline
Old 12-28-2013, 10:11 PM
  #5297
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
Subscribing.
Just tried out the sctpro with the 4700. Very nice smooth power.
JEFFs SC10 is offline
Old 12-28-2013, 11:35 PM
  #5298
I have the sct pro combo width xerun sensored 4068. I'm running it in a Serpent Cobra. What timing profile would I use. Never ran a sensored motor before. Thank you
armysoldier1073 is offline
Old 12-29-2013, 12:12 AM
  #5299
mtn bkr's Avatar
Trader Rating: 19 (100%+)
Purchased a 90a Xerun with program card and the ESC appears to have crapped out on me right after I finished calibrating. Calibrated neutral, full throttle and brake/reverse position successfully. After calibrating, I gave it a little throttle to test. Motor and ESC responded, but when I went to full throttle the ESC stopped responding. I've attempted to recalibrate, but the LED is not lighting up anymore. I hooked it up to my programmer and only see 3 solid lines there. Guessing I'm SOL?
mtn bkr is offline
Old 12-29-2013, 03:46 AM
  #5300
Captcha's Avatar
May sound simple but is your battery fully charged?
Captcha is offline
Old 12-29-2013, 05:33 AM
  #5301
primo86gt's Avatar
Need help, I am running the Speed passion 2.0gt ESC's (could not pass up the deal) My problem is programming, another racer installed the newer software and my old programmer wont work now and he is not at my local track when I need him... Can I install Hobbywing software & use the hobbywing progammer, http://www.falconsekido.com/products/lcd-program
any help would be greatly appreciated.
thanks
John
primo86gt is offline
Old 12-29-2013, 07:05 AM
  #5302
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by JEFFs SC10
Subscribing.
They are smooth glad your enjoying HW
FastPete is offline
Old 12-29-2013, 07:06 AM
  #5303
FastPete's Avatar
I run the same buggy, and esc I don't run any timing and its to fast. lol I would start with 0 and go from there, you wont need much if any.
FastPete is offline
Old 12-29-2013, 07:08 AM
  #5304
FastPete's Avatar
thanks
John
I will let JFuel confirm this one for you.
FastPete is offline
Old 12-29-2013, 07:12 AM
  #5305
FastPete's Avatar
Hi Ron,
Yes I have to ask check the battery. Once you have a fully charged battery, and the problem is still there try to shut the LVC off just to try it. Check all connections also.
FastPete is offline
Old 12-29-2013, 07:13 AM
  #5306
fq06's Avatar
Subscribing.
+1
I think that motor is about the best bang for your buck in RC right now. Runs with if not runs down the Tekin HD at about half the price in a smaller package
fq06 is offline
Old 12-29-2013, 07:25 AM
  #5307
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Question for you guys. I have the 2.1 line of speed controls and I have been known to bounce between blinky class and modified class. I do have the program box but it isn't the latest and greatest one, the one before they introduced the battery check option. Does the new box, latest and greatest, allow for me to switch between the blinky mode and the other version's that are popular with modified? I ask because right now the only way I found how to do this was to break out the pc and update the box to the software/firmware I want. Thanks in advance.
Kraig is offline
Old 12-29-2013, 09:31 AM
  #5308
mtn bkr's Avatar
Originally Posted by FastPete
Hi Ron,
Battery us fully charged and I'm unable to shut off the LVC. ESC doesn't respond to the programming button on the on/off switch being pushed.
mtn bkr is offline
Old 12-29-2013, 10:37 AM
  #5309
vr6
Trader Rating: 22 (100%+)
Shout out to fastpete for his answers to all of my hobbywing questions. Excellent guy to work with and easy website of his to purchase hobbywing items from. Give him a shout for all your hobby needs
vr6 is offline
Old 12-29-2013, 12:29 PM
  #5310
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Oh Ya!!!
Subscribing.
That is such a great combo... I personally like the 4000KV motor and gear it up a little. Does not seem to over power the truck as bad, but if you can put the power down of the 4700 then rock on!
Alan
JFuel11 is offline
