HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree197Likes
Old 11-21-2013, 09:23 AM
  #4786
rcboy1's Avatar
Originally Posted by Kraig
Has anyone had a situation where their system would cog and even after changing out the motor and sensor wire it would still do it. I put in a different speed control and all was fine. Then the next day, with the same setup that cogged before the speed control worked fine. Perhaps it is a heat issue as there was no problem with the 2-3 runs I did in practice but in the first qualifier she cogged out. Thoughts?
Its possible the esc decalibrated or there was an error in the software or something like that when you turned it on for the qualifier. Not very likely though. How hot did it get?
rcboy1 is offline
Old 11-21-2013, 10:17 AM
  #4787
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by timberline97
Ditto with a SCT410. I was going to try 15 degree, and start with a 14 tooth. Should I start with a 16 tooth?
I like to work my way up and check temps.
FastPete is offline
Old 11-21-2013, 10:19 AM
  #4788
FastPete's Avatar
Originally Posted by BlackStarRacing
Quick question: Is there much of a difference beside amps on the V3 and the V3 stock? DO they both have the same functions?
I will check for you and be back.
FastPete is offline
Old 11-21-2013, 10:21 AM
  #4789
FastPete's Avatar
Originally Posted by yacagree
Yes where is Cobra, long time no posts from him. It seems "FastPete" is the mayor of this thread now!?
Cant speak for cobra but im trying.
FastPete is offline
Old 11-21-2013, 10:22 AM
  #4790
FastPete's Avatar
Cool
Originally Posted by 5th wheel
Thanks guys I appreciaTe iT. going to my friends house tonight to see if we can make it work. I was also thinking about putting it in the center due to the wright of the ESC. it's 93 grams was going to get a center Trey to put it on above the battery box. what would be your thoughts on that. thanks for finding that picture for me appreciate all the help I get pete has also been a big help. so we'll see if we can make it work in balance out my friend is in on road guy but he has a lot of experience about 20 years or so just want to get another set of eyes looking at it thank you again y'all have a good day
Good luck Jerry
FastPete is offline
Old 11-21-2013, 10:59 AM
  #4791
@ 5th wheel
As you know I have the 120A V2.1 with caps in the right tray of my B4.1. On the left side it's the rx and the transponder. I didn't need any weight for to balance it, it's perfect without any. I think, it's because of the motor which has the weight more on the left side.
yacagree is offline
Old 11-21-2013, 12:29 PM
  #4792
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
I didn't check temp to be honest. Two different rounds with known good motor swapped out with sensor wire. I guess I will throw it back in and give her another try.
Kraig is offline
Old 11-21-2013, 01:23 PM
  #4793
FastPete's Avatar
Just the amp rating is different sir.
FastPete is offline
Old 11-21-2013, 01:25 PM
  #4794
FastPete's Avatar
Originally Posted by nanoverse
Cobra: Any chance of getting Turbo on the SCT-Pro in future firmware upgrades?
No plans to at this time.
FastPete is offline
Old 11-21-2013, 02:39 PM
  #4795
Trader Rating: 28 (100%+)
I can confirm that the functions / settings are exactly the same.
treys1 is offline
Old 11-21-2013, 02:41 PM
  #4796
I just purchased a Losi SCTE and am looking for a new ESC. I had a Slash 4x4 I was racing and I was running the Hobbywing SCT Pro esc. I was wondering if the Hobbywing XERUN 150amp ESC would be a better fit for this truck. I am running a Tekin 4000kv pro 4 motor.
Scotth13 is offline
Old 11-21-2013, 04:47 PM
  #4797
eddomak's Avatar
The 2-3 pages should cover your question, but in general the 150A is designed for 3S and you will probably encounter problems running on 2S. The SCT Pro is the best for SCTE on 2S or 3S, and if you check the SCTE thread you will see a lot of people running it there.
eddomak is offline
Old 11-21-2013, 04:53 PM
  #4798
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
thank you Sir, ordering two one for my 22-2 and for my SCT-Pro
BlackStarRacing is offline
Old 11-21-2013, 04:58 PM
  #4799
rcboy1's Avatar
Let us know how it goes Hopefully it will work perfectly for you this time.
rcboy1 is offline
Old 11-21-2013, 05:01 PM
  #4800
rcboy1's Avatar
Exactly what eddomak said. I doubt the 150amp would fit very well anyway. Nearly everyone who runs a SCTE here runs an sct pro, so it is a very good choice.
rcboy1 is offline
