HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 11-10-2013, 01:18 PM
  #4651
COBRARACING's Avatar
[QUOTE=RC*PHREAK;12711919]well i finally had an issue with one of the 10+ hobbywing esc's that i've owned. in the middle of a race, it cut down to about 2/3 throttle. when i pulled it off the track, i had no throttle. blinking light suggested a radio signal issue. swapped receivers, same issue. i dealt with sam at falconsekido and my replacement esc is on the way. should be here tuesday. if not for the holiday, that would be 8 days from the day it failed (and 7 days since i contacted sam).
thanks for the outstanding customer service hobbywing and sam (and EJ at builtrc for referring me to him).[/QUOT
That is a low signal issue and can be caused by the battery pack having a very rapid voltage drop or a damaged rx lead .Did your servo still work ?
COBRARACING is offline
Old 11-10-2013, 02:02 PM
  #4652
Hey all...so i had a little problem with my truck today...first time out with my SCTE 2.0...i have a hw 150a esc...Every once in a while i am getting a dead servo...I am using a high tech servo...i assume that this is a problem with the internal bec...If i get the programming box can i bump up the amperage of the bec? Never had this problem witha different esc on my old truck
zuki250 is offline
Old 11-10-2013, 04:01 PM
  #4653
Are you running a 2s ?
If so i do not recommend anything lower than a 3s on the 150 amp xerun and the specs are changing reason some servos need large current to operate and a 2s with the bec just dont work in most cases.
Old 11-10-2013, 04:07 PM
  #4654
I am running a 2s...i am not going to run a 3s.....maybe an external bec?
zuki250 is offline
Old 11-10-2013, 04:30 PM
  #4655
Just run a receiver rx pack or even a external booster.
Old 11-10-2013, 05:04 PM
  #4656
crocco6413's Avatar
Trader Rating: 38 (100%+)
Yes External BEC is best option, run them in all my cars, gives you the option to run HV on all HV servos, are adjustable, and keep the ESC cool due to the lack of amperage pulled from servo. Just know that when running 2S you can't really run full 7.4 volts because the battery will reach that voltage after short run times, in my SCTE I keep the BEC at 6.7 volts.
crocco6413 is offline
Old 11-10-2013, 05:39 PM
  #4657
FastPete's Avatar
Trader Rating: 44 (100%+)
I've had issues like this before on other ESCs not Hobbywing, $10 cap-glitch buster problem gone. Other ideas are good also!
FastPete is offline
Old 11-10-2013, 06:37 PM
  #4658
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
my servo still worked. tried several different batteries and two motors.
RC*PHREAK is offline
Old 11-10-2013, 07:07 PM
  #4659
Default Can't calibrate
I just got a sct pro combo with the 4700kv motor and I got it all installed and when I try to calibrate it won't let me. I hold the set button turn it on the red light starts flashing then when I push the set button to set the neutral position the red light stops blinking and it just sits there with the fan running. If I push the set button again it doesn't do anything until I turn it off then back on. I have a spektrum sr300 reciever and a spektrum dx3s controller. If somebody could steer me in a direction I would appreciate it.
Revo3371 is offline
Old 11-11-2013, 01:09 AM
  #4660
Did you pull out the bind Plug from the rx after binding?
yacagree is offline
Old 11-11-2013, 01:18 AM
  #4661
hi tehere
i got a question.
what is the difference between the xerun v3 and v3.1? is it possible to make just with an update a v3 to a v3.1?
thank you for help
EDIT:
I was searching and found the answere.
itīs nit just the programm ( bottom case, power switch....)
thank you
mihaelbencek is offline
Old 11-11-2013, 02:13 AM
  #4662
I did remove the bind plug my rx/tx was already bound together. I did rebind it however thinking that might be the problem but it didn't change anything.
Revo3371 is offline
Old 11-11-2013, 02:28 AM
  #4663
@revo3371
The steering servo works normally?
yacagree is offline
Old 11-11-2013, 03:01 AM
  #4664
Trader Rating: 21 (100%+)
Try reversing your throttle channel.
mulepic is offline
Old 11-11-2013, 03:12 AM
  #4665
My steering servo works like it should and I tried reversing the throttle servo.
Revo3371 is offline
