HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree196Likes
Old 11-06-2013, 05:48 PM
  #4621
moxford's Avatar
try putting transponder in another channel in receiver
Originally Posted by Nitro Tiger
Yes it is a RC4 pure transponder.
moxford is offline
Old 11-06-2013, 06:23 PM
  #4622
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Paulus
Got a question, for this winter i will be driving 1/10 buggy 2wd off road indoor, what would be a good hobbywing combo esc/motor ?
I will be racing on high traction carpet, most other drivers use 5.5 T in 4wd and 6.5 T in 2wd.
Hi Paulus
I like this one would be a good choice. Smooth plenty of power.
xerun-120a-v2-1-combo-x-series 6.5T
FastPete is offline
Old 11-07-2013, 05:45 PM
  #4623
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Brand new SCT Pro/4700 combo
I calibrated the esc as per instructions and it says to wait 3 seconds after the 3 beep brake calibration to test throttle but my throttle doesn't work. I have to turn off the esc and turn back on for it to work. Is this normal and the instructions forgot to mention to turn off and on the esc switch after calibrating?
BOLISARIO is offline
Old 11-07-2013, 05:59 PM
  #4624
bstadtler's Avatar
That's the same way mine worked. Tried 3 times. Seems to work OK.
bstadtler is offline
Old 11-07-2013, 06:15 PM
  #4625
FastPete's Avatar
Yep mine was that way also. You should be good.
FastPete is offline
Old 11-07-2013, 08:01 PM
  #4626
BOLISARIO's Avatar
Old 11-08-2013, 03:51 PM
  #4627
Hi, I just build up an Asso B4.1 and use my spare ESC from the Mugen MBX6 Eco. It is an SCT Pro and I'm happy with it in the Mugen but in the B4.1 the power of the motor is really weak. Even with highest timing the power is really low. I have an 9.5 T Motor and it feels like a 13.5 T. I tried an other ESC (Nosram) from a friend and the difference was amazing.
Is the SCT Pro the wrong ESC for a 2s 2wd buggy? If yes, why?
Now I ordered an 120A V2.1 and hope it will perform better!?
yacagree is offline
Old 11-08-2013, 06:48 PM
  #4628
iziman's Avatar
Have you change the setting of lipo cells from 4cells to 2cells ?
iziman is offline
Old 11-08-2013, 08:31 PM
  #4629
FastPete's Avatar
Can you list the settings?
FastPete is offline
Old 11-08-2013, 08:40 PM
  #4630
pistol78's Avatar
hey guys my two cars are both running hobbywing esc's (sct120a and xerun150a) and today both were cutting out on me. sct120a is about 4 weeks old and the 150a I've been running for well over a year. but today they would both cut out after a few laps. both were cool, no heat in motor or esc and then if I turned the power switch off then back to on they would start right up again. any ideas why this is happening or what I can do to stop it. any help greatly appreciated.
pistol78 is offline
Old 11-08-2013, 08:44 PM
  #4631
nitro_mt_racer's Avatar
Trader Rating: 245 (100%+)
Originally Posted by SC10Cletus
hey guys my two cars are both running hobbywing esc's (sct120a and xerun150a) and today both were cutting out on me. sct120a is about 4 weeks old and the 150a I've been running for well over a year. but today they would both cut out after a few laps. both were cool, no heat in motor or esc and then if I tuned the power switch off then back to on they would start right up again. any ideas why this is happening or what I can do to stop it. any help greatly appreciated.
Internal BEC's finally gave up and your Savox servos are browning out your receiver?
nitro_mt_racer is offline
Old 11-08-2013, 09:12 PM
  #4632
pistol78's Avatar
that could very well be it. I have two savox servos it my etruggy and one in my sct. thought i'd get longer than a month out of my sct120a. so what can I do to fix them? external bec's???
pistol78 is offline
Old 11-09-2013, 05:35 AM
  #4633
Yep, external 10a bec's will fix it if the problem is the internal bec.
Old 11-09-2013, 06:15 AM
  #4634
Questions??
Here are the sreenshots. In the TX its 100% Throttle and I calibrated the ESC.
Any Ideas or is it normal that the SCT Pro doesn't perform good in a 2s 2wd buggy?
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-asso-1.jpg   HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-asso-2.jpg   HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-asso-3.jpg
yacagree is offline
Old 11-09-2013, 06:34 AM
  #4635
Do you have the latest software in the sct pro ? Try dl it again. Not for nothing but the sct pro is too large for a 2w buggy.The v2.1 will work fine .Its really tough to troubleshoot without the buggy here.
Losi57 is offline
