HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 11-03-2013, 04:47 PM
  #4606
Idk pete...i jsut cut all the solder joints and added bullets....it all turns on and runs fine....but lets see what happens once i put it all back in the truck...also it has just forward...do i need the programming box to fix that
zuki250 is offline
Old 11-03-2013, 05:01 PM
  #4607
FastPete's Avatar
Trader Rating: 44 (100%+)
Well that's good so far. You don't but it nice. Just follow the instructions and you can get reverse also. But are you saying it has no brakes?
FastPete is offline
Old 11-03-2013, 05:20 PM
  #4608
haha...not sure about the brakes...the kid who sold it to me left a servo in that didnt work, although he said it was good...so i replaced that...then checked my wiriing and it started acting funny...so i am going to go give it a try
zuki250 is offline
Old 11-03-2013, 05:48 PM
  #4609
FastPete's Avatar
Goodluck
FastPete is offline
Old 11-03-2013, 06:00 PM
  #4610
SUCCESS....Tearing up the basement and it's fine!!
zuki250 is offline
Old 11-03-2013, 06:02 PM
  #4611
FastPete's Avatar
Awesome
FastPete is offline
Old 11-05-2013, 08:19 PM
  #4612
I have the 150a xerun esc using firmware V103_130806_Beta
hi*
I am trying to upgrade or downgrade to firmware V1.00_111207a_2R
so I will not have compatibility issue with my tenshock motor
but the link is telling me beta cannot be updated to this version.
sonspit is offline
Old 11-05-2013, 08:55 PM
  #4613
COBRARACING's Avatar
hi*
It is related to the sct pro not the 150 a xerun thats why it will not allow you
To upgrade or downgrade
COBRARACING is offline
Old 11-05-2013, 09:07 PM
  #4614
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Help
I am trying to download the software on my laptop with windows 7 home. I click the download and I get the "windows can not open this file".
I checked my downloads and I see the file but cant right click on it to run as administrator.
kjohnsiii is offline
Old 11-05-2013, 10:32 PM
  #4615
Originally Posted by kjohnsiii
Help
You need to extract the files with winrar the run setup .
Old 11-06-2013, 06:20 AM
  #4616
kjohnsiii's Avatar
I used winzip and got it going now!
Old 11-06-2013, 11:36 AM
  #4617
Paulus's Avatar
Got a question, for this winter i will be driving 1/10 buggy 2wd off road indoor, what would be a good hobbywing combo esc/motor ?
I will be racing on high traction carpet, most other drivers use 5.5 T in 4wd and 6.5 T in 2wd.
Paulus is offline
Old 11-06-2013, 03:54 PM
  #4618
Nitro Tiger's Avatar
I run the HW 2200kv motor with the 150a esc, my problem is when I connect my transponder to the reciever the motor won't turn on or more so transmitter does nothing when esc switched on, do hear the usual sound when I turn on the esc, disconnect the transponder everything works fine.
Any ideas??
Nitro Tiger is offline
Old 11-06-2013, 04:13 PM
  #4619
iziman's Avatar
Any ideas??
I do have same problem with my RC4 3wires connected to spktrum SR3100 on bind channel, ESC does not react nor the steering servo. unplug the RC4 and connected to AUX channel then everyting back to normal.
in case you have 2channels Rx, try to make Y cable for transponder from battere
iziman is offline
Old 11-06-2013, 05:39 PM
  #4620
Yes it is a RC4 pure transponder.
