HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 10-22-2013, 05:56 PM
  #4501
Default Hobbywing 4274SD 2200kv sensor problem
hello
i m new to this forum and i need your help with a hobbywing motor issue as the company dont reply to my emails
i have one month now a hobbywing ESC 150A v2.1 with 4274SD 2200kv sensored motor
ESC is new, motor i bought it used
i have installed on a traxxas summit , it works fine for two weeks
the last five days the motor when i powered on it work fine for 30 sec after that in slow speed make interupts , noise or stop complete in high throttle it work when slow down it start again but with some cliks in the throttle it start moving.
my conclusion after reading is that maybe i have hall sensor problem or cable sensor problem but i check the cable and the problem appears in very slow speed after exact 30sec.
so i ask i read in the forum that maybe the esc have the problem
i disassemple the motor and clean and inspect visually all seems fine
as you can see in photos
i cant find anywhere the hall sensor board , is this motor for garbage ?
please help
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-hall-sensor-1-sm.jpg   HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-hall-sensor-6-sm.jpg
nikopol888 is offline
Old 10-22-2013, 08:48 PM
  #4502
Trader Rating: 28 (100%+)
Any update on the instant reverse?
treys1 is offline
Old 10-23-2013, 02:29 PM
  #4503
FastPete's Avatar
Trader Rating: 44 (100%+)
They are thinking about it. Probably wont happen real fast. But in the near future I bet.
FastPete is offline
Old 10-23-2013, 03:04 PM
  #4504
COBRARACING's Avatar
At the moment we have no plans to implement instant reverse in out software by removing the slight delay reason is esc protection and drivetrain
COBRARACING is offline
Old 10-23-2013, 06:42 PM
  #4505
FastPete's Avatar
There it is from the horses mouth! Thanks
FastPete is offline
Old 10-24-2013, 10:47 AM
  #4506
onekiwi's Avatar
I have in my box a HW 120A V2.0 esc
The esc works well BUT when it (the buggy) is at speed there isn't enough power going to the servo and it doesn't turn nearly at all.
When im not on the gas its fineish or if I hold it off the ground and turn the wheels its fine. Only on power the problem arises, although the servo isn't at the speed anyway.
Is there a fix or something I could do besides plugging in a life battery pack to the receiver?
onekiwi is offline
Old 10-24-2013, 09:03 PM
  #4507
Dang.
That is the one thing keeping you from gaining a bigger following in the crawler / scaler market.
treys1 is offline
Old 10-26-2013, 08:46 AM
  #4508
UrabusDenis's Avatar
Originally Posted by UrabusDenis
Hi, can someone confirm that Yuki Model Yakuza Boss 1/8 brushless line is a rebranded Hobbywing, approved by Hobbywing? (and not a lower-quality clone?)
Anyone?
UrabusDenis is offline
Old 10-26-2013, 01:27 PM
  #4509
Genebaby's Avatar
Originally Posted by Genebaby
Savox cause issues with a lot of ESC's, though I think my brother hasn't had much trouble with a Savox and his HW 150A ESC. I just don't get Savox myself.
Question from me, now that I am going to be running this SCT Pro, how do I know if it's actually running sensored, as opposed to the cable is stuffed but the car still runs.
Is there a way to tell I need to replace the sensor cable?
Anyone got any help on this one?
Genebaby is offline
Old 10-26-2013, 01:37 PM
  #4510
Trader Rating: 45 (100%+)
Hey i got a 120a v2.1 xerun gonna run it with a 8.5t in my b44.1 but i want to run some timing and boost to get it to run with the guys running 6.5t at the track which firmware should i b running to get the results i want? Should it be a mod firmware or a stock with boost/timing firmware? And what are a good base timing boost setup? Thanks
Justin33 is offline
  #4511
nitro_mt_racer's Avatar
Trader Rating: 240 (100%+)
Sensorless motors or sensored motors with the sensor wire unhooked will cog slightly from a standing start. This should be your first indication that the sensor wire might need changed.
nitro_mt_racer is offline
Old 10-26-2013, 03:58 PM
  #4512
Genebaby's Avatar
So that is the only way? Cheers. I'll test it now and then, see how it goes when it's slow.
Genebaby is offline
Old 10-26-2013, 04:38 PM
  #4513
Trader Rating: 7 (82%+)
is there plan on putting a current limted in the software
RavensNightFury is offline
Old 10-26-2013, 06:28 PM
  #4514
thejudge's Avatar
Default 3656SD Motor Heatsink
Has anyone put a heatsink on the 3656SD Motor?
I live in a warm tropical environment with 33Deg Celsius as the average temperature, and want to put a heatsink and fan on the motor as a precautionary measure.
Post pics of your setup if you can.
Cheers
thejudge is offline
Old 10-26-2013, 09:01 PM
  #4515
Trader Rating: 21 (100%+)
Cheers
I use a small one, but i know guys who use heat sinks with fans. Not the best pic but it shows heat sink on my 3656-4700kv motor
NvDesertRat96 is offline
