HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 10-18-2013, 01:48 PM
  #4486
rcboy1's Avatar
Originally Posted by crazydane
Hello, I just received my Xerun STOCK Spec v3.1. I am running it in a Team C TC02 2wd buggy with 2s Lipo and Tekin Gen2 8.5T.
The speed control does not fit. In order for me to make it fit I need to raise it on a platform off the chassis. However the fan then gets in the way of the body.
Question: Can I run this speedo "without" the fan safely without damaging this unit?
Cheers,
CD
Just like cobra said. Although, depending on the size of the track you can actually get away with some timing. Just start with none and slowly start increasing it and if temps get too high, lower it and leave it.
rcboy1 is offline
Old 10-18-2013, 03:03 PM
  #4487
crazydane's Avatar
Thanks both, very helpful.
This is a very short technical indoor clay track...not much in the way of airflow. I usually run without any turbo...timing maybe an option however. I will give it a shot and report back for the benefit of others.
Again, thank you for the quick replies!
crazydane is offline
Old 10-18-2013, 04:12 PM
  #4488
UrabusDenis's Avatar
Hi, can someone confirm that Yuki Model Yakuza Boss 1/8 brushless line is a rebranded Hobbywing, approved by Hobbywing? (and not a lower-quality clone?)
UrabusDenis is offline
Old 10-18-2013, 06:06 PM
  #4489
I'm having trouble with my lvc I have it set at 3.4
But I'm coming in at more like 3.0
I have the 120a v3
I've looked and can't find anyway to set # of cells just lvc
Am I missing something with my programmer
I just cranked it up to 3.8 gonna try that
I used to run a mmp and it was obvious car would slow
And then pulse at lvc
Maybe I'm just not feeling it like I'm used to
Mike
68sportcoup is offline
Old 10-18-2013, 06:10 PM
  #4490
fq06's Avatar
I have the 120a v3
Mike
Not familiar with that ESC but it may be a total voltage, not per cell. So you could be just running your pack to dead and lvc never kicks in because your at 6v, not 3.4v.
fq06 is offline
Old 10-18-2013, 06:16 PM
  #4491
Slotmachine's Avatar
I have the 120a v3
Mike
I set my [email protected] volts and it stops running when it get to 6.4 total.
Paul Rush
HWNA
Team Driver
Slotmachine is offline
Old 10-18-2013, 08:16 PM
  #4492
rcboy1's Avatar
The v3 has to be by total voltage. The fact that you can set the voltage to six proves this. Lipo batteries have a max voltage of 4.2 which is obviously lower than six.
rcboy1 is offline
Old 10-18-2013, 08:39 PM
  #4493
That was it thanks guys
Old 10-18-2013, 08:57 PM
  #4494
fq06's Avatar
Good thing you caught the fact that lvc was not doing what lvc does. I'm sure your packs will be grateful for that
fq06 is offline
Old 10-19-2013, 07:27 AM
  #4495
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
When will HW update their esc's with 5-7A/7.4v BECs so it can power HV servos?
BOLISARIO is offline
Old 10-19-2013, 10:38 PM
  #4496
Trader Rating: 21 (100%+)
Soon i hope. I use Hobbywings 5/6v UBEC with my SCT Pro because of the brown outs i get if i dont use one. All i know when it comes time to replace servos i wont be getting Savox anymore. They are to power hungry.
NvDesertRat96 is offline
Old 10-19-2013, 11:05 PM
  #4497
Genebaby's Avatar
Savox cause issues with a lot of ESC's, though I think my brother hasn't had much trouble with a Savox and his HW 150A ESC. I just don't get Savox myself.
Question from me, now that I am going to be running this SCT Pro, how do I know if it's actually running sensored, as opposed to the cable is stuffed but the car still runs.
Is there a way to tell I need to replace the sensor cable?
Genebaby is offline
Old 10-20-2013, 02:18 AM
  #4498
Hello
I just received my new hobby wing 3 in 1 programming card but only half of the LCD screen works. Is that an update or anything I can do to fix this?
Brett.w is offline
Old 10-20-2013, 09:47 AM
  #4499
hesh's Avatar
Originally Posted by Brett.w
Hello
You could try hookinp it to a computer, run the hobbywing software and try an update, but in my opinion you would be better off calling and getting it replaced.
hesh is offline
Old 10-21-2013, 10:35 AM
  #4500
derekbsmith's Avatar
Trader Rating: 25 (96%+)
I have the SCT Pro 120A ESC paired with a Trinity Revtech 4XS 540 4800kv in my 4x4 SCT, bought it new from falcon in March. I notice more often than not, the ESC will blink green+red simultaneously when its at the track after a run, or from a cold start sitting in my workshop. Per the handbook, this means "over current protection, demagnetization or motor is overloaded." Any ideas? I reduced punch from 7 to 5. I am running 54/14 setup. Assuming its a FW issue and I need to upgrade.
Thx!!!
derekbsmith is offline
