HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#4111
Yup,my E Maxx rarely cogs, on 2S/ 3S it's fine and only a little in low speed gear on 4S, when I tend to go really slow, crawling on stuff. In high, 4S it's fine. Something I rarely do on 4S. 2S in 1st is kind of cool for that sometimes and doesn't cog at all.
Thanks for pointing that out on the manual, I read through it, but must have missed it. I don't want to update the esc for something as minor as the 3S miscount issue.
#4112
Thanks for the input. One more question: the xerun 120-150A esc's calibrating fine with Spektrum DX3C, DX3R radios?
I have to change my Turnigy 150A esc because it cannot be calibrated with Spektrum radios (doesnt recognise reverse at setup).
#4113
#4114
Totally 100% confused
Hi there..I apologize if this is posted in the wrong section, but Google directed me here. I recently purchased the EZRun 3656 4700KV BL & WP SC8 120A ESC combo. I am extremely satisfied with the performance. It has put some serious stomp into my Traxxas 2wd Stampede and made my truck the envy of the neighborhood RC club. I totally love it!!
That said, I am new to brushless and I still trying to learn the ins and outs of the system. I am confused on battery compatibility for my particular system. When I bought the system I also purchased 2 batteries, One is a Turnigy 5.0 5000mAH 20-30C 2S pack, Gives it plenty of power but I don't like it because it doesn't fit the Stampede's battery tray quite right. But I purchased it to get use to the new to me power of brushless. I also purchased a Venom 4000mAH 20C 3S hard case battery that will fit the Stampede battery tray much better. Problem is I am still wet behind the ears with this technology and after reading through the units specs I am at a confusional fork in the road.
If I am interpreting the specs correct, this particular system with the 4700KV motor is not advisable to use a 3S. I would need a motor less than but equal to 4000KV. Am I correct in assuming I shouldn't use a 3S with the 4700KV motor?
I hope you can help. I am so confused. I ran brushed motors for years and I can't get out of that mindset just yet. I love my HW EZ-Run system and wouldn't trade it for the world. If I need a different motor to run my 3S battery then I will shop for one. Additionally, what is the best battery I can possibly purchase for my particular system?
#4115
#4116
Still unsure of the gearing but was told on the traxxas forums that 19/87 was a good start.
#4117
Thank you very much. I am so happy to finally have a black and white answer. I have been able to hit 45mph verified by GPS geared 19/87 on 2S. I just was curious what I could top out at if I were able to use 3S.
This site will give you an idea of how fast it is with you're particular setup. http://scriptasylum.com/rc_speed/top_speed.html
#4118
Yup and that's good ratio to start with. Watch the temps on the motor and esc.Roughly esc 140 and motor no more than 150-160 degrees, too much heat is a motor and esc killer. If it's a little to wild, drop the pinion some to say 17 tooth. My son had a Rustler, same gearing. He wanted to put a 23 tooth pinion in and I asked him why on earth would you do that lol. He didn't but started snapping driveshafts anyway. 3S on a velinion 3500 motor.
Snapped drive shafts aren't and issue. I upgraded to mips the same time I got the new BL system. I dumped a ton of $ into my Stampede the last month to make it fast and furious. Lots of RPM parts.
Does anyone have a suggestion for a really good battery for my system in a stampede. As I mentioned in my op Im using a Turnigy 5000mAH 20-30c 2S but because of how pwr wires come out of the pack I can't get it to sit in the battery tub right and I had to move the Rx just to half ass get it to fit. Since I can't go 3S on the 4700kv..what is the biggest 2S I could use?
#4119
I am getting ready to install an Ezrun WP-60, I plan on running it with lipo but I have a 7 cell nimh that I like to use when I am on shorter runs or letting friends using my truck. I saw in the manual this:
"Cooling fan (12V): The high voltage fan is necessary when you are using 3S
Lipo or NiMH battery more than 6 cells.
WARNING! Please note the original cooling fan (5V) can only work with 2S Lipo
or 4-6 cells NiMH battery. DON’T use it with a 3S Lipo or NiMH battery more than 6
cells. Please check the label of the cooling fan carefully to confirm its working
voltage before using it."
Is this really true?
#4120
Ok, so what should the first and second software be? I have 1.08 for the first and 1.01_1 for the second....I would think the sct Speedo should have a set program being its a 4pole motor..I'm getting frustrated because nobody from hoobywing is stating what software should be ran in the sct Speedo...I wouldn't worry about it if all the sct Speedos I got came with all the same software, but they don't. My buddy has 1.00_1 in his and it's a rocket and runs cool, I have 1.01_1 and runs hotter and slower....what's right or wrong.
#4121
Software versions simplified
Hobbwing/Cobra
Could you please simplify firmware versions so that normal people can read them. 1.xx and if bigger revisions 2.xx and 3.xx, etc.
#4122
Sct pro problem
I have the sctpro with tekin 4600 kv and the truck runs fine but when I bring it back to the pits and take the body off the red and green are flashing sensor wire is new. What causes this it isn't to hot either.
#4124
Eta pics
This is using the newest Hobbywing usb link software. V3.3 I hope this helps.
Over on the left you can see the two different firmware listed I have 1.08 loaded for my 150A V2 Pro or as they list it, Type B.
